Old 11-19-2009, 03:24 AM   eBay Motors  #1 (permalink)
Synthetic Oil
Probably a dumb question; but I hear different things:
Atwhat point can I start using good synthetic oil? I have 5,000 miles on my 09 GMC Dmax. Also, any suggestions? I see alot of people use AMSOIL...is it worth the money?
2009 BLK, Crew, GMC, SLT, DMAX.
Skyjacker level kit
First Sergeant
US Army
jbake is offline   Reply With Quote
Old 11-19-2009, 03:33 AM   eBay Motors  #2 (permalink)
Your #1 Source For Amsoil
Dirtbikindad393's Avatar
Now is a great time to start with 5k miles on the truck. You have to do your own research and decide if its worth it to you. That has to be based on miles per year driven, cost, and benefits.
Benefits of using synthetics: extended oil change intervals, lower pour points for cold weather starts, higher temperature stabilization for hot weather, less friction, increased fuel mileage to name a few.
I sent you a PM on my Amsoil offer.
Madjack Racing & Synthetics
www.Madjacksynthetics.com
Your #1 Source For Amsoil And Discount Diesel Parts
Racor Fuel Filter
LMM & Classic Fuel Filter Door
Fumoto Valves
PPE WIF Wrenches
Credit Cards Accepted
Dirtbikindad393 is offline   Reply With Quote
Old 11-19-2009, 03:34 AM   eBay Motors  #3 (permalink)
JuniorDiesel's Avatar
Each product has it's own following here so you will get a variaty of answers to that question. I use AMSOIL and love it. If you have any questions about Amsoil and what it can do for you, feel free to PM bigdaddydiesel, mrmanners, or chevy*tough on this forum. They will get you hooked up!
2007.5 Silverado 2500HD LMM
MBRP 4" DPF back exhaust, H.I.Ds, Billstien 5100's, 18" XD Monsters WAITING FOR SOME TIRES!!
AMSOIL
www.syntheticmotorsports.org
JuniorDiesel is offline   Reply With Quote
Old 11-19-2009, 03:42 AM   eBay Motors  #4 (permalink)
AMSOIL Direct Dealer
mrmanners's Avatar
You can start on your first oil change. There are a lot of view points and everyone seems to have a favorite. IMHO AMSOIL is worth the money. AMSOIL uses only the best chemical base stocks and additives to create their products. They are designed to save the customer money. The benefits of AMSOIL include better performance, smoother running, excellent cold flow charateristics for cold morning starts, better fuel economy and extended drain intervals (3xOEM or 1 year whichever comes first).
Let me caveat that drain interval for the 2007 and newer light duty diesels with DPFs. AMSOIL is now recommending OEM drain intervals unless you are conducting oil analysis. Reason behind this is that manufacturers are starting to see issues with fuel dilution in the motor oil of 2007 and newer light duty diesel engines and CAT C13 and C15 engines with DPF.
Here is some more information about it from a thread we started a month or so ago and updated again this last week.
In a Technical Bulletin updated last week they stated that AMSOIL is saying their additives are holding up under the dilution under the maximum amount of 5% dilution and that the oil analysis is simply a precaution to make sure that the vehicle you are running is not having more dilution than another.
If you are running your truck hard, towing on a regular basis with operating temps running at a higher level, it will commonly burn out the contaminants in the DPF with Passive Regeneration.
The daily drivers, those that only see about 5-50 miles per day of commuting will go into the Active Regeneration process to clean out the DPF by dumping raw fuel into the exhaust stroke of the cycle in an attempt to allow hot exhaust gases to ignite the dumped fuel to burn out the soot collected in the DPF.
Bottom line if you have a DPF and it is a daily driver you run a higher risk of active regeneration and fuel dilution.
If you are planning on modding your truck and losing the DPF, this issue no longer is a problem for you and you can run AMSOIL at the 3XOEM recommendation or 1 year whichever comes first.
Oil analysis is a good thing and recommended for any diesel owner to ensure the quality of your motor oil and to help identify potential problems, beyond fuel dilution.
Probably way more information than you wanted. AMSOIL offers a full line of products for your vehicle and through the preferred customer program I can save 25-35% off retail prices. If I can provide you further information, just PM me.
Take care,
Willie Parsons
06 CCSB LLY, LT3, Edge Evolution Level 3
mrmanners is offline   Reply With Quote
Old 11-19-2009, 04:43 AM   eBay Motors  #5 (permalink)
boccheballs's Avatar
make sure and sign up with one of these guys before you buy amsoil because it knocks the price way down! its worth the 10.00 for 6 months or 20.00 for the year!
07' CLASSIC LBZ, 3LT, EFI LIVE W/DSP5 BY IDAHOROB , COGNITO LEVELING KIT, SS SLEEVES, SS WESTIN NERF BARS, ZINC 5100 BILSTIEN'S, SPEED LINER, 285-70-17 COOPER STT, PPE AIR BOX MOD, EGR BLOCK, TRANSGO JR AND DEEP PAN TRANSYND CONVERSION, 4" MAGNAFLOW SS DOWN PIPE BACK , EDGE INSIGHT W/EGT PROBE.
I'LL KEEP MY FREEDOM, MY GUNS AND MY MONEY AND YOU CAN KEEP YOUR "CHANGE"!!!
http://alligatorperformance.com/
boccheballs is online now   Reply With Quote
Old 12-24-2009, 08:57 AM   eBay Motors  #6 (permalink)
is the royal purple synthetic oil any good? anyone runnin it?
08 2500 black d-max crew cab! k&n air filter and toyo at's 265's
dpf delete and exhaust comin soon!
8racing is offline   Reply With Quote
Old 12-24-2009, 09:12 AM   eBay Motors  #7 (permalink)
mrmanners's Avatar
There are quite a few guys on here running it, AMSOIL, Rotella and Mobile 1.
Let me know if I can help.
Willie Parsons
