help with dpf - Chevy and GMC Duramax Diesel Forum
07.5-10 LMM Performance Parts Discussion Discussion of Performance Parts For the 2007.5 to 2010 LMM Duramax Trucks No Advertising
post #1 of 5 (permalink) Old 05-09-2010, 09:28 PM Thread Starter
truck004's Avatar
help with dpf
i took off my dpf and put 4in stright pipe on used a PPE trurner and and my check engine light is on and i cant clear it and there codes 0546 and 3033 and my remote start wont work now to help please
my truck is 7.5 2500HD
truck004 is offline
post #2 of 5 (permalink) Old 05-10-2010, 08:29 AM
D_R_C's Avatar
Does the PPE tuner have the dpf delete.
It has been a while, but if I remember correctly you have to have the PPE race tuner to be able to delete the dpf without having codes.
Your remote start will not work if there is any check engine light/codes.
2007.5 GMC Sierra 3500 SRW "BLACK", SLT, C.C., 4X4, Loaded, DMax,Z71
Edge Insight CTS2, CFM Billet Valve Cover/Oil Fill Neck Breather, PCV Re-Route, Sinister EGR Delete, AirDog, ISSPRO fuel pressure gauge, BD Manifold, Diamond Eye down pipe & front pipe, 5" DPF(less)back exhaust with 6" tip, DIY Stock airbox mod with aFe Proguard 7 airfilter, Cognito NON Torsion Bar 4" lift, Cognito UCA's, Pitman/Idler arm support, Sulastic Rubber Shackles, Firestone Ride Rite, Bilsteins 5100's front/rear
EFILive ECM tuned by ATP www.atptrucks.com
TCM
tuned by www.duramaxtuner.com
DIY stock AirBox Mod, K&N, Airaid intake, EFILive TCM only by MJE Tuning
D_R_C is offline
post #3 of 5 (permalink) Old 05-10-2010, 01:02 PM Thread Starter
truck004's Avatar
It said when I got the tuner that it had the dpf delet with it I got one of the codes to go away by putting a glove over the sensor thank ill call ppe and see if that's what it is
truck004 is offline
post #4 of 5 (permalink) Old 05-10-2010, 05:49 PM
D_R_C's Avatar
I left the sensors and wire on the dpf pipe and used some large heat shrink folded one end and sealed the ends with heat.
Slided the opened end over the sensor plug on the truck then lightly heated them up and then used a nylon tie to secure them, that way hopefully crap won`t get in and mess up the connections.
Good Luck !
TCM
D_R_C is offline
post #5 of 5 (permalink) Old 05-21-2010, 05:55 PM
youngone's Avatar
What a great idea then if you need them they will be nice and clean.
Youngone (Pat)
Black 2009 CCLB 1 Ton LMM 4X4
400 liter in box fuel and tool tank
Custom headache rack with lights and side box rails.:rockin
Stock as she came from GM.
I added
Recon Smoked Cab Lights.
Ring of Fire Tailgate lights and
Big Rig Ice Lights.
Alberta Beach (Edmonton) Alberta Canada
youngone is offline
