HP/TQ gains from just removing DPF and MBRP 4" - Chevy and GMC Duramax Diesel Forum
07.5-2010 LMM Performance Parts Discussion Discussion of Performance Parts For the 07 and up LMM Duramax Trucks No Advertising
Old 12-24-2012, 03:51 PM   eBay Motors  #1 (permalink)
I tried searching a number but could not find anything. I know you have to tune but.....
Lets say you just removed the DPF from the LMM and didn't tune any added power what do you think the HP/TQ would be.
How about with DPF delete and 4" MBRP?
Thanks
2007.5 Chevy 2500HD -- EFI Live by Kory Willis/DSP5 -- 4" MBRP turbo back w/ Muffler -- Diamond Eye Downpipe -- EGR Blocker Plate -- Nictane W/ Cat filter -- Edge Insight W/ EGT -- Firestone Riderite Bags -- 265/75/16 Duratrac W/ leveling kit
stang233 is offline   Reply With Quote
Old 12-24-2012, 04:20 PM   eBay Motors  #2 (permalink)
I believe the MBRP will give you 15-20 hp increase.
2008 GMC 2500 HD SLT, Crew, 4 X 4
4 inch MBRP Turbo Back
Quadzilla Stealth 2 on 50hp
2 inch leveling kit
EGR Blocker Plate.
Goodyear Silent Armour 285-70-R17.
08lmm/white is offline   Reply With Quote
Old 12-24-2012, 04:35 PM   eBay Motors  #3 (permalink)
Banned
20hp tops.
Intakes don't add jack.
Old 12-24-2012, 05:16 PM   eBay Motors  #4 (permalink)
MBRP website claims 18hp and 28tq gain at the wheels for Duramax.
2 inch leveling kit
EGR Blocker Plate.
Old 12-24-2012, 05:37 PM   eBay Motors  #5 (permalink)
KB3MMX's Avatar
^^^^^^^WHS
Without additional fueling or timing changes the gains are very minimal. The biggest gain you'll see is improved mpg because fuel isn't wasted during regeneration.
EGT will be a little cooler to boot due to less restriction.
Ham Radio= Global communications without airtime fees
My Antenna-SteppIR
Si Vis Pacem, Para bellum !!!!
07' Chevy Silverado HD --CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod)
--EFILive tuning by ...ME with 68MM 4094VA Garrett Powermax Stage 2 Turbo
--SILVERLINE 4" Stainless Exhaust, Modded stock Airbox and LIBERATOR Stainless Downpipe
--AMSOIL Synthetics and filtration bumper to bumper, including Bypass
--DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs
--PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes
--Danville 3" Y Bridge and big air intake kit / EGR delete
KB3MMX is offline   Reply With Quote
Old 12-24-2012, 05:50 PM   eBay Motors  #6 (permalink)
Who cares it's enough that it's worth it!
2006 LBZ EGR BLOCKER, PPE STANDARD,6000W inverter, AMSOIL DUAL BYPASS, ALL AMSOIL FRONT REAR TRANS TRANSFER CASE, BACKUP CAMERA, EDGE CS GAUGES W/EGT PROBE, REMOTE START,PARROT HANDS FREE BLUETOOTH.4"in MBRP EXHAUST/WCAT DELETE PIPE,PCV REROUTE,ALL HEADLIGHT ON MOD.
rvjabo is offline   Reply With Quote
Old 12-24-2012, 06:06 PM   eBay Motors  #7 (permalink)
Banned
"claims"
Old 12-24-2012, 06:28 PM   eBay Motors  #8 (permalink)
mackyoudip's Avatar
You won't notice a performance gain.
Mack: LMM.
mackyoudip is offline   Reply With Quote
Old 12-24-2012, 06:48 PM   eBay Motors  #9 (permalink)
It'll sound better and you might get .5 MPG gain on normal driving conditions.
Dan1969 is offline   Reply With Quote
Old 12-24-2012, 09:43 PM   eBay Motors  #10 (permalink)
projectblack's Avatar
I've been hearing the mpg gains are far better than that! I'm deleting mine soon! I know my brother 08 f350 had major mpg gains when I deleted it! He went from 250km per tank to 350
projectblack is offline   Reply With Quote
