Lmm Turbo Removal/Install Tips. - Chevy and GMC Duramax Diesel Forum
07.5-2010 LMM Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission, Etc.
post #1 of 73 (permalink) Old 03-15-2011, 11:37 AM Thread Starter
TANK222's Avatar
Send a message via AIM to TANK222
So either tonight or tomorrow, i'm going to start pulling my turbo out and could use some tips. I also have to pull my inter cooler and clean that out as well.
F250 6.7
TANK222 is offline
post #2 of 73 (permalink) Old 03-15-2011, 11:50 AM
Its just a worktruck
DMAXchris's Avatar
Jack truck up, pull front tires, remove fender liner. Take the intake and mouthpiece off. Take the down-pipe off. Use a good 12 mm 12point socket for the up pipe bolts. You can get them through the wheel wells. Remove the up pipe bolts on the turbo with 12mm 12point. Remove oil line. Remove bolts that hold turbo to block.
06 LBZ EC/LB 4x4
Built Motor/Trans • Bullseye s475/87/.9 • 45% Injectors • Stock CP3 • Built and Tuned by Blackout Performance • 11.76 @ 115
DMAXchris is offline
post #3 of 73 (permalink) Old 03-15-2011, 11:54 AM
saw what you did there
theunderlord's Avatar
is the heatshield still on there?
MY11 Volkswagen Golf TDI 6MT.
6K Lows, 3K Fogs, Tint.
CLICK BEFORE YOU POST!
theunderlord is offline
post #4 of 73 (permalink) Old 03-15-2011, 12:04 PM Thread Starter
TANK222's Avatar
The heat shield is still on.
F250 6.7
TANK222 is offline
post #5 of 73 (permalink) Old 03-15-2011, 12:06 PM
DMAXchris's Avatar
That thing can be a bitch. I took mine off a few years ago by bending the crap out of it. I dont know the "proper" way to remove one. lol.
06 LBZ EC/LB 4x4
post #6 of 73 (permalink) Old 03-15-2011, 12:06 PM
you might be able to get that off by unhooking the glow plug controller (i'm pretty sure that's what that is) and snaking it out that way, but it's a MF to remove..
I just used a pneumatic saw, and cut it in half to remove it.
post #7 of 73 (permalink) Old 03-15-2011, 12:12 PM
Banned
IIRC the turbo drain to block are 12mm as well, their not very tight.
Hondarider552 is offline
post #8 of 73 (permalink) Old 03-15-2011, 12:48 PM
Banned
Don't forget about the coolant lines and I evacuated my ac to get the plumbing out of the way. And you can undo both upipes from the passenger side wheel well, the drivers side on the lmm is too tight to get your arm in. Becareful with the oil feed it has a banjo bolt fitting and the copper gasket can tear. Good luck.
smokinlmm is offline
post #9 of 73 (permalink) Old 03-15-2011, 02:35 PM
NewEST Spinny Thinggg
seth999's Avatar
It really sux...two tips I can think of are first just cut the shield off and second is to get a good socket cause its tight
06' CHEVY 2500HD CCSB PULLER/DD
Danville Billet S475
SoCal Stg.2 Heads
SoCal Cam
Mahle Forged Pistons .040 ovr
Hamilton Rods
Floor it pump
Dipper sticks
ATS Trans/CoPilot/TC
Other Stuff...
seth999 is offline
post #10 of 73 (permalink) Old 03-16-2011, 09:38 PM Thread Starter
TANK222's Avatar
This project defiantly sucks. I have about three hours in it so far, and I've got the down pipe heat shield out, trans dip stick tube out, Piping from the inter-cooler to the y bridge out, and that's about it. Going to hit it hard again tomorrow night. This would be 100 times easier if I just took the cab off.
I still have no idea what i'm doing with the whole egr delete. I bought a new down pipe and the egr delete from rick. Hopefully I'll have that mid next week and we'll go from there.
F250 6.7
TANK222 is offline
