09 fuel filter change!! - Chevy and GMC Duramax Diesel Forum
07.5-2010 LMM Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission, Etc.
post #1 of 10 (permalink) Old 02-19-2010, 04:04 PM Thread Starter
Indiana Duramax's Avatar
well i need to change my fuel filter. i cant seem to get to it from the top. maybe im stupid. seems the only way is through the finder well.. i hate to take the finder well off everytime, but will if its the only way.. how do u guys with 09 change yours? help
2009 Silverado 2500HD 4wd LT1
Crew Cab Black
2007 Jeep Wrangler Unlimited
2006 30ft Outback Sydney
Is that you John Wayne ? Is this me?
Indiana Duramax is offline
post #2 of 10 (permalink) Old 02-19-2010, 04:07 PM
BadAssBowtie's Avatar
Send a message via Yahoo to BadAssBowtie
If you are going to be changing your own fuel filters i would highly suggest an LMM fuel filter access door. Makes changing them alot easier! All it is is black molded plastic that goes into the hole that you will cut in the inner fenderwell. The cover looks almost factory and is alot easier to take on and off then the whole inner fenderwell
BadAssBowties
<2008 2500HD D-Max cc/sb 4x4>
Mods: 5" turbo back exhaust DPF DELETE, EFI Live by Brayden, Suncoast GMax trans w/ 1058 converter and torque conv lock up switch , Fleece Tie Rod Sleeves, Turbo Down pipe, cold air intake, Air Dog 150, 3 sets of rims/tires. Some fuel, (thanks to Fleece) some air (thanks to Fleece) and you get one of the baddest workstock trucks in ohio
<1996 1500 strip/street>
Mods: 540 ci procharged BBC, back halved, powerglide, ford 9" 4:56 gears
<1985 2500 10" lift winter beater>
Mods: 496 stroker BBC, 10" lift, 20" black rims w/37" tires *SOLD*
http://www.fleeceperformance.com
BadAssBowtie is offline
post #3 of 10 (permalink) Old 02-19-2010, 04:12 PM Thread Starter
i believe i have seen them, and over looked them thinking ,oh i can do it from the top.. well looks like im ordering one.. thanks badass.....
Crew Cab Black
post #4 of 10 (permalink) Old 02-19-2010, 09:56 PM
BoomerD's Avatar
Where do you order them?
2012 Silver Chevy 3500 Crew Cab 4x4 DRW LTZ
2007 Silver Dodge 3500 Reg Cab 5.9 4x4 DRW (Welding Rig)
BoomerD is offline
post #5 of 10 (permalink) Old 02-20-2010, 05:31 AM
LHN...We ARE the Joneses
Yeah, I'm looking to cut mine open....fab a cover with a leftover mud flap lying around. Who thought up the goofy dip stick routing? You pretty much have to have a step ladder to lean over the front and check the oil. They should of left it like the LBZ, so you could take it out the top side.
Hook'em_Horns! is online now
post #6 of 10 (permalink) Old 02-20-2010, 02:38 PM Thread Starter
you can get them on here from this vendor MadJack Racing Discount Diesel Parts And Amsoil Synthetics
http://madjacksynthetics.com/Chevy/G...r/prod_58.html
Crew Cab Black
post #7 of 10 (permalink) Old 02-20-2010, 02:43 PM Thread Starter
i agree!! kinda sucks.. but wouldnt trade her for anything!!:rockin
Crew Cab Black
post #8 of 10 (permalink) Old 02-20-2010, 03:19 PM
hobbes442's Avatar
i bot kit on ebay and came with WIF wrench and new bleeder screw, makes it easy now
Brian Carbon Black Met 2009 GMC Crew Cab 2500HD SLT
EFI LIVE by Danville Performance
egr blocker plate, magtech deep trans pas
danville perforance rear diff cover
ppe race valve- 4"MBRP SS turbo back exhaust ,B&W turnover GN hitch
S&B air intake, Line-X bed liner,20% tint front windows,Cognito UCA,TB cranked,
BMF NOVAKANE DEATH METAL 18"*9" from Nor Cal
,BFG285/65/18, 52 gal Titan fuel tank,air lift bags, Airdog lift pump
hobbes442 is offline
post #9 of 10 (permalink) Old 02-20-2010, 03:39 PM
I do all of them threw the fender well. Its only 3 7mm screws and 5 push through retainers. Then you can get to it no problem. No cutting.
2014 CCLB SRW, Edge CTS EVO
Toypuller is offline
post #10 of 10 (permalink) Old 02-20-2010, 04:10 PM Thread Starter
thanks, i may have to do that on first change! its DUE!
Crew Cab Black
