Old 07-09-2009, 03:55 PM   eBay Motors   #1 (permalink)
N2BRK's Avatar
mopar synthetic gear lube 75w-140 in axles ok?
I don't see any reason why not, but I thought I'd ask.
I have a line on 5 quarts dirt cheap and was thinking about buying them for my upcoming differential fluid change.
2008 Chevy Duramax 2500HD, Crew Cab, 4x4
FPRV shim /Transgo Jr.
Boulder H2 Forged Chrome Rims 265/70/17
MBRP 4" turbo-back
cognito braces
Rough Country Sleeves
EFI Live re-tuned by Idaho-ROB DSP5
Super Diesel 1.5" dia SS center link
Henderson's SuperSteer Idler Bracket/brace
EGR block plate
N2BRK is offline   Reply With Quote
Old 07-09-2009, 07:22 PM   eBay Motors   #2 (permalink)
Racerngr1's Avatar
75-140 is a pretty thick fluid, maybe if you are doing alot of heavy towing in high heat then go to the 140. I run the 75-110 Severe Gear in my truck and I tow back and forth to Havasu alot in the summer when it's 110* out and it seems to work really well with the 75-90 Severe Gear in front. Let me know if I can set you up with the Amsoil.
2008 Chevy 2500 LMM
RCD Lift
18" XD Hoss Wheels
325/60/18 Terra Grapplers
Edge Evo set to Level 1
AIM = Racerngr1
ZO# 1698533
Racerngr1 is offline   Reply With Quote
Old 07-09-2009, 07:25 PM   eBay Motors   #3 (permalink)
It'll work if the price is right. Not many run the 140, but nothing says you can't.
Heath is offline   Reply With Quote
Old 07-09-2009, 11:35 PM   eBay Motors   #4 (permalink)
Racerngr1's Avatar
It's not that it won't work, but there are other things that will work better in his truck. 75-140 is very thick and in turn will decrease his mpg's a little. Will it work, yes.
2008 Chevy 2500 LMM
RCD Lift
18" XD Hoss Wheels
AIM = Racerngr1
ZO# 1698533
Old 07-10-2009, 12:56 AM   eBay Motors   #5 (permalink)
bigdaddydiesel's Avatar
If that is what you want to run then you will be fine with it....
Chris Kelley
'03 GMC 2500HD 4x4 extcb sb sle
AMSOIL Direct Jobber ZO # 1678239
Toll Free (888) 563-5143
email
Become A Dealer
Online Catalog
Old 07-10-2009, 09:11 AM   eBay Motors   #6 (permalink)
N2BRK's Avatar
good info guys - thanks.
I did some looking and realize now that the OEM fill of 75w-90 is synthetic. I thought it was conventional, and 75w-140 in a synthetic would be just fine. I'm thinking now that living in NJ it gets cold enough for me to stick with a synthetic 75w-90 and not the thicker offerings; besides the fact that I rarely tow any serious weight.
MBRP 4" turbo-back
cognito braces
EGR block plate
Old 07-10-2009, 09:24 AM   eBay Motors   #7 (permalink)
GWEEDO!!!!
RedBowTies88's Avatar
i ran 75w-140 full synthetic. and just recently bew a rear anyone think it contributed??? i always thought that was the best to run cause all the full synthetics that were at the store were that weight. I'll be an SOB if that's what just cost me 900
Beech (thats my real name) EfiLive by Nick@duramaxtuner, likes to go fast
CC/SB LLBYE
Originally Posted by DMAXchris View Post
No one ever said anything about lube or salami you sick bastard.
Old 07-10-2009, 09:25 AM   eBay Motors   #8 (permalink)
GWEEDO!!!!
blew up***
CC/SB LLBYE
Old 07-10-2009, 06:53 PM   eBay Motors   #9 (permalink)
N2BRK's Avatar
no way. If anything it gave you longer life, IMHO. I decided against since I do a lot of short commuting in the cold with mine (daily driver and 5mi commute to work). Even so, it's prolly still fine for me to use. Synthetics rely on surface tension and not viscosity, and I think either weight would have enough of a film on the surfaces to work just fine. The 75w-90 might give a slight advantage in short trips on cold days to flow a little better a little sooner, but the 75w-140 would give better protection when you're beating on it
MBRP 4" turbo-back
cognito braces
EGR block plate
Old 07-10-2009, 07:10 PM   eBay Motors   #10 (permalink)
I doubt very seriously if the lube in your rear actually caused it to blow up.
Chris Kelley
email
Become A Dealer
Online Catalog
