Old 06-28-2009, 09:55 PM   eBay Motors   #1 (permalink)
Duramax09
Duramax09's Avatar
Tranny is already slipping
I just recently bought my dmax about a month ago and it had about 2,200 miles on it when I deleted the dpf on it and installed the edge. I now have 3,000 miles on it and the tranny is already slipping which is very disappointing to me especially since I don't drive it like I stole it lol. I never ran the edge over level 3 which is recommended for a stock truck. Any suggestions on what I should do bc I might put the transgo jr. in it but Im just worried that it might be to late. Any help is appreciated thanks.
Duramax09 is offline   Reply With Quote
Old 06-28-2009, 10:00 PM   eBay Motors   #2 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
What are the codes?
Hondarider552 is online now   Reply With Quote
Old 06-28-2009, 10:12 PM   eBay Motors   #3 (permalink)
04LB7DmaX
04LB7DmaX's Avatar
when is it slipping? what speeds and gears? haha and hondarider, those quotes are hilarious, haha
-2004 LB7, Ext. Cab S/B, LT
-6" Tough Country Suspension Lift
-35" Toyo Open Country M/T
-18x9 KMC XD MONSTERS (Black)
-PPE Standard Xcelerator
-Auto Meter Cobalt Gauges Pyro/Boost
-AEM Brute Force Air Intake
-MBRP 4" Straight Pipe Exhaust w/ MBRP 5" Black Tip
-Buckstop Front/Rear Bumpers
-N-Fab Side Steps
-ProTech Headache Rack (Line-X'd)
04LB7DmaX is offline   Reply With Quote
Old 06-28-2009, 10:13 PM   eBay Motors   #4 (permalink)
Duramax09
Duramax09's Avatar
There is no code. it just really feels noticeable during the shifts.
Old 06-28-2009, 10:15 PM   eBay Motors   #5 (permalink)
midieselguy
midieselguy's Avatar
It's probably the tuner de-fueling between shifts. You will notice a lag between gears as you shift through them.
2004.5 LLY, X-Cab, short-bed, Allison Trans, 4" MBRP Turbo-back, no cat, KB's IOH kit, EGR block plate, no finger stick, MB Razor 16x8 with BFG AT 285's
midieselguy is offline   Reply With Quote
Old 06-28-2009, 10:17 PM   eBay Motors   #6 (permalink)
Duramax09
Duramax09's Avatar
Yeah but it never did it whenever I first put the programmer in
Old 06-28-2009, 10:35 PM   eBay Motors   #7 (permalink)
subparwelder
subparwelder's Avatar
Will they always throw a code on a slip?
08 GMC SIERRA SLT CREW SHORT BOX Z71
6'' BDS LIFT 20'' KMC XD HOSS'S W/33'' TERRA GRAPPLERS
5'' TURBO BACK MAGNAFLOW STRAIGHT PIPED
EFI BY IDAHOROB
TRANSGO JR AND MAG DEEP PAN
ALL AMSOIL FLUIDS
subparwelder is offline   Reply With Quote
Old 06-28-2009, 10:36 PM   eBay Motors   #8 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
it might be the allison learning the higher power level. If you have no codes, it might not be slipping. How many miles? have you changed the tranny spin-on? how many miles on the fuel filter?
Old 06-28-2009, 10:41 PM   eBay Motors   #9 (permalink)
04LB7DmaX
04LB7DmaX's Avatar
might just be relearning the increased HP, should throw a code if its slipping.
-N-Fab Side Steps
Old 06-28-2009, 10:42 PM   eBay Motors   #10 (permalink)
Hondarider552
IIRC, allisons will have to slip 6% in order to limp and set a P07XX code. Yes, it can slip without throwing a code, but your doing damage.
Turn the edge down.
