Old 10-05-2008, 11:24 AM   eBay Motors   #1 (permalink)
Crankrod
Crankrod's Avatar
Factory Oil fill???
Does GM use anything special for oil on brand new trucks?
Mine has 3500 miles and I am dying to change the factory fill. Its already getting black! I tow almost at the max of the rucks rating, thats why I bought it......
In the old days they used EOS on the new cars, but I dont think they can do much with additives on these new trucks withs cats & DPF's.
Can I get rotella in it right now? My dash says I got 60% oil life left, but I want/need this truck to last.
My dpf and kitty is already off, so I plan to use the NON/old spec oil with the better additve package than the new junk with the low levels of ZDDP.
I have seen lotsa muscle car (flat tappet cams) wiped out by the new spec oils without the good additive packages. Apparently roller cams dont need good oil, and catalytic convertors and likely DPF systems don't like the "old" oils.
We buy our rotella in 55 gallon drums for our logging equipment that doesnt have cats.......It is not the new spec oil, it has the old/good additives in it. That what I'd like to run in mine.
Question is .... can I do it right now or should I wait till the dash monitor say to do it?
2008 GMC 2500, LTZ, 4" MBRP downpipe back, Stealth 2 @ 135, AFE 7, EGR blocked, Redline water wetter, husky mats and rear under seat storage. I tow my grove tractor with it, 15,000+ with mower & front loader, and 25' trailer. 23 MPG (DIC) at 60 MPH cruise, when empty
Mods coming soon (>10 days) Suncoast torque convertor and a Transgo JR shift kit before I slip the trans, Fass 150, HOPING to see 25 MPG on the DIC.
Future Mods, Suncoast trans, turbo & intercooler.
Mike Milliken, Forester, Boyett Land & Timber: 863-439-8224
Crankrod is offline   Reply With Quote
Old 10-05-2008, 11:32 AM   eBay Motors   #2 (permalink)
deeretracks
The Sheriff
deeretracks's Avatar
IMO I would change it.
Craig
2001 Chevy, 4 door, short bed,D-Max, 2 wd.
Special Thanks goes to the person in the WAL-MART parking lot for installing it for me,
Old 10-05-2008, 11:44 AM   eBay Motors   #3 (permalink)
Crankrod
Crankrod's Avatar
Black oil because of the EGR??
I just read this on another post in the forum.......If the EGR is dumping soot in the oil, and IF thats why its black already. I will get the EGR block offs installed.
There would be no sense at all in putting synthetic oil in one of these IF the egr is dumping soot in the motor oil......
IS THIS TRUE?
WHY would GM use the engine oil as a "septic tank" for soot?
Old 10-05-2008, 02:12 PM   eBay Motors   #4 (permalink)
FH Leader
FH Leader's Avatar
the oil is okay. you are going to have black oil in a diesel after a thousand miles on the oil change. my oci is every 5000miles and my brother and my dad take there's out to 10000miles."WHY would GM use the engine oil as a "septic tank" for soot?" they dont it is what has to happen if they want to make the tree hugers happy. every diesel engine does it some more then others.
Four stroke diesel S.S.B.B. Suck Squeez Bang Blow
06 LBZ with 5 inch magnaflow exhaust,Bd exhaust manifold, Bully dog outlook, Egr blocker, Firestone air bag system,Custom sound system, dual fuel filters,leveling kit, B&M deep tranny pan,TTS lift pump,Turbo Resonator plugged,Cooper ST 265/75R16, Bully nerf bars and B&W guardian headache rack sprayed with reflex bed liner, B&W turn over ball,B&W Tow&Stow, transgo jr, efi live, tranny filled with transynd, Tierods sleeved
Omaha Truck and Trailer offering Woodworth custom build trailers.
Now a factory authorized Whelen dealer
My iron is yellow
FH Leader is offline   Reply With Quote
Old 10-05-2008, 04:11 PM   eBay Motors   #5 (permalink)
BigRedChevy
Post Slut
BigRedChevy's Avatar
change it. the roltella will be fine
KYLE
Old 10-05-2008, 04:41 PM   eBay Motors   #6 (permalink)
Crankrod
Crankrod's Avatar
Thanks guys
I am going to change mine a LOT, every 3K unless the EGR blockers clean it up some. No extended drain intervals for me. My oil is free for all intents, and we buy Wix filters by the case , so they are nearly free as well.
It blows me away that the EGR dumps soot in the oil.
I'd guess that the egr system also raises EGT's.....
Old 10-05-2008, 06:57 PM   eBay Motors   #7 (permalink)
lubeman1969
change it
2006 2500 LBZ CREW CAB LONG BED
EDGE JUICE W/ ATTITUDE
315'S W/ 17" GEAR LOCKER 714C WHEELS
FABTECH 6" LIFT
BD EXHAUST MANIFOLD
S&B COLD AIR INTAKE
4" STRAIGHT PIPE EXHAUST
RESONATOR HOLE PLUGGED
1 CARSEAT IN THE BACK-
lubeman1969 is offline   Reply With Quote
Old 10-06-2008, 03:38 PM   eBay Motors   #8 (permalink)
D_R_C
D_R_C's Avatar
I feel the closed crankcase system is a contributer to dirty oil as well.
Taking fresh air and crankcase oil vapor into the intake is a start of dirty egr flow.
At least the exhaust will be somewhat cleaner.
Doing a PCV re-route and then the intake will be completly fresh air intake burning not the crankcase oil vapors mixed with the not so fresh anymore air intake.
I did a open pcv on my ex 03 Ford 6.0 and left the egr functioning(reason, the engine sounded like it was going to blow up disabled)
Now,the exhaust was a little cleaner, and the oil stayed cleaner, longer.
2007.5 GMC Sierra 3500 SRW BLACK,SLT,C.C.,4X4Loaded,DMax,(Stock)(except for a aFe OEM airfilter part # 71-10101 and deleted the restricted muffler),Allison,Westach single gauge combo reading EGT/Boost,Rear Firestone Air bags with incab controller,back-up sensors and camera in the nav monitor.
D_R_C is offline   Reply With Quote
