Y-bridge - Chevy and GMC Duramax Diesel Forum
post #1 of 10 (permalink) Old 01-23-2013, 03:23 PM Thread Starter
Y-bridge
roughly how long does it take to remove the Y-bridge and are there any special tricks to getting it out like some fancy rubber ratchet or anything? I did my FPR and while I was in there I didnt really take a look to see how bad it would be. I bought the All Season EGR delete with Y-bridge and Im thinking of diving in on Friday.
2008 2500HD LTZ, EFI Live- Idaho Rob's Tunes, 4" Magnaflow Turbo Back, Raptor 150 Lift Pump, Transgo Jr, All Season Diesel EGR delete with high flow Y-bridge, Edge Insight for gauges,
ironman_gq is offline
post #2 of 10 (permalink) Old 01-23-2013, 03:51 PM
If youve never done this before it can deff be time consuming. By the 3rd time i finally replaced mine with a profab kit but i also had my turbo out at the same time so it took a little less time cause there was more room for your hands. Mines an 07 lbz so its a little diff but not to much, i ended up tapeing two 10mm wrenchs together and flattening out the closed end to get the front two and i also made all the bottoms studs and used a magnet to get the nuts on them. Seemed to be alot easier. Just take your time and youll be alright. Id say close to 4 hours or so if i remember??
EFI live by BOBO, Mbrp 4 inch dual exhaust,Suncoast gmax 5-3 with ml cont, S366 billet wheeled turbo, and some cool interior stuff with some cool additional exterior stuff
0IF II AND III
OEF VETERAN
WHEN IN DOUBT DROP A JDAM
:rockin
12.6 @ 108 was fun while it lasted, Sold Aug 2013 no longer a Duramax owner
polaris7x is offline
post #3 of 10 (permalink) Old 01-23-2013, 05:49 PM
klkgmc2500hd's Avatar
I believe it took me around three hours to get mine in there. Not bad, just time consuming. You can help yourself out alot by starting the 4 nuts on bottom studs before you drop the y bridge in. With having the egr cooler out of the way, I was able to get get a wrench and my hand in from the back passenger side, next to the turbo. But now I just saw you have a 2008 so may be a little different. Nevertheless, good luck and have fun.
2005 LLY GMC 2500 ecsb 4x4
FPE billet S363/73 turbo HX 40 downpipe
Grade c head gaskets w ARP studs
All Season EGR delete Y bridge. ASD intercooler pipes
PCV re-route. LBZ mp. Nicktane Cat filter adapter
S&B dry filter cai. 5" MBRP dp back exhaust
Pillar gauges and Edge CTS.
EFI Live by Kory Willis, thanks to Willie at
Synthetic Motorsports.
Stock trans for now.
klkgmc2500hd is offline
post #4 of 10 (permalink) Old 01-24-2013, 07:57 AM Thread Starter
I know the FPR wasnt a whole lot of fun, the biggest pain there was getting the intake elbow back into the Y-bridge, I probably spent over an hour alone on that.
post #5 of 10 (permalink) Old 01-24-2013, 08:37 AM
JoeGorby's Avatar
Its a pain. I had to loosen my turbo and tilt it back to get my y-bridge out. To loosen the turbo bolts I used a swivel socket. I believe its 17mm
Good luck.
2010 2500HD LMM CCSB
Tinted windows
Sweet AutoMeter gauges
Tonneau cover
More to come one day!
2013 GMC 2500HD Denali CCSB
JoeGorby is offline
post #6 of 10 (permalink) Old 01-24-2013, 12:18 PM Thread Starter
At least I have access to a full auto shop and everything in it, I should be able to figure this out.
post #7 of 10 (permalink) Old 01-28-2013, 08:16 AM Thread Starter
Well, I got it done, took most of the afternoon at the shop. There is one bolt that does not clear the turbo so I ended up cutting the head off and backing the rest out with pliers, I replaced it with an allen head capscrew that would clear. Other than that, all the fuel and coolant lines in the valley need to be disconnected and swung out of the way. I would not do this in your garage unless you have a lot of tools. I was in a full auto shop and still had to get creative a few times.
post #8 of 10 (permalink) Old 02-01-2013, 11:33 PM
Good to know
09 Sierra CCSB - 8: Fabtech Long-Travel Dirt Logic lift kit, 37" Toyo MT's, 22" Hostages, FabFours bumpers, AMP steps, Titan tank, EFI 80hp tune, FloPro 5" exhaust, 100hp piggyback.
02 T/A WS6 - PT88 turbo, forged 347, built T56, big turbo cam, HSW 75 shot, and lots of other shit.
GoinDownhole is offline
post #9 of 10 (permalink) Old 04-16-2013, 08:05 PM
Minerigger's Avatar
What kind of tools we talkin? Gonna do twins either keeping the stock unit or replacing it but either way the stock is coming out to get cleaned if i keep it.
Brock
06 LBZ ECLB
Gauges, DP Tunes, 5" Dumped, Trans by Evan @ Limitless Diesel,
DP Stg2r, Sleeved & Braced
Minerigger is online now
post #10 of 10 (permalink) Old 04-17-2013, 07:14 AM Thread Starter
A good set of flex wreches and a large array of socket in the 10-15mm range in 1/4-1/2" drive, some various screw drivers, and if the EGR is coming out, a 5' pry bar some wood a case of beer, box of bandaids and a good buddy to hold you back so you dont take the bar to the headlights. Those up-pipe bolts are very stubborn and you dont have much room to move.
