Go Back   Chevy and GMC Duramax Diesel Forum > Chevy / GMC Duramax 07.5+ LMM Forums > 07.5+ LMM Performance Parts Discussion
07.5+ LMM Performance Parts Discussion Discussion of Performance Parts For the 07 and up LMM Duramax Trucks No Advertising
Old 07-05-2009, 07:31 AM   eBay Motors   #1 (permalink)
flatbed
Nuts!! Need EGR help
I can't get the nuts on the EGR studs to come loose (LMM). Is there a trick or a special tool needed. 12mm wrench does not give me enough leverage and not enough room for a ratchet.
Is there someone in NW Ark who will do this for pay.
2008 Chevy 3500 Crewcab, LMM, 4wd, Quad Stealth2, 4"MBRP (dpf delete), K&N drop-in, 9' custom "FLATBED".
Tracy
flatbed is offline   Reply With Quote
Old 07-05-2009, 07:40 AM   eBay Motors   #2 (permalink)
Johnasara
Yeah, That guy!!!!!
Johnasara's Avatar
Hose them down with some WD-40 and then tap on the wrench with a hammer. They are a pain to break loose but that is 3/4 of the battle.
4" DIAMOND EYE EXHAUST,
DIABLO @ 120,S&B COLD AIR INTAKE, RESONATOR PLUGGED
AUTOMETER ULTRALITE GAUGES, TRANSGO JR, EGR BLOCKED!!!!285/75 BFGs ON ULTRA DYMONDS, TIE ROD SLEEVES....Its Coming.....EFI LIVE.....
WORK RIG
Johnasara is online now   Reply With Quote
Old 07-05-2009, 07:40 AM   eBay Motors   #3 (permalink)
darkcherry08
darkcherry08's Avatar
Did you use an extension on the ratchet or a longer socket? If I can't get one of my bolts loose I just break out my torque wrench,it does wonders...
08 2500 LMM Z71 Hd with a Ready lift leveling kit,Banks monster exhaust,K and N filter,max energy programmer set at stage 3 a 91Hp tune,transgo,PPE shim kit, Jr 18-9 pro comp rims sitting on 325/60 r 18's Toyo A/t's,Westin Chrome nerf bars and Plasma Glow low beams and all emblems are gone except for the Z71 and Duramax on the hood,molding gone too.
WWW.HUSKERDIESEL.COM
WWW.PERFORMANCETRUCKPODUCTS.COM
darkcherry08 is offline   Reply With Quote
Old 07-05-2009, 07:43 AM   eBay Motors   #4 (permalink)
darkcherry08
I agree,put some WD 40 on it and let it work it's way in there...
Old 07-05-2009, 09:16 AM   eBay Motors   #5 (permalink)
HumboldtDmax
Obama stole my rims
HumboldtDmax's Avatar
Use a ratchet wrench and stand on it, you have to use all your weight straight down on the wrench. Those suckers are tight
7.5 LMM CHEVY CC LT Z71 white
Fab Four front bumper, lots of Line-X
Rancho 4in w/Bilstiens, HD tie rods and braces
35x12.5 Toyo MT on 20x10x4.5BS KMC Monsters in black
[BANKS intake,dual exhaust,intercooler]straight piped
BD manifold,Fitch fuel catalyst,res mod,EGR delete
AFE turbo tube, PPE race fuel valve
EFI live, Edge Insight
AD150 & SC4 collecting dust in the shop
HumboldtDmax is offline   Reply With Quote
Old 07-05-2009, 10:11 AM   eBay Motors   #6 (permalink)
dhaile
The bottom one is pretty easy with a 11 inch long ratcheting wrench. remove the passenger wheel and remove the inner fender liner and you can get to it. The top one is a real pain but I found I could get to it with the same wrench to loosen and then use a small 1/4 rachet to tighten and loosen the rest of the way. Put the big one on there again for the final pull to tighten back. Hope this helps
09 chevy 2500HD Duramax LT w Leather PPE HOT +2, MagnaFlo SS 4'', DPF Deleted, EGR Blocked! Granite Alloy GA7 20x9 LT275/65R-20 Goodyear Wrangler AT/S E
dhaile is offline   Reply With Quote
Old 07-05-2009, 10:15 AM   eBay Motors   #7 (permalink)
RedBowTies88
RedBowTies88's Avatar
if you can get some grab some PB blaster. its like wd-40 but much better hit it and let it sit over night and it should be like butter in the morning. i had the same problem.
also if you ever see stuff called Free All in a grey or silver can that stuff works amazing as well and is pretty fast to eat rust
LLY Cc/sb 4x4 RED
Originally Posted by Sean S
Originally Posted by McRat
