Typical turbo boost? - Chevy and GMC Duramax Diesel Forum
post #1 of 17 (permalink) Old 12-24-2012, 09:39 PM Thread Starter
projectblack's Avatar
What's typical turbo boost pressure? This is my first dmax and seems to produce far less boost than my cummins did, I did have an actual mechanical boost gauge on my cummins where as I'm getting my reading thru my edge on my dmax, it doesn't produce a lot of boost, probably like 12-15 psi when I get in to it. It's got lots of power so I assume the turbo is working fine, just curious
projectblack is offline
post #2 of 17 (permalink) Old 12-24-2012, 10:56 PM
dirtymaxxx03's Avatar
What year truck? My lb7 peaks at 27. Sounds like you may have a leak somewhere
2012 LML LTZ
Color Matched, PPEI, FASS, SDP, aFe
Build Thread--->>SC LML Build
dirtymaxxx03 is online now
post #3 of 17 (permalink) Old 12-24-2012, 10:59 PM Thread Starter
2008, I've never actually put my foot to the floor, but my dodge definitely produced more going up the mountain
post #4 of 17 (permalink) Old 12-24-2012, 11:02 PM
I can hit 15 easy just pulling out of a parking lot. I think my buddies lmm peaks at 35. Hit it and see what it makes.
2012 LML LTZ
post #5 of 17 (permalink) Old 12-24-2012, 11:03 PM
Thebiggids's Avatar
smaller turbo probably(cummins). Really lay into it..
GideonHeyyaa
01 LB7 EC/SB Ally 4x4
DD: 1990 4runner completely stock 4x4 3.slow
2007 Yukon Denali - Hers
Big Thanks To Adrenaline Truck Performance, Alligator Diesel PerformanceSocal Diesel and Lincoln Diesel Specialties
Thebiggids is offline
post #6 of 17 (permalink) Old 12-24-2012, 11:05 PM Thread Starter
Will do guys thanks, hey dirty lets see a pic of those hostages!! I just ordered myself those in 22 as well
post #7 of 17 (permalink) Old 12-24-2012, 11:07 PM
Bowtie Bandit Jones's Avatar
I've had 34 on my lmm with a stock turbo according to my edge insight.
2007.5 Chevrolet Silverado 2500HD
EFI Live by Idaho Rob
K&N cold air intake
MBRP dp back 4" exhaust
Air Dog 2 165
Edge CS Insight
Dick Cepek 17x9 GM8 Wheels
Bowtie Bandit Jones is offline
post #8 of 17 (permalink) Old 12-25-2012, 03:39 PM
KB3MMX's Avatar
Dodges require more boost for the same power because the Cummins head doesn't flow as much air.
Check out the CFM differences between the Duramax and Cummins heads.....you'll see why they require more boost and generally smoke more. The old 12V Cummins heads are really pathetic.
Si Vis Pacem, Para bellum !!!!
07' Chevy Silverado HD
--CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod)
--EFILive by KB3MMX Tuning W/ SDP Towing Twins (Billet S475 over Stock)
--SILVERLINE 4" Stainless Exhaust
--AMSOIL Synthetics and filtration bumper to bumper, including Bypass
--DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs
--PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes
--Danville 3" Y Bridge and big air intake kit / EGR delete
--Airdog II DF200 w/ CAT UHE filter upgrade...etc,etc...
KB3MMX is offline
post #9 of 17 (permalink) Old 12-25-2012, 04:19 PM
barsi's Avatar
Do you have a boost fooler? I have one an the more you crank the knob the less it will read I'm running a mechanical guage now
barsi is offline
post #10 of 17 (permalink) Old 12-25-2012, 04:34 PM
Specialized89's Avatar
Stock and my 90 horse tune my truck hits 25psi. 160 horse it will peak at 32psi.
Sounds like you may have a boost leak somewhere.
Specialized89 is offline
