Violent Shake/Vibration in front end at 40-50 mph - Chevy and GMC Duramax Diesel Forum
post #1 of 10 (permalink) Old 11-08-2012, 05:05 PM Thread Starter
anti-venomLS1's Avatar
I am beginning to get very annoyed with this.. My truck has a violent shake in the front end at around 45 mph.. When i say violent don't take it lightly, i mean violent lol.. It started when i had my worn out Toyo open country m/t's on there at no particular speed..
So i bought a used set of BFG's 325/60R20s
with approx 50-60% tread left.. it seemed to smooth out a little but at 45 mph the rattle came back.. I checked all the steering components to find i had inner and outter tie rod ends bad on both side.. So i replaced them with Moog tie rods.. No more slack or play in the steering at all.. Took the truck for a drive and the vibration was LESS than before, but the truck is kinda pulling to the left. So i thought well i'll take it to get an alignment and it will prob fix the issue... Now the truck has a bigger death wobble than before and it violently shaking.. Sometimes it won't vibrate at all.. but sometimes it will.. but it always does it at the exact same speed and gets worse in a curve.. When the tires were mounted they used a half a bag of balancing weight per tire... Seems like there is no bounce at all in the back as all the wobble is in the front and in the steering wheel..
What do you think is causing this? Could a steering dampener or wheel bearing cause this? there's absolutly no give in either wheel in the front from up and down or side to side... I used a 5 foot slate bar to pry and it had no play at all... I'm stumped and getting aggravated with it.. I can't go anywhere without feeling like i'm riding a mechanical bull... any input would be appreciated..
-Tommy Varney
08 CCSB LMM LTZ- 6" super lift with t bar drop. 35" Nitto grappler all terrains, 20x10 Moto metal 951's.. Edge evo race cts on level 2. 5" MBRP SSTB straight pipe, 6 inch tip, DDM 3000k Fogs, 6000k Lows, all on mod
Latest install: nathan airchime K5LLA, 5 gal tank, 444c
compressor
My youtube channel-http://www.youtube.com/user/tdv1985?feature=mhee
anti-venomLS1 is offline
post #2 of 10 (permalink) Old 11-08-2012, 06:03 PM
Check your hub. Jack up front wheel and grab the top and the bottom of the wheel. it should not move at all. Just had to replace mine.
2006 GMC SLT LBZ CCSB
5 inch Diamond Eye with 6 inch Tip
Tow Mirrors
20% Tint
Edge Insight
DSP5 from ATP
Helo Maxx 8's
275/65/18 Michelin M/S2
ILsilverado is offline
post #3 of 10 (permalink) Old 11-08-2012, 06:07 PM Thread Starter
there's no travel in any direction in the front wheels.. that's what stumps me.. i couldn't get it to budge with a 5 foot slate bar..
did you just replace the hub, or the complete hub assey including the wheel bearing?
-Tommy Varney
compressor
post #4 of 10 (permalink) Old 11-08-2012, 06:13 PM
It was the entire wheel bearing from Dmaxstore.
Timken Bearings (NEW + Kryptonite) [SP580310-SP580311-580312-58013] - $199.99 : DMAXSTORE.COM, Your Duramax Diesel-Only Shopping Resource
Tow Mirrors
20% Tint
Edge Insight
DSP5 from ATP
Helo Maxx 8's
post #5 of 10 (permalink) Old 11-08-2012, 07:25 PM
it could be that the tires are so bad out of balance that the half a bag of balance beads isnt doing enough and would require more weight. a half a bag does not sound like it would be enough for that size of tire. we generally just thro a whole bag ina atire which is 10 oz. i had some one time that were that size and new that took a bag and were still 10-15 oz out. we even spun them before putting the bags in them
2008 chevy duramax
cognito leveling kit
Efi Live
4" straightpipe
285-70-17 cooper stt
polemonkey is offline
post #6 of 10 (permalink) Old 11-09-2012, 08:14 AM Thread Starter
i'm thinking it's the tires.... they're saying it calls for half a bag but they didnt spin them or anything so how would they even know if they are balanced?
-Tommy Varney
compressor
post #7 of 10 (permalink) Old 11-09-2012, 09:00 AM
Lwesley's Avatar
i put a set of used wheels and tires on a jeep i had once, i put them on the jeep the exact same way they came off of the other one. changed the oil and rotated the tires took it for a spin and thought i was going to die it was shaking horribly. started changing parts and never could figure it out. moved the tires back the way they originally were and everything was fine. i think your problem is in the tires just from experience
2013 Chevy Silverado 2500
Crew Cab Short Bed LTZ
-Work in Progress-
Lwesley is offline
post #8 of 10 (permalink) Old 11-09-2012, 03:17 PM Thread Starter
UPDATE!:
Guys i want to thank you for all your time and advice... I took it to a tire place today that had a machine that can spin balance a 35 inch tire..
they broke the tire off the rim and took the junky balancing sand out of the tires, and used "stick on" weights on the inside of the wheel... Let me tell you, the truck rides smoother than a new one would!
Don't waste your time using balancing sand because in my experience it doesn't work worth a crap... Take your tires where they can spin test them for balance and it will be well worth it...
Anyway's just thought i'd share, hopefully someone will read this thread will be helpful for someone down the road.. thanks again to all you that took the time to read my problem and give me helpful advice!
-Tommy Varney
compressor
post #9 of 10 (permalink) Old 11-09-2012, 03:33 PM
chevy71pickupman's Avatar
I didn't help you out but glad you got it figured out man.
Adam
BIG THANKS TO ROB CODDENS AND DUSTIN GULLETT AT ATPTRUCKS FOR ALL THERE HELP
WWW.ATPTRUCKS.COM
www.alligatorperformance.com
DMAXSTORE.COM
chevy71pickupman is offline
post #10 of 10 (permalink) Old 11-11-2012, 05:09 PM
i hope they didnt charge you for that? since it was their mistake to begin with. but glad to hear that fixed it.
2008 chevy duramax
Efi Live
4" straightpipe
