cold weather and tranny temp - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 12-29-2012, 09:54 PM Thread Starter
Luke0872's Avatar
got a built tranny this summer and all has been good till it got cold. now every morning when I start it I have to wait damn near 15-20 mins for the tranny temp to reach 50 degrees and for it actually go into gear and move. is this just part of having a suncoast? even get solenoid codes every once in awhile while its sitting there...clear them out and then it runs fine. not sure what to think
2015 GMC SLE 2500 - IRIDIUM METALLIC - B&W GOOSENECK HITCH - 305/55/20 TOYO AT'S -WEATHERGUARD TOOLBOX & FLOOR MATTS - CUSTOM 30GAL AUX TANK - CP3 CONVERSION - EGR DELETED - PUSHER IC PIPES & Y BRIDGE - 4'' STRAIGHT PIPE - PPEI TUNING
SOLD* 2007.5 LMM - DPF DELETE - SUNCOAST GMAX 6 - ML TRIPLE DISC CONVERTER - EFI LIVE BY TODD WARREN@DIAMONDBACK PERFORMANCE - ADII 165 - EDGE INSIGHT - 4'' STRAIGHT PIPE - 6'' RCD LIFT - 35" TOYO MTS - 18" XD BADLANDS - PVC REROUTE - RESONATOR PLUGGED - S&B CAI - 5 & 6k HIDs - RANCH HAND FRONT END & REAR END - CUSTOM HEADACHE RACK - B&W GOOSENECK HITCH - EGR BLOCKED OFF
Luke0872 is offline
post #2 of 8 (permalink) Old 12-30-2012, 08:59 PM
i cany say much about the suncoast trannys i have never owned one but i will tell you the other day on my allison it was -11 outside and when i started the truck it took my tranny about 15 min to get to 75 degrees and that was with my truck on elevated idle, i dont no if this helps hopefully someone will chime in. have yuou thought about shooting suncoast a call?
2009 Duramax CCSB Black, S&B cold air, mbrp 5", magnaflow down pipe, EFI LIVE, edge CTS, Batmowheel, Fass titanium, EGR delete
1987 Chevy k10, 383 stroker, locked up front and rear.90% restored
m1000snopro is offline
post #3 of 8 (permalink) Old 12-31-2012, 04:20 PM
KB3MMX's Avatar
What fluid is in it?
When was it and the filter changed last?
BTW, it's definitely NOT normal that your truck won't drive until 50F !!
Si Vis Pacem, Para bellum !!!!
07' Chevy Silverado HD
--CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod)
--EFILive by KB3MMX Tuning W/ SDP Towing Twins (Billet S475 over Stock)
--SILVERLINE 4" Stainless Exhaust
--AMSOIL Synthetics and filtration bumper to bumper, including Bypass
--DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs
--PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes
--Danville 3" Y Bridge and big air intake kit / EGR delete
--Airdog II DF200 w/ CAT UHE filter upgrade...etc,etc...
KB3MMX is offline
post #4 of 8 (permalink) Old 12-31-2012, 05:03 PM
DieselLuver's Avatar
My Allison will go no matter how cold. It'll shift slow when it's ice cold but that's it
2007.5 Silverado 2500HD CCSB LTZ LMM
- 6" Fabtech - 35" Procomps - 17" Xd Spy's - Efi live by DDP - MBRP 5" straight pipe - 3" Downpipe - PCV reroute - DDM Hid's
2011 Sierra 2500HD CCSB LML (Buisness vehicle) - 4" Fabtec w/ DirtLogics, 35" micky Thompsons, 20" fuel boost rims - color matched cut out style
DieselLuver is offline
post #5 of 8 (permalink) Old 01-03-2013, 10:29 AM Thread Starter
Luke0872's Avatar
Running amsoil in it. Filter hasn't been changed in about 10k miles. It's only in the 20-30s outside too so I'm really wondering what's going on!
Luke0872 is offline
post #6 of 8 (permalink) Old 01-03-2013, 09:37 PM
I would say that there is an issue in the trans- like above, mine will move after running for a few minutes in -20F. Shifts goofy, etc. till warmed up, but no codes, etc. I would contact who built it for you and see what they say.... Especially since you are running syn fluid, 20F is nothing for that to handle...
'05 CC/SB, AMSOIL 15w-40 (From Synthetic Motorsports), Cold Air Intake with a dry Nanofiber filter from AMSOIL, PPE Tuner level 1, EGR blocked, LBZ MP, lost KITTY, finished off the rest with 4" SS Magnaflow, Amsoil Torque Drive, 5K HID's, General Grabbers 265 :rockin
K9Duramax is offline
post #7 of 8 (permalink) Old 01-03-2013, 09:48 PM
Dermax's Avatar
Mine will still shift ok when its -40 up here it just takes forever to warm up fully. I dont think your problem is weather related.
05 LLY CCSB, AFE Stage 2 CAI, AFE turbo MP, PCV reroute, blocked+fingerstick, shimmed, sleeved, resonator delete, Juice+attitude, Edge Insight, MBRP downpipe, Flo-Pro 4" straight pipe, built tranny and transfer case, water meth, fass titanium 150, Cognito UCA's + ptiman and idler kit, 18"s and 33" Terra Grapplers.
Next: Traction bars and EFI live
Dermax is offline
post #8 of 8 (permalink) Old 01-07-2013, 08:40 AM
Trans wont go
You could have a suction leak at the pickup tube in the trans only happnes when its cold enough for the seal to contract at the pickup tube when its cold or you have an electrical problem with one of the solenoids in the trans. My allison starts working at any temp up here. Stuck in Ohio.
gearhead 730 is offline
