Old 11-03-2009, 08:18 AM   eBay Motors   #21 (permalink)
D_R_C
D_R_C's Avatar
Originally Posted by Hondarider552 View Post
You were not getting almost 21mpg.
Remember a 6 speed drops rpm by 300.
31.44" tall tires for me and im running at 2k at 75mph.
I see in your sig you state that 11.99 is 1 second faster than 12.00
11.99 is actually 0.01 second faster than 12.00
2007.5 GMC Sierra 3500 SRW BLACK,SLT,C.C.,4X4Loaded,DMax,(except for a aFe OEM airfilter part # 71-10101 Complete stock air intake mod, deleted the restricted muffler),Allison,Westach single gauge combo reading EGT/Boost egts from the pass. side, BD Manifold EGT readings drivers side on the Edge Insight, Rear Firestone Air bags with incab controller,back-up sensors, Back-up camera monitoring thru the nav monitor same as factory.
Security System Clifford Matrix 50.7 2 way remote with LCD.
"Nitto Terra Grappler" 285-70R-17
Oil used http://www.castrol.com/castrol/secti...tentId=7020026
D_R_C is offline   Reply With Quote
Old 11-03-2009, 08:31 AM   eBay Motors   #22 (permalink)
TANK222
TANK222's Avatar
My last tank I got 7.1 mpg had my foot in it the whole 197 miles, when i drove the truck back from fla i was getting around 14 now with the new exhaust i'll baby it this tank and see what i can get.
2008 2500 NEVER ENOUGH.
TANK222 is offline   Reply With Quote
Old 11-03-2009, 11:15 AM   eBay Motors   #23 (permalink)
rubicons4
rubicons4's Avatar
I got about 15.4 hand calc with 325/60/20's and a 6" lift towing about 6500lbs. From Seattle to Lake Tahoe and back. Not bad.
GMC LMM
6" Fabtech w/325/60/20's
Cog braces
Sleeves
5000k HIDs
rubicons4 is offline   Reply With Quote
Old 11-03-2009, 11:49 AM   eBay Motors   #24 (permalink)
Chazm107
Chazm107's Avatar
im seeing 15.5 in city and 17.5-18 cruising on the highway about 1800rpm on 325/50/22 nitto terragrappler a/t
05 Silverado Crew Short Bed LLY,6" superlift, 22" dubs
35" nitto Terra Grapplers AT,AFE Stage 2 W/pro guard 7
Lbz mouth piece,fuel Rail shimmed,5" Mbrp turbo back cat delete with 6" tip
Diamond eye down pipe
Autometer phantom gauges, trans go shift kit
Mag hytec deep trans pan, BD manifold, egr blocked no fingerstick
Pcv reroute,PPE standard, kennedy diesel boost stick
Chazm107 is offline   Reply With Quote
Old 11-03-2009, 11:55 AM   eBay Motors   #25 (permalink)
smokin'LMM
smokin'LMM's Avatar
7.1? i get 10 pulling my 12k toy hauler at 64... without the trailer i can squeeze 16-18 going around 71 with my PPE on level 4. I want to re gear it soon since even going 70 my rpms are around 1500-1600.
09 white on black CC/SB LTZ loaded.
RPB grill, 6k HIDs hi/low and fogs, pyro/boost gauges, 7-9" cognito, air bags w/compressor, train horns, 20" rockstars, 35" toyo MTs, 5% tint, AMP steps, DPF DELETE, 5" magnaflow w/ RPB tip all gone but the muffler, AFE intake, two JL 10's, all new interior speakers, PPE HOT, titan tank, bed liner, 10inch adjustable drop hitch, and more to come!
smokin'LMM is offline   Reply With Quote
Old 11-03-2009, 01:42 PM   eBay Motors   #26 (permalink)
TANK222
TANK222's Avatar
Sucks right.
