Old 09-15-2009, 07:45 PM   eBay Motors   #1 (permalink)
JuniorDiesel
JuniorDiesel's Avatar
Transmission "Clapping" Noise
Sometimes when I take my shifter from (P)ark to (D)rive or vise versa the transmission seems to make a clapping noise like metal on metal. This doesn't happen all the time, but curious what it could be and if I should be concerned about it.
2007.5 Silverado 2500HD LMM
Edge Evo CTS
MBRP 4" DPF back exhaust, H.I.Ds, Billstien 5100's ON THE WAY
AMSOIL
http://www.lb7.info/
http://www.syntheticmotorsports.org/
Toys:
2008 38' Heartland Cyclone Toyhauler
2008 Raptor 700R - FCI intake, DRD exhaust, PCV
JuniorDiesel is offline   Reply With Quote
Old 09-17-2009, 09:39 PM   eBay Motors   #2 (permalink)
lone Ranger
Hello Junior Diesel,
Look, I am no expert on this transmission. But I did get a shudder in mine under heavy load because I was not in Tow/Haul mode, and it felt like clutch pack slipping... I don't know what you mean by clapping, but this was a da-da-da-da short interval shudder of clutch packs slipping, before I let off and switched on the Tow/Haul mode....
If you have the Edge with Attitude (I have had it, Platinum, on a King Ranch F-350) anyway if you have it and have been running on the high end of things on power, it could be your transmission slipping/ with a shudder you can feel. If it happens with some frequency, and is dependable, I would get it into a transmission Shop right away for them to have a listen....
Clutch packs slipping, can be the final stage before a total failure. Check the oil and see if it is clean and clear, and make sure it does smell burnt... But anyway, this is just a guess... Rule it out...
Otherwise, It could just be a bang of some engine part clearance as the engine torques, as it twists on the mounts, something could be hitting the chassis or something else. If it is not a transmission shudder, Crawl around under and over and you will probably find a minimum clearance somewhere causing a metal to metal banging away rattle... As you put it into drive or out, and the motor flexes on its mounts... Rattle rattle at low RPM, something in the exhaust hitting somewhere. That is the easiest and best thing it could be..
Good luck..
lone Ranger is offline   Reply With Quote
Old 09-17-2009, 10:40 PM   eBay Motors   #3 (permalink)
HumboldtDmax
Obama stole my rims
HumboldtDmax's Avatar
Sounds like that tranny has the clap..........drum roll please
might just be what typically happens when the tranny is under load coming out of park(not parked on a level surface) if thats what it is you have nothing to worry about
7.5 LMM CHEVY CC LT Z71 white
Fab Four front bumper, lots of Line-X
Rancho 4in w/Bilstiens, HD tie rods and braces
35x12.5 Toyo MT on 20x10x4.5BS KMC Monsters in black
[BANKS intake,dual exhaust,intercooler]straight piped
BD manifold,Fitch fuel catalyst,res mod,EGR delete
AFE turbo tube, PPE race fuel valve
EFI live, Edge Insight
AD150 & SC4 collecting dust in the shop
HumboldtDmax is offline   Reply With Quote
Old 09-17-2009, 10:51 PM   eBay Motors   #4 (permalink)
radioman990
Junior
Mine does the same thing. Also a little concerned. If I go to neutral first it never does it. Only from drive to park. When I asked the dealer about it he said HUH!! Hope we are talking about the same thing.
radioman990 is offline   Reply With Quote
Old 09-18-2009, 08:58 AM   eBay Motors   #5 (permalink)
JuniorDiesel
That is exactly when it happens!! Thank you for verifying what I was thinking!
RADIOMAN
What I started doing the other day, and probably should always do, is when I park on anything that is not level I engage the emergency brake before putting it into park. That way when I do put it in park it doesn't drift forward or backward and put a load on the transmission.
Edge Evo CTS
AMSOIL
Toys:
Old 09-18-2009, 01:57 PM   eBay Motors   #6 (permalink)
Justgurn
Just this week I took my 08 in to check the clapping noise going from drive to park. I took the tranny tech out with me so he could hear the sound. He said the parking paw pin was not quit aligned with the star wheel causing the noise. He was going to check on updates to resolve but felt there was nothing wrong. The tech did tell me that the Allison operates at a very pressures and makes some noise at times.
Justgurn is offline   Reply With Quote
Old 09-18-2009, 02:05 PM   eBay Motors   #7 (permalink)
seth999
Duramax Forum Moderator
seth999's Avatar
yeah mine does this too sometimes because with the big wheels and tires even a small incline puts it in alot of stress...try putting on the e-brake before you put it in park then try it that should take the load off the tranny
DD
08" chevy 2500HD cc short bed LTZ
9" fabtech lift/AMP steps
burnt orange paint job
Transgo jr.--Ali is Burnt
5" MBRP Turbo Back--MBRP Downpipe
EFIlive by IdahoRob--DSP 5
Snow Stage 3 Water/Meth
Banks Intake
PPE Lift Pump--Rail Shim--Ported Rail Fitting
seth999 is offline   Reply With Quote
Old 09-18-2009, 02:29 PM   eBay Motors   #8 (permalink)
rap2orrider660R
Serving the Oil Industry
rap2orrider660R's Avatar
Here is what I do, and it had totally eliminated the shutter sound. From "Drive" I apply the regular brakes, then shift to "Neutral" then apply the "E-Brake" then shift to park. I only do this procedure on inclines, and works great to totally relive the pressure on the transmission.
Aaron Blackwell
Cen-Tex Marine
Proudly Serving the Marine and Oil Industry
2007.5 D-MAX, EDGE DIGITAL GAUGES, QUADZILLA WITH DPF DELETE, TUNED AT 90HP NO MORE NO LESS, STRAIGHT PIPED, 17" CHROME SHAKER RIMS WITH 285 70 17 BFG KM2 MUD TERRAIN TIRES, AIR BOX MODIFIED,BUSHWACKER BED CAPS, RECON SMOKED LOW PROFILE CAB LIGHTS AND MORE TO COME (I HOPE)
rap2orrider660R is offline   Reply With Quote
Old 11-05-2009, 08:03 PM   eBay Motors   #9 (permalink)
DuramaxNoKaOi
Any chance you are hearing your exhaust clapping? I used to hear my old LB7 do that that had aftermarket exhaust.
06 ec/sb 4WD
DuramaxNoKaOi is offline   Reply With Quote
Old 11-06-2009, 07:28 AM   eBay Motors   #10 (permalink)
Beaner242
Beaner242's Avatar
Mine does this from time to time when shifting into park. I agree its the shifter pawl falling into place, I dont really worry about it anymore.
08 GMC Sierra
Summit White
Crew Cab
30% Tint
Edge Race
MBRP 4"
Go Rhino Steps
Beaner242 is offline   Reply With Quote
