what are my next few upgrades - Chevy and GMC Duramax Diesel Forum
07.5-10 LMM Performance Parts Discussion Discussion of Performance Parts For the 2007.5 to 2010 LMM Duramax Trucks No Advertising
post #1 of 11 (permalink) Old 11-29-2012, 01:10 AM Thread Starter
what should I think about planning this winter?
07.5 Duramax LMM
RC/LB
leveling kit 2" blocks
3"dp
4" straight pipe behind cab dump
dpf delete
Quadzilla Stealth II
FASS 150
longbox66 is offline
post #2 of 11 (permalink) Old 11-29-2012, 01:23 AM
Corn Fed D-Max's Avatar
egr block/delete, PCV reroute, EFI
2003 Chevy 2500 HD CCSB.
K&N Cold Air Intake, Bills Custom Intake Turbo Horn, 4 inch MBRP straight exhaust with 6 inch tip, pre tuned ECM by creatures of the night performance. SOLD!
2009 GMC 2500 HD CCSB.
Stock for now
Corn Fed D-Max is offline
post #3 of 11 (permalink) Old 11-29-2012, 02:09 AM Thread Starter
besides those, up pipe for intercooler? left side exhaust manifold? TC?
I hear of alot of ppl who still have their stock trannys going strong with big hp..
I'll build if when it fails I figure..
07.5 Duramax LMM
RC/LB
3"dp
dpf delete
FASS 150
post #4 of 11 (permalink) Old 11-29-2012, 03:03 AM
Ask one to be one
usafracer's Avatar
Lift pump.
Marty
2010 GMC Sierra CC SB 4X4 Cognito 6" lift and 315/70/17 ATP Tuned!!
2008 GMC Sierra Crew Cab 4X4 (wifes) Zone lift set close to 4" 305/70/17's Hankook Dyna Pro RF-10 ATM
usafracer is offline
post #5 of 11 (permalink) Old 11-29-2012, 03:51 AM
Originally Posted by usafracer View Post
Lift pump.
He's already got a FASS 150? Maybe upgrade tierods and pitman/idler arms + braces since you're leveled? But I second the EGR delete/block and EFI.
What do you mean up pipe for intercooler? And I believe the driver's side exhaust manifold on your truck is the one that doesn't have the bend for steering so it should be fine.
05 LLY
EFI Live
Built Trans
Built Front End
Supporting Mods
andy-stevenson is offline
post #6 of 11 (permalink) Old 11-29-2012, 03:55 AM
Ask one to be one
usafracer's Avatar
Well I'll be I guess I should have kept reading.
Marty
post #7 of 11 (permalink) Old 11-29-2012, 04:02 AM
LsUtIGeRs's Avatar
I think the lml are the one with out the bend in the manifold, I would def do the egr delete, efi, tie rods
Mike
LBZ|6"|Toyo MT|Fuel Mavericks
Custom Pearl Paint
S&B CAI|5" MBRP Exhaust|BD Power Pup|PPE Shim Kit|Profab EGR Delete|Profab DP|LML Manifold|PCV Re-route|Cobalt Boost & Pyro
Bilstein 5100 & Stabilizer|Krypto Tie Rods|Moog Pitman|Idler Arms|Krypto UCA
Mag Hytec Diff Cover
LsUtIGeRs is offline
post #8 of 11 (permalink) Old 11-29-2012, 04:42 AM
Ya, you're correct.
05 LLY
EFI Live
Built Trans
Built Front End
Supporting Mods
post #9 of 11 (permalink) Old 11-29-2012, 12:52 PM Thread Starter
I already have blocker plate.
I'm talking about the hot side of the intercooler pipe.
And does the driver side manifold do much?
Efi is on Xmas list.
Does the pcv Reroute kit Do much?
07.5 Duramax LMM
RC/LB
3"dp
dpf delete
FASS 150
post #10 of 11 (permalink) Old 11-29-2012, 12:57 PM
PCV reroute keeps oil residue from going through your intake, intercooler, etc.
Auston KCCO
2014 EX-L V6 Accord Coupe White
2013 Ducati Hypermotard SP Ducati Corse livery
2009 GMC D/A CC/SB 4x4 SLT 41,xxx mi. Sold
DuramaxxedLMM is offline
