Bad squealing.... - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 12-06-2012, 07:47 AM Thread Starter
Bad squealing....
I hear bad squealing after I turn the truck on. 08 3500HD Sierra. Keeps on squealing loud for a few minutes, then gets quieter, but I still hear it. Belts? What to look for? New to diesel. Thanks.
2008 GMC 3500 Dually 6.6
2013 Adam 3 Horse BP
Various GN LQs
Piotrcane is offline
post #2 of 9 (permalink) Old 12-06-2012, 08:08 AM
dirtymaxxx03's Avatar
I had the same problem recently. Was doing it for a few weeks, hoping it would go away. I changed the belt, and now I'm squeak free.
2012 LML LTZ
Color Matched, PPEI, FASS, SDP, aFe
Build Thread--->>SC LML Build
dirtymaxxx03 is offline
post #3 of 9 (permalink) Old 12-06-2012, 04:04 PM
I'd say belt, but you can check by just putting a dab of break fluid on the inside of the belt after it has run and with the truck turned OFF, then start it again, if it calms the noise you need a new belt.
Dan1969 is offline
post #4 of 9 (permalink) Old 12-06-2012, 04:15 PM
Thebiggids's Avatar
Pulleys or belt
GideonHeyyaa
01 LB7 EC/SB Ally 4x4
DD: 1990 4runner completely stock 4x4 3.slow
2007 Yukon Denali - Hers
Big Thanks To Adrenaline Truck Performance, Alligator Diesel PerformanceSocal Diesel and Lincoln Diesel Specialties
Thebiggids is offline
post #5 of 9 (permalink) Old 12-06-2012, 09:44 PM
Hang it!...Fire!
TDIpowered's Avatar
Xxx2
Max - 07 LBZ ECLB LOWERED!
TDIpowered is offline
post #6 of 9 (permalink) Old 12-07-2012, 03:56 AM
LHN...We ARE the Joneses
If you do replace the belt, always include a new tensioner and idler pulleys as well. They're cheap, belts aren't.
Hook'em_Horns! is online now
post #7 of 9 (permalink) Old 12-25-2012, 05:19 PM
^^^How does this tell you you need a new belt???
2003 Silverado 2500HD LB7 Ext. Cab SB. Straight Pipe Banks Exhaust, EFI Live DSP5 switched with EDGE Insight CTS, PPE Boost Valve, Hi-Idle Mod, De-badged,Banks Wastegate,S&B Intake, Blacked out Bumpers.
Backrack with brake lights and Rigid Duallys.
No Farms No Food
ACDiesel345 is offline
post #8 of 9 (permalink) Old 12-26-2012, 12:24 AM
Brake fluid works as an anti slick compound and causes it to grip, so if you put that on the track lines of the belt it's going to grip, if it makes a difference is the belt, if it still maintains the noise is a pulley.
Dan1969 is offline
post #9 of 9 (permalink) Old 12-26-2012, 09:05 AM Thread Starter
Resolution to the problem. It was a belt. Got new one on and all squealing gone.
Various GN LQs
