07.5+ LMM Duramax PowertrainDiscussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect
Does it log regen events or just the last regen. It would still have to be "regened" within the last 500 miles or so to pass warranty issues if that were the case, but you could reinstall the DPF and drive for 500 miles to create a regen. I don't know just thinking out loud.
I don't think it would help mileage much anyway because the computer is going to regen anyway, but maybe not.
__________________ Had an 04' Duramax LB7 thought i needed a new one.
2009 GMC 2500HD SLT black on black very nice truck.
12500 miles and counting
Stock right now but that will change soon
it counts the regens
LLY Cc/sb 4x4 RED
Originally Posted by Sean S
Originally Posted by McRat
I would never suggest that someone violate federal emission laws, but why wouldn't someone just rod the guts out of the DPF and re-install it?
Nothing inside to collect particles and cause a pressure change signaling a Re-Gen, the empty carcass is in place visually and all of the pieces of the exhaust are rusted the same from road travel.
No bucks spent on aftermarket pipes or tunes, nobody jackin’ with yer warranty and so on.
Gutting it will throw a CEL, You can overheat it and crack the filter material, it will let some of the soot through and still regen aproximatly every 450 miles and not throw a CEL
Not to mention that str8 piping your lmm aint gonna give you the mpg gains that some have reported. You will get 2 at best and that is with a good tuner. If your worried about warranty than LEAVE IT ALONE. If you want to transform your boring good running truck into a 3/4 ton muscle car then just straight pipe it, tune it with efi and look in the mirror at the big smile on your face every time you start it up.
__________________ 08 GMC SIERRA SLT CREW SHORT BOX Z71
6'' BDS LIFT 20'' KMC XD HOSS'S W/33'' TERRA GRAPPLERS
5'' TURBO BACK MAGNAFLOW STRAIGHT PIPED
EFI BY IDAHOROB
TRANSGO JR AND MAG DEEP PAN
ALL AMSOIL FLUIDS
3-4 mpg is average increase with a dpf delete and tune in...
thats a very big difference your talking 20% or more sometimes
LLY Cc/sb 4x4 RED
Have an 2007.5 ran a stock tune with DPF delete (EFI Live) for 5,000 miles. I only saw a 1-2 MPG increase, not worth pulling that thing on and off every year for smog. What it did do is drop my EGT big time.
I'm not the only one that saw these results of only 1-2 MPG. There are some interesting threads on thedieselplace about this.
is most of your problem
LLY Cc/sb 4x4 RED
Even with some of Nick's EFI Live mild tunes I never saw more than 1-2 (hand calculated). There are big positives to removing the DPF but better MPG is not one. But this is only my opinion.
for the most part 95% of the people i talk to on here here have had at least a 3mpg increase with a dpf delete and tune...
i know nick has good tunes so maybe there were outlying factors but i still believe mpg to be a huge reason to ditch the dpf
LLY Cc/sb 4x4 RED
