07.5+ LMM Duramax PowertrainDiscussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect
So, with the DPF on the LMM motor, it reaches a stage when measured flow against resistance triggers a Re-Gen cycle. It is stated that temps reach 1100*F to burn off the particulates.
My question is this, if you're workin' it hard pulling heavy on the highway and elevating your EGTs, wouldn't you in fact have a passive Re-Gen going on with the DPF, thereby using less fuel overall?
2006 Chev 6.0L/4L80e 3500WT DRW Ex-Cab, 9 'Flat/GN, Ride-Rite Air Springs, A/T Revos. Use-ta Haves 2005-LLY 3500 LS DRW Crew Cab, 2002-LB7 3500 LS DRW Crew Cab
"Did you ever think that making a speech on economics is a lot like pissing down your leg? It seems hot to you, but it never does to anyone else. " -Lyndon B.Johnson 100th
Yes and no if that makes any sense. When pulling you are getting egts of maybe 1000-1200, When its in regen it heats the dpf filter to around 1700 is what our description and operation states. So when towing you are using more fuel, causing more soot, causing it to regen more.
__________________ 2005 LT 3500HD CCLB SRW LLY
PPE Powered, Brand new allison thanks to ppe level 4
Lbz intake and mouthpiece
Torsion lift keys
MBRP 4" turbo back
Autometer boost and egt
Firestone ride-rite
Res Mod
Mcculloch 5300k HIDS
Technician Parkland Chevrolet
I C...I was using 1100 as that is stated in the medium duty showroom brochure as the burn point.
If a higher temp is needed, then the jump from 1100 would require less fuel for a shorter period of time to complete the re-gen, wouldn't it? Are the higher than 1100 temps seen a result of more fuel being dumped from a cooler EGT starting point?
My quest is, towing re-gens may use less fuel for shorter durations, yet may have more cycles per tank, or not. Are more particulates forced through in stop and go driving versus steady boost cruise on the open road? I think so.
Help me understand better... when a regen occurs extra fuel is put into the exhaust to heat the dpf to the needed temps.... The extra fuel comes from the injectors? Does it inject it on the exhaust stroke? How does it only heat the dpf to that temp and not everything else? I wouldn't want my turbo seeing 1700 degrees. I appologize if this is dumb question just trying to understand what happens. Thanks guys.
__________________ -Anthony-
08 2500 Crew Cab 4x4
6" Fabtech Lift Kit
18" Moto Metals
Mickey Thompson ATZ 35x13.50's
Stainless Running Boards
12" Flip Down TV/DVD for the kids
PCV Reroute
Edge Juice W/ Attitude
Coming soon: Transgo Jr.
Sit Down... Shut Up.... and Hold On!
If I understand the system correctly most of the heat is created in the DOC. There is a catalyst that reacts with the un-burnt fuel causing the high temps. The fuel is injected on the exhaust stroke and yes it does heat the turbo but not to the point of hurting it. If I am wrong someone please correct me.
__________________ 2008 GMC Sierra Crew Cab 4X4 334 hp and 599 ft/lbs on 24 Aug 2008 at Meridian Motor Sports Meridian Idaho.
Yes what usafracer said. I could not have said it better.
Torsion lift keys
MBRP 4" turbo back
Firestone ride-rite
Res Mod
