DPF Regen? - Chevy and GMC Duramax Diesel Forum
07.5-2010 LMM Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission, Etc.
post #1 of 14 (permalink) Old 04-28-2008, 02:44 PM Thread Starter
Jaydog's Avatar
DPF Regen?
I have over 2,500 miles now and I have not noticed a regen yet. Does it show up on the dash message display when it is in regen mode? I have had it out on the highway non-stop for over an hour several times and I figured I would have seen it go into regen mode by now. The last trip I took I was pulling my 9,000 lbs. fifth wheel camper and had a strong head wind which really sucked. I averaged about 8 mpg on that trip. Unlaoded I have seen about 19 mpg if I keep it around 65 mph.
2008 Duramax 2500HD Crew Cab LTZ
  • EFI Live - tuned by Idaho Rob
  • MBRP 4" turbo back exhaust
  • EGR block plate
  • Transgo Jr Kit
  • Auto Meter digital pyro & boost gauges
Jaydog is offline
post #2 of 14 (permalink) Old 04-28-2008, 05:42 PM
r.laz's Avatar
When I had my DPF, I really didn't notice regen, other than the mpg suffered and it seemed like it didn't have full power. The DIC did not show regen mode. Also, there's this certain smell on exhaust fumes...
08 Sierra WT CC SB
Steel Gray 4x4
PPE RACE
Modded OEM AirBox/PCV Reroute/4" MBRP into 5" MagnaFlow/ EGR BLOCKED
Isspro EGT/Boost gauges Cognito Leveling Kit/HD Tie Rods Pitman/Idler Support Brackets/Bilsteins
Pirelli Scorpion ATR 265/75/16 Coated OEM Wheels
Factory Oval Steps/Rhino Lining
Klein Air Horns (4)/ViaAir 150 psi 2g compressor
r.laz is offline
post #3 of 14 (permalink) Old 04-28-2008, 06:41 PM
blackdeath's Avatar
no it does not show anything
2008 CHEVY LTZ MURDERED THE F OUT WITH SOME SEXY TWINS AND OTHER GO FAST PARTS AND SOME SORT OF 9" LIFT ,ALPINE DOUBLE DIN,FOCAL FRONT AND REAR, TWIN 10" JLw3 AND AUDISON LRx 5.1K
2008 victory vegas low raked 45
1997 gmc 3/4 2wd parts wagon
Xtremeline Automotive Services
www.atptrucks.com
blackdeath is offline
post #4 of 14 (permalink) Old 04-28-2008, 07:19 PM
PinkoDiesel's Avatar
only after market programmers/monitors will show when your truck is in Passive Regen.
08 Chevy Silverado 2500HD Crew 4x4
6" Fabtech
35" Pro Comp Extreme A/Ts
EFI Live DSP 5 Thanks Rob!
TransGo Jr
DTS Performance 3" IC Pipe
4" Silverline System, PPE EGR Plate
BD Exhaust Manifold
Kennedy Diesel Air box Mod
6k/8k HID Headlights & Fogs
PinkoDiesel is offline
post #5 of 14 (permalink) Old 04-28-2008, 07:26 PM
diesel bombers's Avatar
The only way I can tell is if it is going through regen when I turn the truck off. It really has an odor (not a diesel odor) similar to propane or if you can imagine a REALLY hot odor.
07.5 Chevy CC Dmax-6-8"CST set at 8" -35x12.5x20 Toyo MT's-Jesse James Lawless 8's 20"-PPE-Banks 5" tip-AFE Stage 2 Intake-5 Trumpet Train Horns-Truxedo Lopro bed cover-Custom made bedrails, painted to match OEM color-AMP Research Steps-
diesel bombers is offline
post #6 of 14 (permalink) Old 04-28-2008, 07:28 PM
Hmmm! Mine usually has a really strong Diesel burn smell and the hot exhaust pop/cracking noise like when you do a long freeway trip....
6" Fabtech
TransGo Jr
BD Exhaust Manifold
post #7 of 14 (permalink) Old 04-29-2008, 01:09 PM
FH Leader's Avatar
This is from the book. The D-max can not sit and regen you have to be driving it. If you let it sit and run to long it will display a light on the dash. All the d-max does is it regens on the go, you will never notice it with out a programer.
Four stroke diesel S.S.B.B. Suck Squeez Bang Blow
06 LBZ with 5 inch magnaflow exhaust,Bd exhaust manifold, Bully dog outlook, Fass 150, EFI by Rob, SC4 TC1056, transfer case brace, hid 8k on highs and lows
My iron is yellow
Current project-389 pete glider C-16 Stage 2.5 pdi injectors, stage 3 pdi cam, stage 1 tuning,stage 3 turbo, ending hp 850 to the ground!
Id rather be dead then CUMMINS RED!
FH Leader is offline
post #8 of 14 (permalink) Old 04-29-2008, 01:31 PM
It will regen in "Passive" mode for about 5-10min sitting, then will notify you on the dash. Its meant to be running when going down the road towing/driving so exhaust temps and pressures are higher to help it burn out faster using less fuel and more of the engines heat.
When it does go into "Active" Regeneration mode you have to park it until its done.
6" Fabtech
TransGo Jr
BD Exhaust Manifold
post #9 of 14 (permalink) Old 04-29-2008, 01:34 PM Thread Starter
Jaydog's Avatar
OK, it must have went through several regens and I just have not noticed. I did park it one time and the exhaust made a lot of the tick...tick...tick noise like it was really hot, so it must have been doing a regen then. Thanks for all the input.
  • EGR block plate
  • Transgo Jr Kit
Jaydog is offline
post #10 of 14 (permalink) Old 04-29-2008, 02:57 PM
caramon's Avatar
Pardon my ignorance, but what is Regen mode? I take it this is not on the LBZ engines, just the LMM's?
caramon is offline
