Turbo help!!!! - Page 2 - Chevy and GMC Duramax Diesel Forum
07.5-10 LMM Performance Parts Discussion Discussion of Performance Parts For the 2007.5 to 2010 LMM Duramax Trucks No Advertising
post #11 of 16 (permalink) Old 12-03-2012, 09:01 PM
3521 USMC
chevylovinfordtech's Avatar
Just look at it and you will see the diffrence if it is, gm put the dent there to clear the steering shaft but it isn't needed
-Robert-
2005 CCSB Silverado 2500 HD LLY
Performance: LBZ Mac performance intake, LBZ mouthpiece, MBRP duals, shim kit, ported fuel rail fittings, headstuds, FASS150, FASS fuel filter delete bowl, LBZ FPR, EFI live by Idaho Rob
Air Flow:finger vanes, ported turbine housing, BatMoWheel, losend unison ring, ported exhaust manifolds, gasket matched up-pipes
Exterior: Rear Reunel bumper, leveled tow mirrors, HIDs (all on mod), ADP tie-rod sleeves, green tinted headlamp housings
Interior: 2 12" memphis car audio subs, custom sealed box and 2000 watt memphis amp, LED interior, dash and door lights-green, cobalt autometer pyro and boost piller gauges
Best Time: 13.92 @ 95 mph 1.96 60 foot
Work In Progress: 1969 Chevy Nova, built turbo 350, 283ci small block est. 550hp with 7500 rpm redline, caltracs, 4.11 ford 9" rear end, dual 3"exhaust
chevylovinfordtech is offline
post #12 of 16 (permalink) Old 12-09-2012, 09:53 PM
KB3MMX's Avatar
Originally Posted by duramaxtow View Post
And really I should do the manifold on the lmm? I have done the down pipe as well as the Pvc Reroute And this week I am doing inline lift pump the holly black, I am doing the tranny I the new year I guess I sould do the twins and do the tow flows.
If you do twins, doing both manifolds and up pipes is a good idea for flow.
Si Vis Pacem, Para bellum !!!!
07' Chevy Silverado HD
--CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod)
--EFILive by KB3MMX Tuning W/ SDP Towing Twins (Billet S475 over Stock)
--SILVERLINE 4" Stainless Exhaust
--AMSOIL Synthetics and filtration bumper to bumper, including Bypass
--DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs
--PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes
--Danville 3" Y Bridge and big air intake kit / EGR delete
--Airdog II DF200 w/ CAT UHE filter upgrade...etc,etc...
KB3MMX is offline
post #13 of 16 (permalink) Old 12-09-2012, 09:57 PM
3521 USMC
x2 on this
-Robert-
post #14 of 16 (permalink) Old 12-09-2012, 10:34 PM
nvrplzd's Avatar
the LMM has the restricted drivers side manifold as well.. wasn't fixed until the LML series
and i'd go with the twins for towing heavily. Just my opinion however
Tyler-
2007.5 3500HD SRW Just your run of the mill 1-ton
Borg Warner, Wehrli Custom Fab, PPEI, DPC, PPE, Airdog, Cognito.. just to name a few.
2004.5 LLY Ext Cab 8' ~EFI, Fabtech 6" and much, much more.. SOLD
nvrplzd is offline
post #15 of 16 (permalink) Old 12-10-2012, 08:02 AM
Buy a LML drivers side manifold, Its actually cheap from the dealer, a lot cheaper than aftermarket ones
2008 2500HD LTZ, EFI Live- Idaho Rob's Tunes, 4" Magnaflow Turbo Back, Raptor 150 Lift Pump, Transgo Jr, All Season Diesel EGR delete with high flow Y-bridge, Edge Insight for gauges,
ironman_gq is offline
post #16 of 16 (permalink) Old 12-10-2012, 08:07 AM
Its just a worktruck
DMAXchris's Avatar
The modded VVT is gonna suck for towing. The EGTs will be higher and the turbo brake sucks. Skip the modded VVT and get a set of compounds from SDP. You & your truck will be very happy. Manifolds and up pipes will do nothing for you. There are 1000+ HP race trucks running OEM manifolds.
06 LBZ EC/LB 4x4
Built Motor/Trans • Bullseye s475/87/.9 • 45% Injectors • Stock CP3 • Built and Tuned by Blackout Performance • 11.76 @ 115
DMAXchris is offline
