Fuel Gelling?? - Chevy and GMC Duramax Diesel Forum
post #1 of 39 (permalink) Old 12-09-2010, 06:15 PM Thread Starter
Fuel Gelling??
New to diesels. I know the fuel can gel at low ambient temps. About what temp does this occur? What is the effect on the engine? And how can you tell if your problem is due to fuel gelling?
What keeps the "Ice Road Truckers" from gelling? Fuel additives, some sort of fuel heaters?
BILL T
2007.5 SILVERADO DURAMAX 2500HD Z71 4X4 LTZ
ARE CAP, NO MODS (yet)
Bill T is offline
post #2 of 39 (permalink) Old 12-09-2010, 06:38 PM
DIESELbowhunter's Avatar
dont really know what temperature it happens at but i throw a splash of additive if its cold (days when its about a high of 30F, and goes into the teens at night) when i fill up.
Heard from a decent amount of truckers that Howes diesel additive is the best.
05 LLY
Robs EFI Live
Dipper trans/ML Converter
Studs
4094
AD 165
Zone 6"/35s
DIESELbowhunter is offline
post #3 of 39 (permalink) Old 12-09-2010, 06:39 PM
lddrew's Avatar
you can buy anti gelling and cold treatment additives for your diesel to use every tank
Winter Additive
-Lee-
LBZ Crew - EFI - MBRP - Profab - Airdog
Raptor lined rockers and flares by me
my "build" thread
Raptor color match thread
ATP Trucks
lddrew is offline
post #4 of 39 (permalink) Old 12-09-2010, 06:47 PM
Banned
The northern states have a winter blend of diesel that is gel resistant down to like -20f I want to say.
2009RavenR1 is offline
post #5 of 39 (permalink) Old 12-09-2010, 06:49 PM
Duraski's Avatar
Gelling can start as high as 20. Most colder climate areas will either have a winter blend like 1/3 No 2 diesel 2/3 No 1 diesel or similar and will be displayed on pumps or will have #1 diesel and #2 diesel pumps so you can blend your own(also displayed on pumps). I use #2 primarily in winter and double that recommended rate of Stanadyne or good anti gel additive until it gets into sub zero continuous temperatures before I add #1 with additive. With winter blend of #1 and #2 you will get less fuel economy. Additive does not reduce economy. I use additive from time we start seeing 50 degree highs until again continuous above 50 degree highs.
2002 2500HD Dur/Al CC SB LS 4x4 Sprayed in bedliner, Sun Visor Star Board running boards from previous owner. Edge w/attitude is installed again.
Next Mods when I have the Cash
4" Stainless Exhaust Single Or Duals?
www.alligatorperformance.com
Duraski is offline
post #6 of 39 (permalink) Old 12-09-2010, 07:31 PM
My dad has a Duramax and it got down to -23 last year and his never even sputtered. He didn't have any anti gel stuff in either. I had howes in mine and i think the howes must of gelled up because it only goes to -20 I believe and a message came across that said fuel filter plugged and we get fuel from the same place. I think he was running the winter blend so that probably helped. Avoid biodiesel at all costs.
2009 Chevrolet Silverado 2500HD LMM, LTZ crewcab regular box. EFI, Transgo Jr. and Magnaflow from Husker Diesel
Husker Diesel- 402-502-6961
Traded:2005 GMC Sierra 2500HD LLY
SLE, Black, crewcab short box, 265s
EFI live tuned by St. Joe Diesel, 5in Magnaflow exhaust
GMCduramaxdude is offline
post #7 of 39 (permalink) Old 12-09-2010, 10:12 PM
lostscout55's Avatar
are you gelling?
2006 Sierra D/A ccsb pure as the day she left the assembly line
see also my other account (lostscout...:booboo..cant seem to log on) but not banned etc
lostscout55 is offline
post #8 of 39 (permalink) Old 12-10-2010, 04:46 AM Thread Starter
Nah, I ain't gelling. lol Low temp yesterday was in the mid teens and high was high thirtys. Not typical for SC. Just curious.
My owners manual says the use of additives is not necessary or recommended. I wonder if that includes fuel anti-gelling products?
Thanks for the replies guys.
BILL T
Bill T is offline
post #9 of 39 (permalink) Old 12-10-2010, 05:47 AM
Administrator
jc1843's Avatar
[QUOTE=Bill T;949876]New to diesels. I know the fuel can gel at low ambient temps. About what temp does this occur? What is the effect on the engine? And how can you tell if your problem is due to fuel gelling?
What keeps the "Ice Road Truckers" from gelling? Fuel additives, some sort of fuel heaters?[/QUOTE]
Lot of the trucks in cold country are never turned off when it get so cold. Run then 24/7-!
jc1843 is online now
post #10 of 39 (permalink) Old 12-10-2010, 06:13 AM
mrmanners's Avatar
I use a fuel additive and cetane booster in every tank regardless of manual. Fuel starts to gell at around 40 deg F. In the South, I just run a regular AMSOIL Fuel Concentrate but they also offer one with a cold flow additive to help keep fuel from freezing in really cold climates.
If I can help with any of these products, please don't hesitate to PM me.
Take care,
mrmanners is offline
