Question/help - Chevy and GMC Duramax Diesel Forum
07.5-2010 LMM Performance Parts Discussion Discussion of Performance Parts For the 07 and up LMM Duramax Trucks No Advertising
Old 10-31-2012, 02:42 PM   eBay Motors  #1 (permalink)
RedMax316's Avatar
Question/help
So the riser broke on my uppipe so i pulled it to cut it off and weld it shut in process the bolt broke off that bolts the downpipe to the uppipe on the bracket that tacked to uppipe does anyone know where you can get that bracket or can i go without bolting the downpipe to anything?
Sent from my DROID RAZR
Donnie 08 GMC Sierra 2500HD cc/sb Debadged AFE CAI and mouth piece with resonator delete 5in straight pipe Profab Downpipe EFI live tuned by Rob at ATP PVC reroute Bank 3in IC pipe PPE Race Vavle & Ported Fuel Rail Fitting CP3 High Flow Feed Line Kit Raptor 150 lift pump built trans by Big Dipper EGR delete with 3in Y-bridge BD manifold Tinted tail lights & 3rd brake light Recon smoked LED cab lights LED tailgate bar Big Rig amber running lights 8K hids lows & driving Fuel Hostage rims Nitto 420's 305/50/20 3in drop shackles traction bars PPE straight centerlink Rareparts tierods Rancho steering stablizer and shocks line X Bed liner billet fuel door
http://www.atptrucks.com/ http://www.powerlabsdiesel.com/
RedMax316 is online now   Reply With Quote
Old 10-31-2012, 02:56 PM   eBay Motors  #2 (permalink)
la77chevy's Avatar
That bracket didn't line up on mine so I just left it out, been like that for bout 2 years now and hasn't hurt anything
Brandon
-04.5 LLY, CCSB, 4x4,Silver Birch
-68mm Cheetah, Suncoast stage 4/triple disc converter
-ATS manifolds/Up-pipes, Profab EGR delete, 4''exhaust
-Diamone Eye DP, AFE stage 2, EFI Live (Rob's tunes)
-Airdog 165, Shimmed FPRV, Re-routed PCV, 3'' IC tubes
-Superlift 6'' w/traction bars, heavy duty bumpers
-35'' Nitto Trail Graps on Mickey Thompson Sidebitters
-LBZ MP, Sleeves, N-Fab step bars, HID's
la77chevy is offline   Reply With Quote
Old 11-01-2012, 05:25 PM   eBay Motors  #3 (permalink)
RedMax316's Avatar
Bump anyone else have any info or a junk up-pipe laying around with the bracket they want to get rid of
Old 11-12-2012, 06:28 PM   eBay Motors  #4 (permalink)
joegorby's Avatar
Did you bolt the riser plate down?
2010 2500HD LMM CCSB
Tuned by Blackout PerformanceBatmo S472 from EPR
AirDogII 200= PPE Dual Fueler= 45% Injectors
PPE Stage 5 with billet shafts=PPE C5 upgrade=Suncoast 1058 Built by Big Dipper
Kryptonite and Cognito Front End
Diamond Eye 4" straight pipe
Alligator Performance PCV reroute
AutoMeter Gauges
2013 GMC 2500HD Denali CCSB
Stock for now (H&S on the way)
joegorby is offline   Reply With Quote
Old 11-12-2012, 06:57 PM   eBay Motors  #5 (permalink)
RedMax316's Avatar
Yeah but it still cracked but its all good now welded shut so no more worries
Old 11-12-2012, 07:01 PM   eBay Motors  #6 (permalink)
Meyer Performance
lutzjk913's Avatar
Was you running a egr cap on yours when it broke?
Joe
2008 CCLB LT2 DURAMAX LMM
was once stock
Special thanks to Tyler @ www.MeyerPerformance.com 812-344-4421
lutzjk913 is online now   Reply With Quote
Old 11-12-2012, 07:08 PM   eBay Motors  #7 (permalink)
RedMax316's Avatar
Yeah had riser cap but it broke at the flex part on the riser so i pulled it off and cut riser off and welded it shut
Old 11-12-2012, 07:16 PM   eBay Motors  #8 (permalink)
Meyer Performance
lutzjk913's Avatar
Ok, I have the same thing as of now but have a lb7 up pipe on stand by.
Joe
was once stock
Old 11-12-2012, 07:34 PM   eBay Motors  #9 (permalink)
RedMax316's Avatar
My 2 cents but i say go ahead and change it if you have the time before it breaks and you get all that soot under the hood in the engine compartment but that just my opinion some may say leave it alone till it breaks but thats what i thought but now i wish i would have just done it that way in the first place had to tear it all back apart anyway and now have a mess under the hood to clean
Old 11-12-2012, 07:44 PM   eBay Motors  #10 (permalink)
Meyer Performance
lutzjk913's Avatar
I had intentions of doing it but couldn't get the mbrp down pipe out and got irritated.
Joe
was once stock
