Old 11-02-2009, 07:32 PM   eBay Motors   #11 (permalink)
TANK222
TANK222's Avatar
How do I check the drive shaft carrier?
2008 2500 NEVER ENOUGH.
TANK222 is offline   Reply With Quote
Old 11-02-2009, 07:34 PM   eBay Motors   #12 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
crawl underneath your truck and look at it.. check for loose bolts holding the carrier to the frame and check ujoint play.
Old 11-02-2009, 07:34 PM   eBay Motors   #13 (permalink)
WOLFN8TR
WOLFN8TR's Avatar
I have the same exact vibration. It's very annoying! I'm taking my truck in to get the tires balanced and rotated tomorrow, will let you know if it does the trick.
"GARY"
2007.5 Chevy Silverado 2500HD LTZ (LMM), 6" Superlift with 35" Pro Comp's, 18" Mazzi's, 5% TinT, Amp Research Steps, Billet Grille insert, Jimmi Jammer.
WOLFN8TR is offline   Reply With Quote
Old 11-02-2009, 07:35 PM   eBay Motors   #14 (permalink)
joelsmith
the king
u may just need a rotate and balance and if it isnt that u arent out much more then 20 dollars
03 2500hd dual black six inch miters, intake, ppe hot, pro comp extreme at, airdog 150, glowshift gauges, and billet ats stage three tranny
244k
next ill be gettin efi live, tie rod sleeves, idler and pitman arm braces, and a new center link
and lookin at a fleece turbo
and im gonna put new injectors in when i do that
joelsmith is offline   Reply With Quote
Old 11-02-2009, 07:35 PM   eBay Motors   #15 (permalink)
blackdeath
blackdeath's Avatar
i got a vibration at those speeds , from my cv axles being pulled out to much, , checks ur tires first
2008 silverado dmax LTZ, aFe stage 2,race tune from idahorob,EFI LIVE, AD 150 lift , ppe shim kit,dpf delete,EGR block off plate,autometer gauges (cobalt) boost and pyro,transgo jr,6"fabtech with maxxcams and 2"addleaf,fabtech tierods,37"procomp 20" boyd wheels. 5% tint all around,5"grandrock stack kit,straight piped, custom painted dash panel,SCIV coming maybe
2008 trailblazer ss, straight pipe ,jetttstream air intake,iat relocate kit,efi tuned , 3" lowered
blackdeath is offline   Reply With Quote
Old 11-02-2009, 07:41 PM   eBay Motors   #16 (permalink)
tate07lbz
tate07lbz's Avatar
id bet its a u joint or maybe a tire that is out of round
07.5 chevy LMM quad cab stock for now. my wife doesnt need any more power.
07 ChevyClassic LBZ. Quadzilla stealth 2 tuner, stock straight piped,K&N cool air intake,lots of chrome looking for a new set of wheels
04 chevy lb7 dually hypertech tuner, straight pipe, Dew eze hay bed
tate07lbz is offline   Reply With Quote
Old 11-02-2009, 07:43 PM   eBay Motors   #17 (permalink)
TANK222
TANK222's Avatar
Ok i'll check the carrier in the am and for tires hope fully i'll be ordering some 37's by the end of the week so these will come off any way.
Old 11-02-2009, 07:43 PM   eBay Motors   #18 (permalink)
dhaile
I had the exact same problem with my stock wheels and tires and it went away with my new set of wheels and tires. Probably just needs a good balance.
09 chevy 2500HD Duramax LT w Leather PPE HOT +2, MagnaFlo SS 4'', DPF Deleted, EGR Blocked! Granite Alloy GA7 20x9 LT275/65R-20 Goodyear Wrangler AT/S E
dhaile is offline   Reply With Quote
Old 11-03-2009, 07:25 PM   eBay Motors   #19 (permalink)
WOLFN8TR
WOLFN8TR's Avatar
Vibration
Took the truck in for tire balancing and rotation. Each tire needed 2.5 oz of weights. One tire was slightly out of round, and he said both upper ball joints were slightly worn. I use to go thru a set of upper ball joints every two years on my 97 lifted Chevy, here we go again . So $50 dollars later rollin' home it was money well spent! I would say 80% of the vibration is gone. New ball joints are on the to do list.
"GARY"
Old 11-03-2009, 07:41 PM   eBay Motors   #20 (permalink)
rabb11d
rabb11d's Avatar
might read up on this. new rear mounts going on mine this week.
http://www.duramaxforum.com/forum/exterior/32989-frame-beaming-gm-campain-pit3009j.html[/url]
2007.5 Chevy 2500 CCSB
Rancho Lift - 33" Procomp Xtreme All terrains
rabb11d is offline   Reply With Quote
