Old 11-03-2009, 10:20 AM   eBay Motors   #1 (permalink)
rap2orrider660R
Serving the Oil Industry
rap2orrider660R's Avatar
Exclamation Torque Converter Vibration
Ok, here is my question. While driving with very little acceleration, I go through the gears getting up to highway speeds (70mph), the converter locks in 5th gear, everything seems fine. Now with me doing the same thing but with about half throttle as the TC locks in it feel like it is vibrating as it it locking in with the extra fuel. All of my specs are listed below in my signature, and I have not had any check engine lights or reduced power problems. Sometimes it does this vibration when the TC is already locked in, like in 6th gear and I give it some throttle and I fill the vibration. Anyone experence any of this or know what this is ??
Thanks,
Aaron Blackwell
Cen-Tex Marine
Proudly Serving the Marine and Oil Industry
2007.5 D-MAX, EDGE DIGITAL GAUGES, QUADZILLA WITH DPF DELETE, TUNED AT 90HP NO MORE NO LESS, STRAIGHT PIPED, 17" CHROME SHAKER RIMS WITH 285 70 17 BFG KM2 MUD TERRAIN TIRES, AIR BOX MODIFIED,BUSHWACKER BED CAPS, RECON SMOKED LOW PROFILE CAB LIGHTS AND MORE TO COME (I HOPE)
rap2orrider660R is offline   Reply With Quote
Old 11-03-2009, 10:33 AM   eBay Motors   #2 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
turn the power down a notch or 2 and see if it still happens, might be your converter ballooning.
Old 11-03-2009, 10:37 AM   eBay Motors   #3 (permalink)
RedBowTies88
RedBowTies88's Avatar
i wouldn't think it would balloon with less throttle input then when it is smooth....
this sounds like a mike L question
LLY Cc/sb 4x4 RED
Originally Posted by Sean S
Originally Posted by McRat
Old 11-06-2009, 08:46 AM   eBay Motors   #4 (permalink)
setexan
setexan's Avatar
I’m not sure if mine is doing the same thing as yours but, my truck is acting up too. When I drive around 55mph the transmission shifts into 6th gear and then shudders around 1500 rpm. It is more noticeable at 55 but seems to happen around 1500 rpm in 5th and 6th gear. I have been keeping it out of 6th gear when driving that slow but; have been wondering if it is a serious problem. It seems with the tuner the trans doesn’t want to down shift as often. My truck does this regardless of what tune is in it even with stock tune. It began happening when I deleted the dpf so, the small amount of added power from removing the stock restrictive exhaust might have been enough to cause this but hope there is an easy solution. Will the transgo jr kit fix this and what is the transgo jr kit for.
2008 Chevy cc Dually 4x4 LMM LTZ
B&W Hide a Ball w/5th wheel companion, Ranch Hand Front End Replacment, MBRP 4" Duals, Quadzilla Stealth 2, EGR Blocker Plate and NO DPF!!!
2007 Ford F350 cc Fx4 PowerJoke (Could not get rid of fast enough what a gutless piece of junk)
2001 Chevy 2500 4x4 LB7 (Traded for the piece of junk Ford)
2005 New Holland TD48A
setexan is offline   Reply With Quote
Old 11-08-2009, 10:01 AM   eBay Motors   #5 (permalink)
setexan
setexan's Avatar
Nobody has any advice for me or rap?
Old 11-09-2009, 12:11 PM   eBay Motors   #6 (permalink)
JDT4430
JDT4430's Avatar
It must be a texas thing because I am getting the shudder feeling when the tourge converter locks also. Any help is appreciated.
2009 SWB C/C Z71 2500HD
EDGE EVO RACE
SILVERLINE 4" TURBO BACK
B&W Turnover GN Hitch
EGR Blocked
For all your wheel and tire needs www.discounttiredirect.com
www.huskerdiesel.com
JDT4430 is offline   Reply With Quote
Old 11-15-2009, 07:04 PM   eBay Motors   #7 (permalink)
setexan
setexan's Avatar
I reset my tranny with my programmer this morning and put it back to stock/no DPF. It seemed to help a little but, is still shuddering.
Old 11-15-2009, 07:07 PM   eBay Motors   #8 (permalink)
setexan
setexan's Avatar
Who is Mike L and how can we get a hold of him. I'm starting to think the problem might cause tranny failure while towing.
Thanks in Advance
Old 11-15-2009, 07:13 PM   eBay Motors   #9 (permalink)
jaglmm
Diesel Addict
jaglmm's Avatar
what your feeling is torque converter shutter.. i bet you dont feel it in tow haul because the shift points are much more agressive and the converter locks up earlier..
mine did the same thing.. BAD.. i mean horrible, i thought i ruin my transmission..
then i reset it.. did a tranny learn .. and all is well!!
and i just dynoed yesterday 473h.p/1038ft lbs and transmission is doing GREAT
07.5 LTZ
473h.p/1038lbs of torque 11-14-2009
Suspension: 6inch Rough Country w/ Shocks
Wheels: 37x13.50 Super Swamper M16's on 22x11 Black Monsters
Programmer: EFI Live
Exhaust: MBRP DPF back stack kit, 6inch Black Stack, DPF delete, Lost Kitty
Lift Pump: Airdogg 150
Intake: S and B
Gauges: Triple Pillar w/ EGT, Boost, Fuel Pressure
Other Mods: Aem water/meth, Trans Go Jr, Fabtech Tierods, EGR blockoffplate, PPE shim kit
jaglmm is offline   Reply With Quote
Old 11-17-2009, 05:42 AM   eBay Motors   #10 (permalink)
setexan
setexan's Avatar
Each day it gets better and better so, I guess reset the tranny seemed to work
