07.5+ LMM Duramax PowertrainDiscussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect
Just finished a 9400 mile trip towing a 31 foot fifth wheel weighing 11500
2008 duramax w/ allison 6 av 10.3 MPG would like more. Any Ideas?
Do the DPF delete if you dont mind voiding exhaust warranty at a minimum. Shoot me a pm or give me a call, if you have any questions about it. You could see up to 4-5 mpg empty.
Tyler
MPF,LLC
__________________ Meyer Performance & Fabrication, LLC Home of your diesel performance needs. www.meyerperformance.com (812)-344-4421 Tyler
Black Friday Sale going on till Dec. 3rd. PM for pricing.
I will be out of country Dec. 4-8th. Let me know if can help before i leave, or upon return.
Just got back yesterday from a trip to yellowstone put on 3150 miles and averaged 17.6mpg hand calculated checked every tank lowest was 13.96 with a 30+ mph head wind best was 20.14 33400 on truck in stock mode have not put ppe back in after reflash
__________________ 2007.5 lmm mbrp filter back ppe banks ram air edge insight
About 2k miles on my new truck already. Has 4" lift with 275/70/18 (basically 33 1/2" tires) Discover STTs. Hand calc with correction for new tires - about 13mpg around town, 14-15 when driving 75-80 on freeway, impressive 19.6 mpg when keeping it 65 mph (all highway driving trip).
22,000 miles and I get 11 towing a 13,000lb 5th wheel, 13 around town and 16 on the highway. Much over 65 and it drops to about 14. MPG has gone up since I got rid of my K and N filter. K & N was throwing a code for the air flow sensor. Too much oil out of the box that would gum up the sensor. Dealer would not replace sensor under warranty until I came back with a stock filter. Two friends had same problem.
Good thing to remember is to watch your tire pressure. My mileage dropped almost 1mpg after getting my tires rotated. They had let the back tires down to 60psi and the front down to 45psi for a better ride. Pumped them back up to 70 today, i should be getting 19+ again.
__________________ 2008 GMC Duramax 3/4 ton 4x4 CC SB Dark Brown Metallic-In dash nav, sunroof, rear dvd, leather (came with some wood too ).Socal Diesel ECM- 125hp tune with EGR off, DPF off, Speed Limiter off. custom 6in stacks 1in apart on pass. sideResonator blocked off 2004.5 Ugly Red Dodge 1 ton DRW -Full billet auto with triple disk torque converter, Quad Race Box, Crazy larry, F1 flux 2 injectors, PPE 150gph adj pump with GDP filters, Volant stg 2, 5 inch turbo back with 9 inch black tip 1995 Desert Copper Ford F-350 Single Cab Long bed- Mint with just a few mods, Bullhauler stacks and 305 BFG MTs 2004.5 white lly zf-6 flatbed dually mp-8,ppe race valv,s&b stg2,resonator blocked off,leds everywhere, muffler and cat delete
I think you give too much reason to their ineptitude. One of my pet peeves with these tire places is they simply refuse to look at the tire they're servicing.
Why in the hell would someone think I want 45psi in any 10-ply tire on the truck or trailer? It has gotten me into some tough situations in the past, not realizing their mistake until I have 20k lbs loaded. This after explicitly stating the pressure I desired in the tires.
I carry an air compressor now so, not such a problem anymore.
Now after rotations, I just have 'em leave the pressure alone and put the wheel caps and beauty rings in the back of the truck. I adjust the pressure properly at the shop when they're cold, and re-install the wheel caps WITHOUT stripping out the plastic lug nut caps, another peeve on mine! An impact wrench on PLASTIC caps, sheesh!
__________________ 2005 Chev Duramax/Allison 3500LS DRW Crew Cab
Pulling 10 tons daily.
2006 Chev 6.0L/4L80e 3500WT DRW Ex-Cab
Pulling 6 tons daily.
"The difference between liberals and cannibals, is that cannibals eat only their enemies." -Lyndon B.Johnson 100th
I also have the 08 cc stock reg box, im around 16 mpg around town,manual calc after the last 2 fill ups and dead on with comp. took a ride up the pa turn pike and reset instant econo and after about 15 miles it settled in at 21.5, are you finding the same and should i expect to get better milage as the truck breaks in?
