07.5+ LMM Duramax PowertrainDiscussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect
I found this under the hood and think that it indicates there is a leak of some kind. Don't bash me too hard, I'm no mechanic. Is this a problem? Do I need to do something about it?
__________________ Chase
LMM
EFI Live
Dpf and Egr Deleted
Trans Go Jr
You can get much farther with a kind word and a gun than you can with a kind word alone.
MPF ALL IN ONE LOGISTICS LLC
A even quicker fix is to take the rubber connector off, and wash it in good soapy water, dry it, and spray some hairspray in the inside where it is going to contact the CAC tubing. Next tighten the clamps real good and WALAH!!! If you can leak oil, there is a good chance you are leaking Boost as well "oil is thicker than air".
__________________ Jim
4" Magnaflow Exhaust
Modified factory air box
Ported Turbo Horn
EFI LIVE V2 www.performancetruckproducts.com
Are you talking about the rubber connector shown in my picture? Is this where the stuff is coming from or is it from the adjacent "T" shown in the PCV mod thread?
__________________ 2007 Chevy 2500HD Duramax Diesel LMM, 4x4, Crew Cab, Leer Shell, Bed Rug, Side Steps, 265 BFG AT-KO
Another question. What type of product should I use to clean this greasy stuff up? After I do the PCV re-route of course.
Just use some good old dish soap and hot water. If you are waiting to do the PVC, you can at least try and tighten the clamps. It will only take a couple minutes.
One thing that is goofy though is I have 199k PVC still hooked up miles on mine and it has no where near that amount of blow by! Heck I had my CAC out for over a day, tipped it up so any oil that was in there would come out, and nothing ever came out. My boost tubes and dry and clean as well. So why do some Dmax's have so much oil in the CAC system from the PVC and some do not???????????
Ported Turbo Horn
Yours is most likely coming from the rubber connector. I have never looked into the PVC reroute
Ported Turbo Horn
