Should I block my egr? - Chevy and GMC Duramax Diesel Forum
07.5-10 LMM Performance Parts Discussion Discussion of Performance Parts For the 2007.5 to 2010 LMM Duramax Trucks No Advertising
post #1 of 69 (permalink) Old 01-11-2010, 10:15 AM Thread Starter
Duramax09's Avatar
I was wondering if I should block my egr. I now have EFI in my truck and was thinking about doing it but I hear its such a pain in the a** lol. If anyone has an input it would be greatly appreciated.
Thanks,
Blake
2015 GMC 2500HD All Terrain
Duramax09 is offline
post #2 of 69 (permalink) Old 01-11-2010, 10:16 AM
NewEST Spinny Thinggg
seth999's Avatar
Yes........
06' CHEVY 2500HD CCSB PULLER/DD
Danville Billet S475
SoCal Stg.2 Heads
SoCal Cam
Mahle Forged Pistons .040 ovr
Hamilton Rods
Floor it pump
Dipper sticks
ATS Trans/CoPilot/TC
Other Stuff...
seth999 is offline
post #3 of 69 (permalink) Old 01-11-2010, 10:17 AM
DuramaxSMOKE11's Avatar
Send a message via AIM to DuramaxSMOKE11
X2 on that. i would deff do that. lower EGT's
Mike
2005 Chevy 2500HD Duramax LLY
BANKS ram air intake, MBRP 4" exhaust, CAT DELETE and NO MUFFLER, EGR Deleted, Fisher SS ExtremeV plow, Auto Meter Gauges, Boost, Pyro, Fuel Pressure, turbo resenator blocked off, PCV Reroute. SoCal Stage 1 heads, ARP Studs, BD Manifold, diamond eye down pipe, AFE mouth piece, AFE intercooler pipes, KMC Rokstars 20" wheels with Nitto Terra Grappler AT
EFI LIVE TUNED BY NICK
Big thanks to chad at Alligator performancewww.alligatorperformance.com
DuramaxSMOKE11 is offline
post #4 of 69 (permalink) Old 01-11-2010, 10:17 AM Thread Starter
Duramax09's Avatar
Did you do yours by yourself?
post #5 of 69 (permalink) Old 01-11-2010, 10:18 AM
Sweet Revelation
Ninja Ninja's Avatar
sounds like seth had fun doing his
Jason
- 08 Silverado LTZ, LMM
- 89 Trans Am GTA, L98
Ninja Ninja is offline
post #6 of 69 (permalink) Old 01-11-2010, 10:21 AM
JaxDuramax's Avatar
It's definitetly healthier for your truck not to have sooty exhaust being released into your intake tract. You can turn it off with EFILive, but high manifold pressures will force the valve open. The blocker plate is a good way to know that no exhaust/soot is making its way back into your engine.
06 CC/SB 4x4 LBZ
http://www.huskerdiesel.com/
JaxDuramax is offline
post #7 of 69 (permalink) Old 01-11-2010, 10:37 AM
yes i did. i deleted it tho. i took the EGR cooler off and got a LB7 up pipe and i eleminated the EGR manifold with the valve in it
Mike
post #8 of 69 (permalink) Old 01-11-2010, 11:01 AM
Its just a worktruck
DMAXchris's Avatar
100% Yes!!!!
06 LBZ EC/LB 4x4
Built Motor/Trans • Bullseye s475/87/.9 • 45% Injectors • Stock CP3 • Built and Tuned by Blackout Performance • 11.76 @ 115
DMAXchris is offline
post #9 of 69 (permalink) Old 01-11-2010, 02:01 PM
D_R_C's Avatar
"My opinion"
The EGR basically has 2 functions, good and bad.
#1 When it opens it helps relieve head pressure, this is "good"
#2 Also when it opens it re-circulates exhaust thru the intake.
This is good for the environment but NOT so good for the engine.
In my opinion if you wanted to block the egr you should also consider opening up the exhaust from the exhaust port on the head to the tailpipe.
And install studs for the heads.
By just going with bigger exhaust from the downpipe-tailpipe, I don`t feel there is enough to relieve the head pressure when your just blocking the egr.
Sure you add big exhaust, but if you still have the stock exhaust manifolds,Y-pipe and stock downpipe there could be more head pressure built-up and cause possible bigger issues in the future.
The downpipe chokes down small which does not let enough exhaust pressure that has built up get out quick enough.
Several that add big power and have a lead foot, a blocked egr, find out eventually they need to install studs for the heads.
I feel if you just do the PCV re-route and forget worrying about whether to block the egr or not.
The PCV is very friendly to the environment but very nasty to the complete intake system.
By re-routing the PCV you will have a remarkable cleaner burning engine and exhaust, and leave the egr alone you won`t have the possible issue of to much head pressure.
I have a block-off plate that has been setting next to my computer monitor for 1 1/2 years. I feel unless I end up having actual egr issues that is where the block plate will stay.
I would not bother unless in the future you have a egr issue, then worry about it..
2007.5 GMC Sierra 3500 SRW "BLACK", SLT, C.C., 4X4, Loaded, DMax,Z71
Edge Insight CTS2, CFM Billet Valve Cover/Oil Fill Neck Breather, PCV Re-Route, Sinister EGR Delete, AirDog, ISSPRO fuel pressure gauge, BD Manifold, Diamond Eye down pipe & front pipe, 5" DPF(less)back exhaust with 6" tip, DIY Stock airbox mod with aFe Proguard 7 airfilter, Cognito NON Torsion Bar 4" lift, Cognito UCA's, Pitman/Idler arm support, Sulastic Rubber Shackles, Firestone Ride Rite, Bilsteins 5100's front/rear
EFILive ECM tuned by ATP www.atptrucks.com
TCM
tuned by www.duramaxtuner.com
DIY stock AirBox Mod, K&N, Airaid intake, EFILive TCM only by MJE Tuning
D_R_C is offline
post #10 of 69 (permalink) Old 01-11-2010, 02:10 PM
Chevyguy08's Avatar
yes block your egr, keep your intake and engine free from the black nasty oil build up
08 LMM is alive and well again with a few add ons
2011 3500 Denali
2011 2500HD LTZ
2011 1500 LTZ
Chevyguy08 is offline
