Old 11-24-2008, 09:25 AM   eBay Motors   #11 (permalink)
DMAXchris
DMAXchris's Avatar
I plug my truck in when its below 40F. Elevated idle will NOT hurt your truck. PLuggin it in is the BEST thing you can do in the winter.
Warm coolant+Warm oil=happy engine
06 LBZ W/T ECLB---PPE standard, ported rail fittings,FPRV shim, K&N Drop in w/ modified box, resonator delete, Grand Rock powerflow 4" turbo back w/ 7" Aussies, EGR Blocked, PPE tie rod sleeves, PPE pitman/Idler brace kit, LED Recon tailights, 3rd brakelight and tailgate bar, HID 8000k, Pioneer 4000 DVD, Memphis components, Autometer GS boost/pyro, Aeroforce Scangauge(soon i hope). 434.6 hp 764.48 ft/lbs--------Suncoast stage IV is next
Chuck Norris always knows the EXACT location of Carmen SanDiego
photobucket:http://s384.photobucket.com/albums/oo289/DMAXchris/
YOUTUBE channel: http://www.youtube.com/sootchuckers
DMAXchris is offline   Reply With Quote
Old 11-24-2008, 05:44 PM   eBay Motors   #12 (permalink)
Jfarmer
Jfarmer's Avatar
For the elevated idle to work, the outside temp needs be be below 32F and the engine temp needs to be less than 160F. (or a combination close to that) On cold days, I've noticed that just running around town that the engine temp will drop low enough that the elevated idle will activate even if I've been driving for some time. Never had any problem with it, but you may want to watch extended idle times with the DPF.
07.5 LMM, Sport Red, Extended Cab Long Bed, DPF Delete, Quadzilla Stealth 2, MBRP Straight 4" Exhaust. Torsion lift keys with Blisten Shocks.
True Love is a Corvette, but the Truck is Faster.
Jfarmer is offline   Reply With Quote
Old 11-24-2008, 07:42 PM   eBay Motors   #13 (permalink)
eprovenzano
Don't be so sure about that. Last winter Canadian dealerships were changing hundreds of Allisons that were fried due to elevated idle and an associated part failure.
Do a search and I'm sure you'll find some info.
Personally, I don't run the elevated idle and I see -30C temps. When the block is frozen solid in the frigid winter I don't like the idea of running the engine any quicker than it needs to.
I think a good winter grill cover will do more for you than the elevated idle.
Just my $0.02.
2007 LBZ 2500HD CC SB 4x4 Red
Leer canopy, Aries Oval step bars, 18" AR Cannons wrapped with General Grabber HTS 275/65R18's, everything else stock.
Love this truck....HATE the fuel economy yea yea, I know it's a truck, and YES I want the same mpg as a Civic
eprovenzano is offline   Reply With Quote
Old 11-24-2008, 07:49 PM   eBay Motors   #14 (permalink)
eprovenzano
I had a quick look at the posts from last winter. It seems GM addressed the problem for the LMM's so you should be ok.
Still, I don't like it.
Good luck!
Old 11-24-2008, 08:21 PM   eBay Motors   #15 (permalink)
DMAXchris
DMAXchris's Avatar
Just my $0.02.
Thanks for the info, I'll look it up.
Wow, it never gets that cold here.lol
Old 11-24-2008, 08:23 PM   eBay Motors   #16 (permalink)
n0useforaname
Knows your Mom
n0useforaname's Avatar
I had someone fax me that recall because I was worried. But what happened was, when it got below -30F...with elevated idle on....it would not flow tranny fluid...and that's what was frying the tranny. But unless it gets that cold out, elevated idle is fine to use. I think it all boils down to how long you want to wait for your truck to warm up. And as for plugging it in...I heard that won't even work unless it's like -10 or below....
LIFT: Ready Lift Leveling Kit
SOUND: Pioneer P4000DVD - 6 1/2 Polk Audio everywhere else.
ADD ONS: H1 Halo Projector headlights, Backup Camera, Dee Zee running boards, Chrome Grill, ExTang Solid Fold Tonneau Cover, Line of Fire w/reverse, custom bug shield/vent shades, TomTom GPS
TIRES/WHEELS: 285/75-16 Firestone MT Tires on 16x8 ATX series Teflon Coated Wheels
Old 11-24-2008, 08:26 PM   eBay Motors   #17 (permalink)
DMAXchris
DMAXchris's Avatar
I"ve pluggin mine in for the last week or so..since night temps were below freezing..it made my coolant temp about 160. but as soon it ran it went down and high idle kicked on. Only when it was in the 20's
Does the idle go up higher when its colder?
