Location of block heater cord on 2010 - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 12-07-2010, 08:49 AM Thread Starter
1GTurn's Avatar
Hey i tried searching but didn't see anything. Can anyone tell me where the cord is for the block heater? If you have a picture that'd be awesome!
And is it okay if I plug it in from about 6pm to 5am every night? Does it regulate how long it's on for?
2013 2500HD 4DR 4x4
1GTurn is offline
post #2 of 8 (permalink) Old 12-07-2010, 09:03 AM
saw what you did there
theunderlord's Avatar
Same as on all the rest of them.
http://www.duramaxforum.com/forum/ho...faq-burrr.html
MY11 Volkswagen Golf TDI 6MT.
6K Lows, 3K Fogs, Tint.
CLICK BEFORE YOU POST!
theunderlord is offline
post #3 of 8 (permalink) Old 12-09-2010, 08:20 AM
Do all DMAXs come with a block heater standard?
Nevermind. I read th link above and answered my own question.
2003 GMC CC 4x4
AFE Stage 2, 4" Striaght turbo back
EFI Live by Dustin@Diesel Addiction,Profab Down, Pipe,Profab Intake Horn, Air Dog 150, Boost/EGT Gauges
Sun Coast Stage III w/Precision Industries Converter
6" RCD Dual Fox Shocks
Cognito Tie Rods Idler/Pitman Braces, Cognito UCAs
Hankook AT/Ms 35
That whenever any Form of Government becomes destructive of these ends, it is the Right of the People to alter or to abolish it
Giest is offline
post #4 of 8 (permalink) Old 12-09-2010, 09:27 AM
Administrator
jc1843's Avatar
All Duramax engines come with a block heater-- and it is difficult to find----- even if you know where to look.
Under the passender side battery, it is taped to the wire harness. Some have had to remove the inner panel to see well enough to remove the tape and get the cord out!
jc1843 is online now
post #5 of 8 (permalink) Old 12-09-2010, 09:39 AM
I have a timer that works nice. It comes on at 5:00am and stays on for an hour or so till I am ready to leave. They are fairly inexpensive and it saves some on electricity. Also, turn your heater on defrost before you shut the truck off, and it helps keep your window from frosting/icing over.
2003 LB7 Arrival Blue Extended Cab-Short Bed
2 Wheel Drive
Straight Piped
Pace Arrow Bed Cover
101,000 miles as of 1/1/15
edigert is offline
post #6 of 8 (permalink) Old 12-09-2010, 03:06 PM
You can plug it in all night long it wont hurt ,but 1 or 2 hours before start up saves electricity and extra wear on the heater element.Its there dont stop looking till you find it..
jmac5058 is offline
post #7 of 8 (permalink) Old 12-09-2010, 03:30 PM
To tag along on this, do any of you in the colder regions use the battery blankets? I plan on going to WY and want to make sure I dont have any starting issues with mine.
2003 GMC CC 4x4
Hankook AT/Ms 35
Giest is offline
post #8 of 8 (permalink) Old 12-10-2010, 03:37 PM
bthanks's Avatar
they also make timers that you can plug your truck into that wont turn on the block heater untill the time you set it for.
If you want your truck to be cheap and fast it wont be reliable... If you want your truck to be reliable and cheap it wont be fast... If you want your truck to be fast and reliable it wont be cheap...
08 6.7 Silverbullet, dragon slayer, arp, airdog, southbend,bds lift, bod intake/injectors, smarty- Truck Sold - Big thanks to RollinSmokediesel and BlackOpsDiesel
08 6.6 New build in progress
bthanks is offline
