Stock no more !! - Chevy and GMC Duramax Diesel Forum
07.5-10 LMM Performance Parts Discussion Discussion of Performance Parts For the 2007.5 to 2010 LMM Duramax Trucks No Advertising
 2Likes
  • 2 Post By slickdmax
post #1 of 10 (permalink) Old 02-02-2017, 07:06 PM Thread Starter
slickdmax's Avatar
Stock no more !!
Well i figured i would start a thread on my truck, purchased this truck about a month ago, its a 2007 duramax lmm with 39000 miles. So far i have ordered sinister diesel egr delete got good deal for 100 bucks brand new, mbrp down pipe, pcv reroute, efi from atp with 5 position switch, rest of parts should be in wednesday, including 5 inch flo pro exhaust, s&b intake , and ash tray mount for the switch. I will be posting pics of my progress, just so excited to actually let the power loose on this baby, and get more than 11 mpg.
jo4450 and Paddlefish like this.
slickdmax is offline
post #2 of 10 (permalink) Old 02-02-2017, 07:18 PM
Woonie's Avatar
sounds good
2015 GMC Denali 2500HD 4x4
Xtreme Diesel EGR blocker plates, S&B intake, Flo-Pro exhaust, AirDog, EZ LYNX
Titan fuel tank, Kicker sound system, Ridge Grapplers, Bushwacker flares, Weather Tech, Carhartt seat covers, UWS tool box, Back Rack
Woonie is online now
post #3 of 10 (permalink) Old 02-03-2017, 10:38 PM
D_R_C's Avatar
$100 for the Sinister new , just make sure you don't have the first version or a cheap knock off claiming to be as good or equal to the Sinister, this has happened to a few.
When they first came out the up-pipe block support was made of a thinner metal, it didn't hold up very good causing the up-pipe to crack.
Mines been on about 3 1/2 years it was the revised newer version, which holds up very good, with no problems.
The worse case senaro would be having to shell out $$$ for a LB7 up-pipe or one that's been welded closed.
Any questions you could call Sinister and pick their brain on what you have.
"Good Luck"
2007.5 GMC Sierra 3500 SRW "BLACK", SLT, C.C., 4X4, Loaded, DMax,Z71
Edge Insight CTS2, CFM Billet Valve Cover/Oil Fill Neck Breather, PCV Re-Route, Sinister EGR Delete, AirDog, ISSPRO fuel pressure gauge, BD Manifold, Diamond Eye down pipe & front pipe, 5" DPF(less)back exhaust with 6" tip, DIY Stock airbox mod with aFe Proguard 7 airfilter, Cognito NON Torsion Bar 4" lift, Cognito UCA's, Pitman/Idler arm support, Sulastic Rubber Shackles, Firestone Ride Rite, Bilsteins 5100's front/rear
EFILive ECM tuned by ATP www.atptrucks.com
TCM
tuned by www.duramaxtuner.com
DIY stock AirBox Mod, K&N, Airaid intake, EFILive TCM only by MJE Tuning
D_R_C is offline
post #4 of 10 (permalink) Old 02-04-2017, 12:49 AM
DuramaxForum Guru
HD Dmax Machine's Avatar
HD Dmax Machine is offline
post #5 of 10 (permalink) Old 02-04-2017, 07:33 PM Thread Starter
slickdmax's Avatar
Yeah I figure I would use sinisters kit and see how well it worked , if I have issue I will do the lb7 up pipe .The guy I got it off of was on eBay and he only opened the box and everything has sinister name on it and the deal was too good to pass up, I almost bought the knock off stuff but heard a lot of bad things about them
post #6 of 10 (permalink) Old 02-04-2017, 08:26 PM
D_R_C's Avatar
I like mine especially retaining the grid heater and stock look.
Once you get the kit I suggest calling Sinister to verify which block plate you have.
If it's the newer thicker version you should be good, if it's the thinner one you might just consider getting the LB7 up-pipe to install right off the bat.
TCM
D_R_C is offline
post #7 of 10 (permalink) Old 02-05-2017, 07:07 AM Thread Starter
slickdmax's Avatar
I think I have the newest version since the part number is the same as on their site , I didn't measure the plate but it seems like its aprx 1/2 inch
post #8 of 10 (permalink) Old 02-05-2017, 07:16 AM
D_R_C's Avatar
The part number didn't change, but a good answer is just one phone call away.
TCM
D_R_C is offline
post #9 of 10 (permalink) Old 02-09-2017, 07:06 AM Thread Starter
slickdmax's Avatar
So over the past few days, I got the exhaust , down pipe, egr delete, intake done on my truck and all I can say is WOW!!!!!!. Truck will spin the tires in the eco tune with 1/4 throttle if I do it too quickly. whole different animal compared to my old 12 valve I had just sold. Thanks so much to ATP diesel for the efi live and the great deal I got. The directions were very straight forward and very detailed. BEST DIECISION BY FAR .! I will try to post pictures later. Now I need to figure out what I want to do next
post #10 of 10 (permalink) Old 02-09-2017, 07:44 AM
John6363's Avatar
Trans so you can put the power to the ground.
Jaime S.
06 RCLB 4x4
EFI live
Built trans
30% sticks
68mm stg2r
Supporting mods
Top end rebuild at 90k
Hot blonde driven and maintained
Wondering when the bottom end will blow
John6363 is offline
