Duramax Scan Tool (Injector Flow Rate Updating) - Chevy and GMC Duramax Diesel Forum
07.5-2010 LMM Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission, Etc.
post #1 of 5 (permalink) Old 01-19-2012, 02:16 AM Thread Starter
I have been searching for a "Programmer", "Tuner", "OBD Code Reader" that will allow me to update my Injector flow-rates when I replace them. I keep reading about EFI-Live, but no-one has been able to confirm or deny if it will re-program flow-rates. I found another article that explains how to do it and that I need a "Scan Tool".
Copied from (w w w . thedieselgarage . c o m/forums/showthread.php?t=1072)
With a scan tool installed, enter the vehicle information and select the following options:
• Engine Control Module
• Module Setup
• Injector Flow Rate Programming
• Display ECM & GPCM Inj. Flow Rates
Record all flow rate numbers with the corresponding cylinders from the control modules. Important: When installing a new fuel injector, ensure that the IQA data number from the yellow IQA Data Tag, shipped with the new injector, is programmed to the correct cylinder
⇒ If any injectors are replaced, go to Reprogram Injector Flow Rates parameter and enter the flow rate number of the new injector to the corresponding cylinder. The flow rate numbers will automatically update both control modules.
⇒ If the ECM was replaced, go to Copy GPCM Inj. Flow Rates to ECM parameter and reprogram the ECM. This will update the ECM with the GPCM flow rate numbers.
⇒ If the GPCM was replaced or the flow rate numbers are not the same for both modules, go to Copy ECM Inj. Flow Rates to GPCM parameter and reprogram the GPCM. This will update the GPCM with the ECM flow rate numbers.
⇒ If both control modules were replaced, go to Reprogram Injector Flow Rates parameter and enter the previously recorded flow rate numbers or the numbers retrieved from each individual injector, to the corresponding cylinders.
Can anyone shed some light as to what "tool" I need to complete this?
2008 Chevy 2500HD 4X4 LT
ARE Snug-Top
Pro-Comp Shocks
9K Ramsey Winch and Mount
285/75/R-16 Goodyear MT/R W/Kevlar
K&N Air Filter
Stock Everything else!
165K and counting!
VZWTech is offline
post #2 of 5 (permalink) Old 01-19-2012, 11:18 AM
Sounds like you need a Tech II. Something your going to find at the dealership, no they wont sell you one
2008 2500HD LTZ, EFI Live- Idaho Rob's Tunes, 4" Magnaflow Turbo Back, Raptor 150 Lift Pump, Transgo Jr, All Season Diesel EGR delete with high flow Y-bridge, Edge Insight for gauges,
ironman_gq is offline
post #3 of 5 (permalink) Old 01-19-2012, 11:30 AM
1GTurn's Avatar
Oh GM will sell you one for the right price.
2013 2500HD 4DR 4x4
1GTurn is offline
post #4 of 5 (permalink) Old 01-19-2012, 11:48 AM
Do work!
GMguy's Avatar
You can get a tech two from any Bosch dealer. I got one from napa a few months ago brand new
Autoguide
GMguy is offline
post #5 of 5 (permalink) Old 01-28-2012, 07:06 PM
Autoguide
Wow, what did that set you back?
MTL_Dmax is offline
