Turbo Gaskets - Chevy and GMC Duramax Diesel Forum
07.5-2010 LMM Performance Parts Discussion Discussion of Performance Parts For the 07 and up LMM Duramax Trucks No Advertising
post #1 of 14 (permalink) Old 12-28-2010, 07:34 AM Thread Starter
Banned
Turbo Gaskets
Should I replace the exhaust gaskets on my up pipes to turbo connection when I install my 4094? Or can i just reuse the factory ones, I ask bc the machining on new turbo mating surface has got to be a little diffrent than stock.
smokinlmm is offline
post #2 of 14 (permalink) Old 12-28-2010, 07:35 AM
Im Superrrrr!
jmaz268's Avatar
Send a message via Yahoo to jmaz268
I would prob replace them.....or at least have a set in case yours get messed up removing the uppipes.
be shitty to have to wait to finish installing because of them
Goes by John
--2001 ECSB
SDP Big Single, Wehrli Dual Fuelers, 50% sticks, Front Coilover Conversion, Anorexic .....much much more
Sponsored by Creatures of the Night Performance and SDP
--2005 CCLB Dually
The tow pig
Tuned and Edge Insight CTS
jmaz268 is offline
post #3 of 14 (permalink) Old 12-28-2010, 07:45 AM
Pura.Vida's Avatar
The machining should be no different from one to the next. Machined faces have to adhere to very strict tolerances in the machining industry and if they don't, they are rejected. These are measured in parts per million. The amount of rejects are usually in the 1-2 PPM. If you got a bad one you are just one unlucky SOB. With all that said, yeah it could happen.
FWIW...Lets just slap that baby on today…screw waiting for the tech. I wanna go finish off your Mud Terrains.
Jordan
05 LLY CC SB 4X4, K&N ON LBZ INTAKE, RESONATOR PLUG, LBZ MP, 4" SILVERLINE, PCV RE-ROUTE, PORTED FUEL RAIL FITTING, EGR DELETE TUBE, FPRV SHIMMED, AIR DOG II 165, DEEP PAN/FILTER LOCK, TRANS-GO JR SHIFT KIT, SYN BLEND TRANS FLUID, PPE STANDARD, H2 WHEELS WRAPPED IN 295 GRAPS, HID H/L/F ALL ON, LED PLATE LIGHTS, MANUAL HIGH IDLE, GATORBACK SERP BELT, TORSION KEYS, TIE ROD SLEEVES, ARP HEAD STUDS
Oxcart- 01-18-2011, 11:43 PM
Thread-efi smoke tune help
"You will be back hippy."
Pura.Vida is offline
post #4 of 14 (permalink) Old 12-28-2010, 07:52 AM Thread Starter
Banned
So do I!!!!!!!! Still waiting on down pipe.
post #5 of 14 (permalink) Old 01-04-2011, 07:48 PM Thread Starter
Banned
Went ahead and bought the steel gaskets, 17 bucks for both of them. They don't look reuseable to me, they look like a crush washer. Tearing it apart saturday, ic pipes, turbo, uppipes, down pipe, intake manifolds, valve covers, etc...
post #6 of 14 (permalink) Old 01-05-2011, 07:44 AM
Meyerperformance's Avatar
You will have fun!
Meyerperformance is offline
post #7 of 14 (permalink) Old 01-05-2011, 07:47 AM Thread Starter
Banned
Thanks, Tyler. That is the plan!!!! Can't wait to hear that 4094 spool for the first time!!!
post #8 of 14 (permalink) Old 01-05-2011, 08:27 AM
It is a great sound.
post #9 of 14 (permalink) Old 01-05-2011, 08:31 AM
Pura.Vida's Avatar
Thanks for the tease...now I gotta get one. Its like the blue pill for your Dmax.
Jordan
post #10 of 14 (permalink) Old 01-05-2011, 09:02 AM
duratothemax's Avatar
personally I have never had a problem reusing them many times.
06 audi S4, V8/6spd
05 dmax/allison...always testing something new
-BT DieselWorks, LLC-
[SIZE="3"]Specializing in a wide range of custom electronics and great gadgets for your 2001+ GM full size truck/SUV
Allison torque converter lockup controllers, Allison Tap-Shift kits, digital DSP-5 switches, affordable injector harness repair kits, and much more!
duratothemax is offline
