LMM DPF delete>>> - Page 2 - Chevy and GMC Duramax Diesel Forum
post #11 of 31 (permalink) Old 04-05-2010, 12:50 AM
HD-DMAX1's Avatar
I am running the FLo Pro DPF delete and on the 70hp tune with a 4x6x18" tip and it is freakin awesome
2008 2500HD 6.6L Duramax Z71 SLT, 4" MBRP T409SS With 4"x6"x18" Tip, DPF/CAT Delete, EFI LIVE DSP-5 Switch, Edge Insight CTS
Tunes From IDAHO ROB
Wheels: D'Centi 903 20x10, Tires: Cooper Zeon LTZ 305-50-20
The DMAX is sold
C'Mon Bring The PSI!:rockin
HD-DMAX1 is offline
post #12 of 31 (permalink) Old 04-05-2010, 12:53 AM
Dead beat seller!
FREIGHTTRAIN's Avatar
you can go with a full kit underneath and a quad for you programmer
FREIGHTTRAIN is offline
post #13 of 31 (permalink) Old 04-05-2010, 01:17 AM
HD-DMAX1's Avatar
Is this in reference to me!
The DMAX is sold
HD-DMAX1 is offline
post #14 of 31 (permalink) Old 04-05-2010, 01:26 AM
Dead beat seller!
no but it could be if you want it to
post #15 of 31 (permalink) Old 04-05-2010, 09:34 AM
DSTRBD's Avatar
Originally Posted by blaineGMC View Post
Considering a DPF delete on an 08 LMM. Whats my cheapest way? Disconect the sensors and cut the pipe around the DPF then beat the filter out of the DPF and weld it back on and use a programmer. Or is it a lot better to go with a DPF delete pipe.
I strongly suggest keeping your factory emissions equipment the way that it is. If/when you need to put it back on, you will be very sorry that you beat the guts out of it. It is much easier and cost efficient to buy a full MBRP straight piped 4" kit to replace the entire stock exhaust. Pair that with the Quad Stealth II and you have the cheapest solution.
DSTRBD is offline
post #16 of 31 (permalink) Old 04-05-2010, 05:16 PM
BRAAP307's Avatar
I bought the Magnaflow DPF back exhaust system which comes with a straight pipe and a muffler for your choosing, then I purchased a Proflo DPF delete pipe, that was I can be fully legal in just minutes if I need to be, the only thing I have to replace is the DPF pipe back to stock. Picked up a edge race for DPF delete setting.
BRAAP307 is offline
post #17 of 31 (permalink) Old 04-05-2010, 08:22 PM Thread Starter
blaineGMC's Avatar
wut if i just welded a chunk of four inch pipe in and tied up the sensors? Would it work? with PPE to turn it off of course
Blaine
04 LLY Suncoast/Precision ML by me. Tuned by Rob.
AFE, MBRP, Mag-Hytec, Merchant Automotive, SSBC, Bilstein
For EFI Live go to:
blaineGMC is offline
post #18 of 31 (permalink) Old 04-05-2010, 08:29 PM
AlligatorPerformance's Avatar
Originally Posted by WOLFN8TR View Post
I currently have the MBRP DPF back exhaust and my plan is to go this route because of the smog requirements here in Las Vegas. FloPro DPF delete pipe, and a Edge Evolution CTS Race programmer. I like this set up basically for the ease of swapping out the delete pipe for smogging the truck.
That's a very popular package for my Vegas and Cali. Customers.
Alligator Diesel Performance - Chad Hall Owner 1-866-255-7212
Shop Location - 4470 W. Seltice Way, Ste. E - Post Falls, ID 83854
DPF Delete PKG's - Gauge Packages - PRICE BEAT GUARANTEE - Blocker Plates
AlligatorPerformance is offline
post #19 of 31 (permalink) Old 04-05-2010, 08:39 PM
Sure, but you have a 40+K truck, then thinking about jimmy rigging a pipe in place to save a few hundred bucks. I've had several guys attempt it, then ended up with either a full exhaust or the delete pipe to save them a bunch of time and heartache. I don't mean any disrespect by this, it just doesn't make sense to me, unless you're a fabrication shop and can do all the work yourself for cheaper than a couple hundred bucks.
Flo~Pro's delete pipes and MBRP's 4" straight kit are mid two hundred dollar parts, so it might be worth it to drop the coin where it's needed, then save somewhere else down the road.
post #20 of 31 (permalink) Old 04-06-2010, 08:40 PM
"THEEPASUCKS"
WOLFN8TR's Avatar
Well put Chad...
2008 2500HD LTZ
EFI LIVE DSP5 - Edge CTS Insight - Transgo Jr.
6" Superlift - 35" Trail Grapp's - 18"Mazzi Hulks
Amp Research Steps - Billet Grille - PCV Reroute - DE Down Pipe - MBRP SS Exhaust - AFE Delete Pipe
Cognito Braces - Fabtech HD Tierods - PPE Deep Pan
Dmaxstore - Duramaxtuner - Madjacksracing -
MeyerPerformance - Alligatorperformance - Performancetruckproducts
WOLFN8TR is offline
