Shift range inhibited on cold starts. - Chevy and GMC Duramax Diesel Forum
07.5-2010 LMM Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect
Old 12-21-2012, 07:23 PM   eBay Motors  #1 (permalink)
Unhappy Shift range inhibited on cold starts.
In the last couple of weeks when below -15c after cold starting my truck the voltage is around 9-10 volts for a couple of min. Then returns to 14v but in this time the check engine light comes on and says shift range inhibited on the dash. After clearing code p0751 truck drops into gear and drives normally. I have already had the truck to the dealership $700 later and same problem. And this morning my dash was saying service charging system on cold start but went away after warming up and is still locking out the trans. They tested a both batteries and cleaned and checked all connections. And reflashed TCM. I really dont want to take it back to the stealership...
2008 Chevy Silverado LTZ Crew Cab 4x4 Z71. 4'' Turbo Back Straight pipe. PPE Standard Tune 3
Scooner is offline   Reply With Quote
Old 12-21-2012, 07:45 PM   eBay Motors  #2 (permalink)
Spoolin' Up
Hibneck1's Avatar
Im not sure why it would have the check engine light but the allison does have a shift range inhibitor to help with warm up in real cold weather... Just one more reason I love this trans! http://www.allisontransmission.com/s...t=SA3931EN.pdf
2006 Chevy 2500HD Duramax Allison ECLB
Mods: Cognito 4"-6" with hd sway bar, ballistic jester camo 17x9 rims with 315/70 R17 Treadwright Guard Dog M/T's, Fabtech tie rods, Pitman and dler arm support kit, pump rub kit, 5000k 55w HIDs in high, lows, 4300k 55w in fogs, all on mod, PPE Air box mod, blocked and stuck, PCV re-route and resonator kit, 5" Diamond Eye Turbo back with 7" tip, raptor liner from body line down and holding up perfect!
Hibneck1 is offline   Reply With Quote
Old 12-21-2012, 07:45 PM   eBay Motors  #3 (permalink)
TBone's Avatar
I think the shift range inhibit is temp induced, once the tranny warms up it should be fine. If you have your book that came with it read about the allison....I think its to prevent overpressureizing the trans when fluid temps are below a certain temp..
Now I see the other post I remember, I'm wrong.
2008 CC SB 4X4 LTZ
6" ProComp lift
20" ProComp wheels
35" Xtreame A/T's
4" Iron Cross step bars
TBone is offline   Reply With Quote
Old 12-21-2012, 08:02 PM   eBay Motors  #4 (permalink)
It will still say shift range inhibited after running on high idle of 1200rmp for 15min. And trans temp of over 25 celcius. It will only drive after clearing codes.
Old 12-25-2012, 03:47 PM   eBay Motors  #5 (permalink)
KB3MMX's Avatar
If your batteries are dropping that low, it needs new ones regardless of what the dealer says. It's going to have reduced voltage until the intake grid heater shuts off but if the batteries are weak, it'll be real low.
The transmission will also limit it's operation in cold weather until it's warm enough to prevent damage from lack of oil flow.
Also, going to synthetic engine oil will reduce electrical strain when cranking and improve flow in the winter. Synthetic Allison Transynd ATF would also be a good upgrade...
Ham Radio= Global communications without airtime fees
My Antenna-SteppIR
Si Vis Pacem, Para bellum !!!!
07' Chevy Silverado HD --CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod)
--EFILive tuning by ...ME with 68MM 4094VA Garrett Powermax Stage 2 Turbo
--SILVERLINE 4" Stainless Exhaust, Modded stock Airbox and LIBERATOR Stainless Downpipe
--AMSOIL Synthetics and filtration bumper to bumper, including Bypass
--DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs
--PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes
--Danville 3" Y Bridge and big air intake kit / EGR delete
KB3MMX is offline   Reply With Quote
