brake pads - Page 3 - Chevy and GMC Duramax Diesel Forum
07.5-2010 LMM Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect
Old 12-01-2012, 09:32 AM   eBay Motors  #21 (permalink)
chevor's Avatar
My fronts pads are still orginal at 447k
chevor is offline   Reply With Quote
Old 12-01-2012, 06:38 PM   eBay Motors  #22 (permalink)
Thanks guys.... I'll check them when the rain stops
pgermond is offline   Reply With Quote
Old 12-01-2012, 08:41 PM   eBay Motors  #23 (permalink)
rms
rms's Avatar
Hook'em - how were your rotors?
2007 LBZ 4x4 regular cab
S & B Intake - Diablo Predator
285/75/16 Cooper ATP's - 8' Bedslide
Amp Steps - Bilsteins - Fumoto
rms is offline   Reply With Quote
Old 12-01-2012, 09:31 PM   eBay Motors  #24 (permalink)
LHN...We ARE the Joneses
New or Used?
Old, I haven't mic the rears yet for remaining thickness. They were heavily heat discolored, but no warpage or visible surface eggshell cracks. The available between new and max wear thickness on the rear rotors is surprisingly low. I'm sure they're history....maybe destined for Trot Line anchors?
New, the Cryo slots are slick. Haven't trailered yet though.
I am NOT happy with the Hawk supplier though; shipping the wrong rear pads (had to throw in new cheapos temporarily). After verbally assuring that they had the right pad # for shipment, they still sent the wrong ones…..SRW instead of DRW.
I’ve since found out Hawk Super-Duty Reds don’t offer DRW pads, only SRW.
I’m Pissed! If you're a Forum Vendor on a Duramax site, pull your head out and gain some knowledge on the right parts for our Trucks!
....till Monday.
Old 12-01-2012, 10:37 PM   eBay Motors  #25 (permalink)
rms
rms's Avatar
Yes . . . wanna' hear about the "Cryo's. My rears are a little thin.
Thinking about the Hawk LTS pads and maybe the Cryo's. With Russel SS lines & Speedbleeders.
And have a tech II cycle the ABS module with some DOT 4 fluid.
Should make it brand new.
