Old 11-29-2008, 12:32 PM   eBay Motors   #11 (permalink)
farmer14
i have an 08. pulls great on the farm from hay wagons to silage boxes, 6 ton dump (bumper hitch), to my 7 ton goose. rides great plenty of power and the engine brake is great.
2007.5 2500 ltz fully loaded crewcab, banks air intake,
truxx 3inch lift.
lots of chrome accs.
nathan k5la train horns,
b&w hideaway goose & 5th wheel
stealth 2
mbrp duals-dpf & muffler delete
fire & ice lightbar
farmer14 is offline   Reply With Quote
Old 11-29-2008, 12:35 PM   eBay Motors   #12 (permalink)
Duramax-LB7
Duramax-LB7's Avatar
Any duramax will pull hard if u can get a cheap programmer for it. Im suprised your 03 didnt pull to impress. But idk if u had any mods. But the LMM AND LBZs both have enough torque and hp to pull hard stock : )
-2002 LB7, CC/SB 4x4 SLT
-4" fabtech lift
-35x12.5x17R Toyo open country tires on 17" MKW wheels.
-PPE STANDARD XCELERATOR @ 160hp
-BANKS EXHAUST BRAKE 3 1/2 STRAIGHT PIPE.
-Lost kitty : )
-Bushwacker Pocket Style Fender Flares : )
to come: Gauges $250....bigger Exhaust $430...Torque Converter $1000...PPE boost valve $30..lift pumps...water methanol
MYSPACE: www.myspace.com/jakeboi15
Duramax-LB7 is offline   Reply With Quote
Old 11-29-2008, 04:09 PM   eBay Motors   #13 (permalink)
Iceman56
I pull a 36" horse trailer with roughly 25000 pounds or more with my 08 2500HD. It pulls great stock and even better with the mods. I do have airbags though.
08 LMM, MBRP 4" Turboback, Quadzilla Stealth 2, EGR Block plate, BD Manifold, Transgo Jr., Edge Insight Monitor.
Leveling kit, 20" Ultra Lighting Wheels, 285/55/20 Terra Grapplers, Air Lift air bags and pump.
Iceman56 is offline   Reply With Quote
Old 11-29-2008, 06:49 PM   eBay Motors   #14 (permalink)
ironcrossmike
I've used mine for hot shotting pulling a 40' mini float. Gross weight over 36,000 many times and zero major problems. Only probs. have been fuel filter related ( change it regularly!!!) Out pulls anything else I've driven.
"When in doubt,STAND on it!!!"
2007.5 Crew cab dually with LMM and 6 speed, B&W hitch,4"Diamond Eye exhaust,PPE Xcellerator Hot+2 Race, Autometer Sport Comp2 boost and pyro gauges.Transgo Jr. Custom bent tailgate thanks to a lowriding GN trailer!
ironcrossmike is offline   Reply With Quote
Old 11-30-2008, 06:34 PM   eBay Motors   #15 (permalink)
BoomerD
That was probably my problem, no mods, with the first Duramax. I loved the truck, but it just didnt really pull to impress. Ive definitely heard a lot of good things about the newer ones though. When hauling hay i stay around 30,000 lbs, my question is will the new Dmax out pull a 5.9? My 5.9 is a little sluggish with hills, but i could run 80mph easy on a flat. One more Question, does the 08's come factory with an exhaust brake?
07 Dodge 5.9 RC DRW 4x4, Silver, Smoked Recons all around, light bar, Rockstars, AFE, Smarty, Soon to come: 09 Chevy 3500 Crew DRW 4x4
BoomerD is offline   Reply With Quote
Old 11-30-2008, 07:07 PM   eBay Motors   #16 (permalink)
Hook'em_Horns!
Endless torque
Plenty of power...so much so that against that kind of load you'll be easing the seemingly endless torque onto the Drive Line. NO tromping to the floor is needed, even for hills. Totally different throttle needed compared to driving the 6.4L Furd also.
2006 Chev 6.0L/4L80e 3500WT DRW Ex-Cab, 9 'Flat/GN, Ride-Rite Air Springs, A/T Revos.
"Did you ever think that making a speech on economics is a lot like pissing down your leg? It seems hot to you, but it never does to anyone else. " -Lyndon B.Johnson 100th
Old 12-01-2008, 08:01 PM   eBay Motors   #17 (permalink)
BoomerD
So Hookem Horns, your saying that i wont miss the Cummins at all? My dad loves his Duramax and is going to let me test his before i throw down the cash, but im thinking regardless im going to get one i love the room and ride compared to a dodge. Do the new ones come with a factory exhaust brake?
Old 12-01-2008, 08:05 PM   eBay Motors   #18 (permalink)
CaseBlackKnight
CaseBlackKnight's Avatar
Im not sure if you can order them with exhaust brakes. But the allison does downshift for you when your in tow haul which helps quite a bit when pulling trailers.
Kyle
02 Chevy 2500 LB7 extended cab long box
PPE Standard Tuner on setting 3, PPE Boost Valve
4" Turbo Back Straight Piped, Resonator Plugged
Autometer NV Boost and Pyrometer
CaseBlackKnight is offline   Reply With Quote
Old 12-01-2008, 08:09 PM   eBay Motors   #19 (permalink)
BoomerD
Well ill have to look into it, Thanks though. Thats the ONLY thing i liked about my 6.7.
Old 12-01-2008, 08:11 PM   eBay Motors   #20 (permalink)
CaseBlackKnight
Well if you really want one there is always aftermarket kits
Kyle
