2010 Duramax no crank no start - Chevy and GMC Duramax Diesel Forum
07.5-2010 LMM Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission, Etc.
post #1 of 20 (permalink) Old 10-21-2011, 10:11 AM Thread Starter
Ok, I have a 2010 chevy buswith a6.6 duramx diesel. The problem happens out of nowhere. If you shut the bus off and leave come back to start it it wont crank at all. No codes are stored starter is new and everything checks out! Any ideas?? It starts after a while again then it happens again
duramax0323 is offline
post #2 of 20 (permalink) Old 10-21-2011, 10:14 AM
Super Moderator
jc1843's Avatar
Of course with any start problem-- check the batteries-- They are wired in parrallel so you need to isolate one to test them.
Be sure all the connections are tight and clean.
Chevy 04.5 LLY, 2X, shell, XDR, MikeL Heavy duty up-grade, 6spd, TransGo, deep pan, de-badged, 65 Gallon replacement Aero tank, LBZ-mp, Kennedy pump, shimmed, Pre-fuel filter, tow mirrors, BU cam, gauges, GPS, Sirius, bags, custom grille, fender vents, HD trans cooler- Curt front hitch, footwell lights, load lights, Studs, head gaskets.--- Jerry
jc1843 is offline
post #3 of 20 (permalink) Old 10-21-2011, 10:20 AM Thread Starter
Batteries are good! It starts fine when it does start .
post #4 of 20 (permalink) Old 10-21-2011, 10:36 AM
Super Moderator
jc1843's Avatar
I vagely remember there was a problem with the LMM not starting-- and GM had a re-flash for the system-- I searched for a TSB, and could not find anything. Might check with a dealer.
jc1843 is offline
post #5 of 20 (permalink) Old 10-21-2011, 10:41 AM Thread Starter
Hmmm thanks for th input ill try the dealer. This is driving me nuts!!
post #6 of 20 (permalink) Old 10-21-2011, 10:45 AM Thread Starter
We have three of these durmax in the fleet and this one keeps acting up. The other 40one are 6.0 foes diesel and well we all know they suck!
post #7 of 20 (permalink) Old 10-21-2011, 11:47 AM Thread Starter
So I pulled a code. U0168 LOST comm.with vehicle security module. Any ideas?
post #8 of 20 (permalink) Old 10-21-2011, 04:04 PM
Super Moderator
jc1843's Avatar
I think that is the code-- and what I was trying to remember-! I will check over at another place--
Here is a contact -- direct to GM Customer service-- they might be able to help.
http://www.duramaxforum.com/forum/me...erservice.html
jc1843 is offline
post #9 of 20 (permalink) Old 10-25-2011, 05:51 PM Thread Starter
If anyone else can chime in it would greatly help!
post #10 of 20 (permalink) Old 10-25-2011, 05:58 PM
Slave to the Interwebs
Johnasara's Avatar
Were are you at?
If it is losing communication with the Vehicle security module then it could be the IGN switch, or just something throwing the program loopy. Check all the fuses with an ohm meter or test light when it does it again. You could be losing connectivity when it is warm. Does the bus have an alarm on it or possibly a saftey switch that will disable it?
Johnasara is offline
