Dpf help - Chevy and GMC Duramax Diesel Forum
07.5-2010 LMM Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect
Old 12-29-2012, 03:37 PM   eBay Motors  #1 (permalink)
Dpf help
Hello everyone.
I have read through this forum for some time but first time poster. I am still undecided about deleting my dpf. So right now I am just trying to figure if there is a way to clean it out? ( besides the owners manual drive and let it regenerate) I commute to work 1000km every week and on my last two trips I. Got the clean exhaust filter message on my dic. I have been doing this trip for over a year now, every week and normally the truck will regen once per trip. But these last two trips have been ridiculous for fuel mileage and I have been getting this message. Any suggestions? I have been running the same fuel from same place. The only changes was before the first time I had just added some fuel injector cleaner . And during my last fuel filter change ( which was just before my first trip with the message) I found or maybe I broke a wire on the water in fuel sensor on the bottom of the filter and have not picked up a new sensor yet.
2008 lmm ccsb 4x4 z71
Mostly stock except for banks ram air intake
737ame is offline   Reply With Quote
Old 12-29-2012, 03:43 PM   eBay Motors  #2 (permalink)
anthonyshaw's Avatar
From what I've read elsewhere, you're going to need a dealer to service the DPF, or replace it.
My personal recommendation would be to just delete it and pick up the mileage gain. I gained 5mpg easily while still romping on it because of the exhaust tone. I ended up deleting from the downpipe back and replacing with a 4" MBRP no muffler exhaust, it was only a few bucks more than a delete pipe for the whole thing
'08 GMC Sierra SLT CCSB LMM
4" MBRP Downpipe-back, EFI-Live V2, DSP5 Switch, Tuning by Idaho-Rob, EGR Block-off
anthonyshaw is offline   Reply With Quote
Old 12-29-2012, 04:31 PM   eBay Motors  #3 (permalink)
lacroixd's Avatar
It is normal for the DpF to self clean, I think it's every 500 miles..you need to keep constant over 1500 rpm for 30 minutes to clean it.
I run some white diesel Kleen all the time in mine and seems to help somewhat with fuel mileage. Also tire size has an impact on fuel economy as well as try and keep it below 1700 RPM.
Hope it helps!
2007 Silverado LTZ
Black Stock 4 dr
33 Nitto trail grappler MTZ tires
lacroixd is offline   Reply With Quote
Old 12-29-2012, 04:42 PM   eBay Motors  #4 (permalink)
read this link and tell me you want to wait till 100k to do your mods.
http://www.amsoil.com/techservicesbu...l_Dilution.pdf
And I am not an amsoil guy but this was my thinking to why I did my mods way before warranty. Yes you take the chance a wheel bearing goes out ect within 100k but I am sure the engine will last that long then after the warranty is up and after 100k of this going on with possible increased wear you mod. I would take the chance and mod as soon as possible. I do not race my truck or abuse it. Every mod I have done to this truck is to improve on GM's truck. I made it better IMO not faster. I added an exhaust for EGT's fuel dilution ect. I added a lift pump not for big HP in the future but to save the injection system ect. I daily drive this truck and wash/wax every weekend. It is babied so bad it is scary. Yes the better exhaust sound is nice and the turbo whistle is cool but not the real resons I did these mods.
If you beat your truck daily do not mod as the chances of needing warranty repair is bigger but if you plan on taking care of it and keeping it for a long time start eliminating the BS government emmisions crap that is hurting your trucks longevity
2009 LMM 4 x 4 crew cab
John Kennedy 70 hp tow tune ecu
MBRB 4 " straight pipe with Magnaflow Down pipe.
Kennedy Twin lift pump with filter setup.
03 BUSA is offline   Reply With Quote
Old 12-29-2012, 05:03 PM   eBay Motors  #5 (permalink)
Husker Diesel Pimp
gr8shot's Avatar
Originally Posted by 737ame View Post
Hello everyone.
If you go into a dealer, and talk to one of the techs, they can do a forced regen with the Tech 2. Will this help? Maybe. Will you be able to convince them to do this? eh maybe. But its about the only thing you can do to try and improve the DPF performance. Just a piece of information for ya... GM will charge you close to $2000 for a new DPF if they deem it out of warranty for some reason. You can delete the DPF with a quadzilla tuner and 4" exhaust for a bit over $600, and will get quite a bit better fuel mileage as well.
Jesse Meyers | Husker Diesel | 402-502-6961
www.huskerdiesel.com | Email us!
We will gladly match any competitor's deal!
04 LB7: It's coming along, slowly
Old 12-29-2012, 05:03 PM   eBay Motors  #6 (permalink)
i am actually out of warranty anyways. Warranty is not the reasons for not dpf deleting yet. I am not at all into big horse power or rolling coal. I just want a dependable daily driver that has a great power train so when i need to tow my family travel trailer across the country ( 11,000 lbs) . I would love the fuel mileage gains but could really due with out any change in exhaust noise or dependability issues
Old 12-29-2012, 05:22 PM   eBay Motors  #7 (permalink)
Super Moderator
jc1843's Avatar
The WIF sensor at the base of the fuel filter rarely works as designed-- and if the wire is off, it will not trigger any codes, in fact the system will never know.
Old 12-29-2012, 05:48 PM   eBay Motors  #8 (permalink)
Dependable daily driver and tow rig with DPF is an oxymoron.
Old 12-29-2012, 06:41 PM   eBay Motors  #9 (permalink)
Kbaerg's Avatar
I would delete the dpf system get a 4" or 5" exhaust with downpipe, gauges, and great EFI Live tuning from ATP.
08 Silverado 2500HD LMM 4X4 CCSB
18" Wheels on Nitto Terra Grapplers
Tie rod Sleeves, Isspro EV2 Pyro and Boost
Adrenaline Truck Performance http://www.atptrucks.com
http://www.alligatorperformance.com
Kbaerg is offline   Reply With Quote
Old 12-29-2012, 08:04 PM   eBay Motors  #10 (permalink)
chevor's Avatar
I still have my DPF in place and average about 20mpg with a truck with over 454,000 miles. I think if you go to a Dealer they are gonna tell you to put back in the stock air filter. Its weird I ran into a similar problem with shorter miles between regens. The dealer blamed it on a K&N airfilter cause the MAF sensor to go scew. What makes it even weirder is I had that brand filter in the truck for over 300k miles. Put the stock air filter back in mile between regens went back up. Change back to the K&N back down. Stock back in back up. I do believe the LMM is programed to clean out the DPF every 400 miles reguardless of soot level.
chevor is offline   Reply With Quote
