Shift Inhibitor Message - Chevy and GMC Duramax Diesel Forum
07.5-2010 LMM Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect
Old 01-07-2008, 11:02 PM   eBay Motors  #1 (permalink)
With regard to the shift inhibitor message, has anyone experienced this..Tonight I did and i had to shift to neutral and then back to drive to correct.. Any idea of to whats this about?? Thanks
New Member First post
Textech21
textech21 is offline   Reply With Quote
Old 01-08-2008, 01:53 AM   eBay Motors  #2 (permalink)
i had this same message happen to me last week and i have no idea what it is either. i put it in reverse and it took me out of gear and popped up that message. anyone know?? its that first time its happened.
2003 Chevrolet CC/SB LB7
Homemade 5 inch "shorty" stack, Kennedy boost valve, Autometer Phantom II Boost and Pyro gauges, 35's on all black Ultra Goliaths, front end leveled, 2% tint, SD tierod sleeves, 2 Kicker CVT 10's w/ Sony amp, 10,000k HID headlights, blacked out taillights and brake light, spray on bedliner on front end
duramaxiskilinit is offline   Reply With Quote
Old 01-08-2008, 07:36 AM   eBay Motors  #3 (permalink)
BryanVilaubi's Avatar
"Range Shift Inhibited" messages usually means that the 'Neutral Safety Switch" is getting a spuratic signal. Your shift cable feeds into this switch on the drivers side of the transmission which electronically and physically tells the transmission which gear you have selected. Most likely the electrical is your issue and is a common issue with the Allison transmission and most likely will throw a P0708. Is it throwing any codes?
2003 GMC Sierra LB7
New motor in the works as we speak with lots of goodies!!!
BryanVilaubi is offline   Reply With Quote
Old 01-08-2008, 11:48 AM   eBay Motors  #4 (permalink)
mine didn't throw any codes.
Old 01-09-2008, 04:16 PM   eBay Motors  #5 (permalink)
Save Water, Drink Beer
Landscapeman's Avatar
I have had this problem twice and both times it happened after I had been Power braking in the Dirt. No codes and no known problems since.
2006 GMC 2500HD LBZ Crew Cab 4x4, Tie Rod Sleeves, LineX, Silverline Turbo Back Dual Exhaust, PPE Hot Programmer, Egr Block Plate, PPE Air Box Mod, 2in. Plug, SES Light
Full Bore Exhaust Manifold compliments of BD Diesel.
1987 Corvette
Crazy Larry. Get it Here.
http://www.mediafire.com/?g3mtmmjogkz
Landscapeman is offline   Reply With Quote
Old 10-17-2010, 10:19 PM   eBay Motors  #6 (permalink)
I got this message tonight, wouldn't let me get into any gear except Park., I called my son to tow me home and told him to bring the code reader. I read the following codes (P0700 & P0708) I cleared them and started the truck and it ran without any problems!
2003 Duramax
ex-military truck from factory
K & N intake
samclan is offline   Reply With Quote
