| Premium Membership | |
| | | 07.5+ LMM Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect |  | |
07-23-2008, 06:19 PM
eBay Motors
#1 (permalink)
| | Junior Member
| onstar cant unlock truck or even locate it Like it says I locked my keys in my truck, so phoned onstar to unlock it. They say they cant find the truck , it is right in a city. is there a fuse or something or can my antenna be broken ? Why does my onstar never work  |
| Advertisement
07-23-2008, 08:03 PM
eBay Motors
#2 (permalink)
| | Senior Member
| Its because your "Big Brother" didn't love you. Think about it.... Did you pay your bill? hahaha. really I like onstar but don't because I don't like knowing someone can unlock my door from 2000miles away for me or someone else.
__________________  04' LB-7 Crew Cab 4x4 SLT Loaded with GM goodies
Amsoil Air Filter in a moded stock air box
Amsoil for Diesels in my motor, Both front and Rear Diff's, Trany and Tranfar case.
Autometer C2 0-35boost and 0-1600temp gauge with Autometer LED gauge lighting Dimmer Control
Copper STT Tires 285/75-R16
PPE Boost valve
Single Flowmaster 4" with a SS 5" tip  Keep America Strong and BUY American made goods with pride! Union Pride!!!  IF YOU DON'T!!! |
07-23-2008, 09:21 PM
eBay Motors
#3 (permalink)
| | Catch Me If You Can!
| Yes there is a fuse under the hood. I don't remember which one it is though.
__________________ KYLE
07-24-2008, 04:29 AM
eBay Motors
#4 (permalink)
| | DuramaxForum Veteran
| If you are parked under a thick tree or any kind of structure you are up a Creek. If your anteanna cannot see the sky you cannot be traced.
__________________ 06 2500 CREW CAB 4X4 LBZ
4" DIAMOND EYE EXHAUST, KITTY RAN OFF!!!
DIABLO @ 120HP. 285/75 BFG's RUNNIN ON ULTRA 16's
PIONEER HEAD UNIT RUNNIN SCOSCHE AMP W MTX TWINS
AIR BOX IMPELLER REMOVED!! RESONATOR PLUGGED !!!
AUTOMETER ULTRALITE GAUGES IN POD. TRANSGO JR WORK RIG
O7.5 3500 CREW, LMM, ROYAL UTILITY BED
4" DIAMOND EYE EXHAUST.DPF???KITTY?? QUADZILLA PROGRAMMER. MTX AMP AND 10" TWINS IN THE BACK. STEPS,VISORS,BUG SHEILD. AIRBOX IMPELLER REMOVED,RESONATOR PLUGGED,LOTS OF PRETTY DIAMOND PLATE EVERYWHERE |
07-24-2008, 09:56 AM
eBay Motors
#5 (permalink)
| It could be the same as it is for XM, I had XM for a while and it would cut out whenever i went by a tall building. Never had problems with trees, but anything big and tall, blocking the view to the south would make it cut out til I went past it. Since onstar is satellite run, its probably the same. Either your fuse is out, or the satellite couldn't see you. |
07-24-2008, 10:46 AM
eBay Motors
#6 (permalink)
| | Member
| Quote:
Originally Posted by albertaboy Like it says I locked my keys in my truck, so phoned onstar to unlock it. They say they cant find the truck , it is right in a city. is there a fuse or something or can my antenna be broken ? Why does my onstar never work  | Ever since the computer reflash, my Onstar cannot read the diagnostics on the truck. The phone works, and they can read the mileage and oil life. I have the dealer checking to see what they need to do to make it work again.
__________________ 2007.5 2500HD LMM, AEM air intake, 5 inch DPF back MBRP exhaust w/6 inch tip, Banks Ottomind6 Power Pack, ARE tonneau cover, Cobra CB, Rhino liner, 3 inch EFX step bars.
Reason: More information
07-24-2008, 12:01 PM
eBay Motors
#7 (permalink)
| | Member
| OnStar LOL on getting OnStar to read the diagnostics. Seems all they can read on the diesels is:
Tire pressure
Oil life
Mileage
Location of vehicle (maybe)
__________________ Joe
08 GMC 2500HD SLT EC SB 4WD
EDGE w/Attitude, 50 Gal Aux tank
Downstate Illinois
07-24-2008, 01:24 PM
eBay Motors
#8 (permalink)
| | Member
| Quote:
Originally Posted by 08DMAX LO on getting OnStar to read the diagnostics. Seems all they can read on the diesels is:
Tire pressure
Oil life
Mileage
Location of vehicle (maybe) | Before my PCM was replaced because of a bad experience with a tuner, and the reflash, I got a regular e-mail report form OnStar about the engine, emmisions, tire pressures, etc. Since the replacement, and reflash, all they can read is the mileage, and oil life. Onstar said they had been getting several such complaints since the reflashes are being done.
__________________ 2007.5 2500HD LMM, AEM air intake, 5 inch DPF back MBRP exhaust w/6 inch tip, Banks Ottomind6 Power Pack, ARE tonneau cover, Cobra CB, Rhino liner, 3 inch EFX step bars. |
07-24-2008, 05:28 PM
eBay Motors
#9 (permalink)
| | Junior Member
| Do you have anything plugged into the OBD port? If anything is, On-Star can no longer read most of the sensors. I found this out after I plugged in my Insight.
John K
__________________ 2007.5 2500HD, White CC SB 4x4
Edge Insight Monitor, Fold a Cover, AMP Step, BD Exhaust Manifold, Banks Exhaust, Titian Tank, |
07-25-2008, 11:27 AM
eBay Motors
#10 (permalink)
| | Member
| Quote:
Originally Posted by John K Do you have anything plugged into the OBD port? If anything is, On-Star can no longer read most of the sensors. I found this out after I plugged in my Insight.
John K | That could be it. I have an edge plugged in.
| Advertisement
