4" vs 5".. is there really a difference. - Page 7 - Chevy and GMC Duramax Diesel Forum
07.5-2010 LMM Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect
Old 01-07-2013, 10:22 PM   eBay Motors  #61 (permalink)
daword2011's Avatar
I think Chevy has the quietest and smoothest running engine out there. Hell my 01 has a quieter engine noise then some of the newer fords. I always love when ppl ask why diesels make noise under the hood, I always just say you can't expect 26,000 psi to be quiet haha
-Austin- Fightin' Texas Aggie
2001 LB7 2500HD CC/SB 2WD
5" Flo~Pro Straight w/ 7" Tip| ProFab Intake Horn |Spectre Stage-2 CAI | EFI Live w/ DSP-5 | PPE Stage IV Transmission | ProFab Downpipe | PPE Boost Valve | Holley Black Lift Pump | Intake Heater Delete | GlowShift Guages (Boost, Pyro, & Fuel Pressure) | 3" Drop Shackles | 18x9 Falken ORC 952's | Nitto Terra Grapplers 285/65/r18 | Kenwood Deck | 2 12" Kenwood Subs on 2200watts | 4 6-1/2" Pioneers (Doors) on 350watts | JML 6000k HID Lo-Hi/Fog | Herculiner Bedliner | Westin Side Steps | Ranch Hand Full Front and Rear Bumper Replacement.
546hp & 1025 ft/lbs at Lone Star Dyno, Spring Branch Tx.
daword2011 is offline   Reply With Quote
Old 01-07-2013, 10:39 PM   eBay Motors  #62 (permalink)
KentCountyCoal's Avatar
I love my 5" MBRP straight pipe. Its all a matter of personal preference and money. Not gunna notice a huge difference. Im happy with my 5, but if u own an LLY theres not a lot of space between your spare and the rear shock... I just dropped mine.
Sounds awesome and looks even better billowing black smoke.
2005 ECSB LLY
EFI Live
4094 AVNT
Big Dipper 1058
Edge Insight CTS
Air Dog II 165 GPH
PCV, EGR, PPE Ported
Blade Runner MP, 5" MBRP, AFE CAI
KentCountyCoal is offline   Reply With Quote
Old 01-09-2013, 07:52 AM   eBay Motors  #63 (permalink)
KC2GIW's Avatar
Originally Posted by CCPerformance.com View Post
Well in that case I guess we should forget about 4" & 5" and move on to 7, 8 or 9" pipes........ Apparently bigger is always better...... Really?
How many 4" stacks have you seen on a pickup?
Bigger may not be better, but its also not worse.
It's all about image, baby...and sound. WRT to sound, there IS a difference. Love my 5"
(And so does yo mama)
2007.5 GMC 2500 HD. XC/SB. Edge CTS, MBRP 5", leveled.
2002 Z06. 520/500 hp/tq @ wheels.
2009 VRSC DX. Screamin' Eagle "race" cams, Dyno tuned, TAB exhaust, etc. 130 hp @ wheel.
2007 F8 Sno Pro. Now in 1000 tiny little pieces in the woods. That was fun.
facebook.com/matthew.antonio
KC2GIW is offline   Reply With Quote
Old 01-09-2013, 08:44 AM   eBay Motors  #64 (permalink)
boostnlb7's Avatar
Some more input, its common on almost every engine that the quicker u get air in and the quicker u can get rid of it, the better it will run.. I like to open my exhaust right up to its most free flowing potential, also lowers egt's, which we all want.. So IMO 5".. I dont like anything being restricted, as is the lb7 downpipe. Of a guy was going for sound, the that would be totally up to u... If a 5" sounded shitty but flows better than a 4, then ill take it
couldnt pass hazing to be a "pup bro"
03 lb7 ccsb 4x4-6" bds- 20"mkw's- p195/65/14 intercos-
auto meter boost/pyro/trans gauges- traction bars- 5'' DE straight pipe- PPE BIV- AD II 200 lift pump- edge insight CTS- spectre CAI- 45% over injectors- LMM cp3 & FPR -EFI live dsp5 flashed by tony burkhard with danville tunes- thanks to Brent @ Lincoln Diesel
boostnlb7 is offline   Reply With Quote
Old 01-09-2013, 09:05 AM   eBay Motors  #65 (permalink)
Cknight199's Avatar
What? There's no performance difference between 4" and 5". And 5" sounds better IMO, but it drones too bad in the cab. You will get better performance removing a cat off a 4" than replacing it with a 5". ImageUploadedByAutoguide1357751148.523829.jpg
2006 LBZ CCLB DRW
Suncoast Trans w/ 1056
Billet Garrett 4094
BTLockup Box
Built Front End
Some More Stuff
EFI Live by Starlite Diesel
Fastest 1/4 yet: 13.606 (fourth time down the track)
Cknight199 is online now   Reply With Quote
Old 01-09-2013, 09:24 AM   eBay Motors  #66 (permalink)
Cmart1989's Avatar
Size is not going to matter with performance...
I have 4" DP back and I am not really satisfied with the noise level. A buddy of mine as the EXACT same set up to the T and his is twice as loud.
I will be moving up to a 4" in the very very near future.
2006.5 CC/SB LBZ
EFI Live DSP5
PCV Reroute & EGR Blocker Plate
Edge Insight CTS w/ EGT Probe
4" MBRP Exhaust Turbo Back w/ 5" Rolled Tip
Resonater Plug
Transgo Jr.
Pump Rub Fix
High Beam All on Mod
Tie Rod Sleeves
More to Come....!!!
Cmart1989 is offline   Reply With Quote
Old 01-09-2013, 09:49 AM   eBay Motors  #67 (permalink)
Cknight199's Avatar
Huh? Do you have the same truck as him? Your going to move from a 4" to a 4"?
2006 LBZ CCLB DRW
Billet Garrett 4094
BTLockup Box
Built Front End
Some More Stuff
Old 01-11-2013, 07:25 AM   eBay Motors  #68 (permalink)
Cmart1989's Avatar
Typo my bad...
I meant to say from a 4" to a 5"..
Yes 9 have a 06 lbz he has an 07 lbz classic... the exaust were bought from the exact same place.. part # everything...
The ONLY difference is the tip... I have a rolled tip and he has a mbrp tip... (straight edged i guess hard to explain)
The angle it comes out behind the tire is pretty much the same no huge difference..
I dont know exactly why.. I have looked on here numerous times trying to find an answer with no results... any ideas..
I apologize if I derailed the thread.. I can make a new one if it bothers anyone..
CKnight199.. any ideas??
2006.5 CC/SB LBZ
EFI Live DSP5
Resonater Plug
Transgo Jr.
Pump Rub Fix
Tie Rod Sleeves
More to Come....!!!
Old 01-11-2013, 07:34 AM   eBay Motors  #69 (permalink)
Cknight199's Avatar
Typo my bad...
It could be simple as tuning... Does your hiss at idle or is it a rumble?
2006 LBZ CCLB DRW
Billet Garrett 4094
BTLockup Box
Built Front End
Some More Stuff
Old 01-11-2013, 07:46 AM   eBay Motors  #70 (permalink)
smacker86's Avatar
..are you stock tuned still? what about him?
2001 chevy 4x4 Regular Cab LB7...5inch exhaust(not MBRP!!) Profab intake horn and downpipe,Rare parts tie rods,Cognito Braces,Coolant filter,Nicktane,Airdog100,Pump rub fixed.diy high idle mod.Rear Airbags..................R.I.P.-2006 Chevy 2500 4x4.Regular Cab 4x4 LBZ
smacker86 is offline   Reply With Quote
