OEM Steering Stabilizer Removal - Chevy and GMC Duramax Diesel Forum
07.5-2010 LMM Performance Parts Discussion Discussion of Performance Parts For the 07 and up LMM Duramax Trucks No Advertising
 1Likes
post #1 of 12 (permalink) Old 10-17-2009, 04:43 PM Thread Starter
FLADMAX's Avatar
I just purchased an aftermarket steering stabilzer for my 09 2500HD. Does anyone know how the heck to remove the OEM stabilizer. The attachment on the drivers side is simple to remove, but I removed the nut on the passenger side and cant get the stud the attaches the stabiler assembly to the main steering rod to come out.
D/AChris likes this.
2009 GMC 2500HD , 4" lift, 305 Toyo Open Country, 20x9 Novakane's, Cognito tie rods and braces, Cognito Traction bars, Kryptonite idler support and gussett, Banks intercooler & hot side boost tube, 4" MBRP exhaust, Airdog II 165, Built tranny, EFI Live DSP5 (Tunes by ATP), Edge CTS for monitoring, SDP twins (S475 over stock).
FLADMAX is offline
post #2 of 12 (permalink) Old 10-17-2009, 06:11 PM
Crusher's Avatar
I heard of using pickle fork or pitman arm puller.
2006 Chevy 2500HD LT CCSB 4X4 Duramax LBZ;
EFILive V2 Tuned by IdahoRob, FASS HD-C10-150G,
BANKS Ram Air Intake + Super Scoop, Banks Boost CAC Tube, BD Exhaust Manifold, EGR Blocker, MBRP DP, 4" Turbo-Back Exhaust w/ Aero-Turbine 4040, PCV Reroute, Transgo Jr., B&M Racing Deep Pan, Pure-Power Filter, SunCoast Deep Filter Lock,
Autometer Ultra-Lite II - EGT & Boost in overhead. NCT/Bilstein Shocks, Sulastic Shackles, Kryptonite Tie-Rods, Cognito UCA & Steering Braces, Firestone Ride-Rite Airbags, Reunel Bumper, Open Country M/T, LINE-X, TruXedo Tonneau, Pro-Tech Toolbox, Pioneer FH-P8000BT, i-pod, Focal 165KF Frt & Rear, JL Audio 300/4 Amp, Focal 27KX Subs, Audison Amp, Rattle-Trap Xtreme.
Crusher is offline
post #3 of 12 (permalink) Old 10-17-2009, 06:14 PM
twinturbo3150's Avatar
not much wiggle room either, I also had to cut off the oem tab and grind it smooth before installing my fabtech dual stabilizer.
I dont own a Duramax! I own a Gremlin
twinturbo3150 is offline
post #4 of 12 (permalink) Old 10-17-2009, 06:21 PM
motohead's Avatar
I had to take out the wheel liner and broke two Air hammer Tie rod attachments. Finally got it out and when i put the new one in, I over tightened the nut and sheared the bolt off. Repeated the whole thing and now im good. The attachements were from Snapon and i already ordered replacements
-2005 Chevrolet 2500 HD D-MAX CC/SB
motohead is offline
post #5 of 12 (permalink) Old 10-17-2009, 06:23 PM
I didn't have to remove the wheel liner, but I did give my air compressor, and air chisel a serious workout. I cussed up a storm but worth it with a lift
post #6 of 12 (permalink) Old 10-21-2009, 11:30 PM
You make it sound difficult lol!
Inspector12 is offline
post #7 of 12 (permalink) Old 10-22-2009, 12:31 AM
05greendmax's Avatar
i need to replace mine soon
2005 ccsb hunter green
rip old motor
(fully stock)
motor going in
huge thanks to Dustin and robb at (ATP)
could not have donr this with out your help
hope this new motor holds 500hp this time
05greendmax is offline
post #8 of 12 (permalink) Old 10-22-2009, 04:10 AM
Administrator
ob_1jr's Avatar
Dang, that's what i have to look forward to? At least the auto hobby shop has most any tool i would ever think of needing.
2016 GMC Sierra 2500HD Denali
Extang Blackmax Tonneau
X-pel clear bra
SOLD 2004 GMC Sierra LB7
ob_1jr is offline
post #9 of 12 (permalink) Old 10-25-2009, 12:58 PM Thread Starter
FLADMAX's Avatar
I replaced the stock stabilizer this weekend. I used a pitman arm puller and the OEM stud popped right out. The trans cooler lines were in the way of the puller but I temporarily removed a small plastic tab that secures the lines and then was able to move them enough to get the puller in. I also removed the fender well liner, it made it much easier to get at the bolt on the puller. The heavy duty stabilizer is much better than the small stock one, much less bump steer now!
FLADMAX is offline
post #10 of 12 (permalink) Old 10-25-2009, 01:32 PM
Thanks for the info!
