loud whine??? - Chevy and GMC Duramax Diesel Forum
post #1 of 35 (permalink) Old 06-09-2011, 09:40 PM Thread Starter
jk101's Avatar
loud whine???
in the mornings when i first take off out of the driveway, my truck will a really loud whine, or squal, or some kind of sound for the first few miles. it doesnt sound like a belt squeaking. it almost kind of sounds like a bearing on a pulley or somethin might be bad. it gets louder as i accelerate depending on how hard im on the throttle. and it quits after a mile or two and doesnt do it again until the next morning. any guesses on what this is? kinda has me a little concerned.
08 Chevrolet 2500hd, crew cab short bed, H&S mini maxx, 5 inch straight pipe, Airlift system, soon to come- lift pump.
jk101 is offline
post #2 of 35 (permalink) Old 06-09-2011, 09:44 PM
CVBFireman's Avatar
you could pull your belt in the morning and spin your pulleys.... if one makes a realy faint noise.. then thats it
2005 chevy 4dr SB, Garret 4094-stage-2!! EFI. EDGE CTS ROB FROM IDAHO, 8" Fabteach, 37" pro comps on 18s, straight exhaust AFE intake with mouthpiece, blacked out, custom one of a kind cab lights. full stereo with fosgate shallow 12, FabTech Tie rods. Cognito idler and pitman saver. custom traction bars, Viper Remote Start FOR IPHONE, bd blow off valve. rhino liner Theres More Just Cant Think Of It.. TRAIN HORN!!!!, Diamond Eye DP, Radar/laser Detector--AND JAMMER. fox gauges. air ride bags/ with on board air..Mag Tech Diff Cover
CVBFireman is offline
post #3 of 35 (permalink) Old 06-09-2011, 10:49 PM Thread Starter
jk101's Avatar
has this happened to anyone else?
jk101 is offline
post #4 of 35 (permalink) Old 06-09-2011, 11:41 PM
DeMax LB7's Avatar
Could almost be a u joint... maybe hard telling.
2002 Chevy 2500HD LT
Night Train
Never Enough Parts
DeMax LB7 is offline
post #5 of 35 (permalink) Old 06-10-2011, 04:51 AM
Mine doesnt wine but it does sound different until it warms up. my truck has always been cold natured. Doesnt run right till its warmed up. I thought all diesels were like that.
08 ccsb 4x4. Diamond Eye turbo back
Nicktane adapter with the BIG filter
33 Cooper STT Pro (E) rock lover windshield hater
EFI by ATP dsp5
4" Cognito Fox shocks
eddie nelson is offline
post #6 of 35 (permalink) Old 06-10-2011, 05:10 AM
Not all diesels are like that but Duramaxes are,its the clutch in the fan staying locked up.Its part of the warm up cycle and stops in a fue minutes.
jmac5058 is offline
post #7 of 35 (permalink) Old 06-10-2011, 07:03 AM
I was told the transmissions whine a little until they get the fluid moving and warmed up. Mine whines for a few minutes until I get into 4-5th gear and the rpm's drop then its quiet for the rest of the day until its cold again in the morning
2008 2500HD LTZ, EFI Live- Idaho Rob's Tunes, 4" Magnaflow Turbo Back, Raptor 150 Lift Pump, Transgo Jr, All Season Diesel EGR delete with high flow Y-bridge, Edge Insight for gauges,
ironman_gq is offline
post #8 of 35 (permalink) Old 06-10-2011, 07:56 AM
On mine, the clutch fan frequently makes a lot of noise on a cold start. This is normal. But on mine, it is not a whine. It is more like a lot of lower frequency fan type noise.
I suspect that one of your idler pulleys is going bad. It will whine like that for a few thousand miles, maybe even 10K miles, and then it may lock up or come right off. When it is doing this it is causing excessive wear on the belt. However, maybe the belt will fail first.
Also, if it is a squeal/squeak more than a whine, the belt itself could be bad as the back of the belt slips over a cold pulley. The belt back could be glazed. But then you got to ask yourself how long is that pulley's bearing actually going to last, too. I'd be looking at the belt and pulleys, unless you clearly just have a lot of fan noise.
For testing, you could add a small bit of belt dressing to the back of the belt and see if the noise disappears. Then try a dab of dressing on the ID of the belt. If used sparingly and on the belt one side at a time, often you can tell which pulley bearing is suspect. If the noise noise is still there after testing both sides of the belt, you may have two bad pulley bearings.
Using the belt dressing momentarily takes the belt surface out of the loop for testing. However, it is not a good long term fix.
'09 2500 Z-71 HD, Wyoming Edition
'06 Desert Fox TH
'53 Cranky Ex-Spouse
N8AGS
Len Todd is offline
post #9 of 35 (permalink) Old 06-10-2011, 08:03 AM
Banned
Switch your serpentine belt to a GATORBACK from goodyaer and it will stop. Duramax's are know for excessive belt squeal. Mine sounded like a bad idler pully too and it was just a squeaky belt. The best place to find them is ROCKAUTO, they are 30 bucks I think.
smokinlmm is offline
post #10 of 35 (permalink) Old 06-10-2011, 08:24 AM
eastex's Avatar
Yeah, mine does it. I think it's a turbo noise.
When I picked up the truck brand new, I drove it a few blocks and turned around and went back to the service manager. He drove it, said it was normal. I told him I had owned an LBZ for four years and never heard that.
He said the LMM's make that noise, don't worry about it. So, I don't. If it's not normal, it'll fail in warranty...............I hope.
I know what the fan sounds like and it's not that. It's more of a high pitched whine. It only makes the noise under load and when accelerating. It doesn't have to be a heavy load.
2010 Chevy Dually D/A
If a man in the forest makes a statement, and there's no woman around to hear him, is he still wrong?
eastex is online now
