Go Back   Chevy and GMC Duramax Diesel Forum > Chevy / GMC Duramax 07.5+ LMM Forums > 07.5+ LMM Performance Parts Discussion
07.5+ LMM Performance Parts Discussion Discussion of Performance Parts For the 07 and up LMM Duramax Trucks No Advertising
Old 10-31-2009, 01:14 AM   eBay Motors   #11 (permalink)
09darkdmaxx
09darkdmaxx's Avatar
ok thank u sir!
-09 2500hd cc/sb
ppe intake mod with afe pro gaurd 7, turbo resonator block, pvc re-route...edge cs race, dpf delete, no muffler mbrp 4" turbo back,shim kit, egr blocker,diamondeye downpipe,transgo jr., deep pan,ready lift leveling kit, 285/75/16 pro comp xtreme a/t...and a new boss 8'2 power-v xt
in spring: airdog2, tie rod sleeves, cognito tie rod ends, suncoast stage3, afe bladerunner turbo inlet, snow performance stage1 water/meth, bd manifold!!!!
-08 2500hd reg/lb 6.0 (gasser)
flowmaster single cat-back exhast, airaid cold air intake, predator diablo tuner, 285/75/16 coopers, leveling lift
AlligatorPerformance.com/Amsoil syn/Powermaxperformance
09darkdmaxx is offline   Reply With Quote
Old 11-01-2009, 12:32 AM   eBay Motors   #12 (permalink)
D_R_C
D_R_C's Avatar
09darkdmaxx,
My question is why did you remove your mech boost gauge.
First compair the Edge with the mech gauge then go by the mechanical gauge.
Then you would have the Edge to monitor something else.
My mech combo egt/boost combo single gauge is dead nuts to my Edge Insight reading boost.
Which my mech gauge has hit 30 psi towing.
I have not towed since I installed the Insight.
Then I had room for something else to monitor on the Insight.
I am monitoring egt`s on my mech gauge from the pass side manifold, on the Edge Insight I am monitoring egt`s from the driverside BD manifold.
There is about 50-75 degrees difference between the two.
2007.5 GMC Sierra 3500 SRW BLACK,SLT,C.C.,4X4Loaded,DMax,(except for a aFe OEM airfilter part # 71-10101 Complete stock air intake mod, deleted the restricted muffler),Allison,Westach single gauge combo reading EGT/Boost egts from the pass. side, BD Manifold EGT readings drivers side on the Edge Insight, Rear Firestone Air bags with incab controller,back-up sensors, Back-up camera monitoring thru the nav monitor same as factory.
Security System Clifford Matrix 50.7 2 way remote with LCD.
"Nitto Terra Grappler" 285-70R-17
Oil used http://www.castrol.com/castrol/secti...tentId=7020026
D_R_C is offline   Reply With Quote
Old 11-01-2009, 05:57 AM   eBay Motors   #13 (permalink)
09darkdmaxx
Originally Posted by D_R_C View Post
09darkdmaxx,
true, it was just a cheap gauge for the time being... i will be getting another here soon...
it also made me wonder if the edge monitor picks up boost readings from a diff. spot in the system...
thanks for the input, i have read alot of threads that u have chimed in on, and got alot of great info
-09 2500hd cc/sb
Old 11-05-2009, 06:53 PM   eBay Motors   #14 (permalink)
D_R_C
D_R_C's Avatar
The Edge monitor gets the boost info from the computer.
The manual gauge is mechanical readings from the engine it is usually installed on the return from the intercooler back to the engine. Real life readings with a good boost gauge.
I used a boost manifold from SoCal that installs from the turbo to the inlet line to the intercooler, no drilling involved
And the readings are exact compaired to my Edge insight.
Old 11-05-2009, 07:21 PM   eBay Motors   #15 (permalink)
dslgray
mine dont read but 26 to 28 i heard thats about right but dont know the truth
dslgray is offline   Reply With Quote
Old 11-09-2009, 11:58 AM   eBay Motors   #16 (permalink)
D_R_C
D_R_C's Avatar
The truth is the boost readings can and will vary a little from engine to engine but usually no more that about 2-3 psi.
Old 11-09-2009, 12:30 PM   eBay Motors   #17 (permalink)
smokin'LMM
smokin'LMM's Avatar
with my PPE on level 4 itl spike to 35psi+ and then taper down to 30 or so
09 white on black CC/SB LTZ loaded.
RPB grill, 6k HIDs hi/low and fogs, pyro/boost gauges, 7-9" cognito, air bags w/compressor, train horns, 20" rockstars, 35" toyo MTs, 5% tint, AMP steps, DPF DELETE, 5" magnaflow w/ RPB tip all gone but the muffler, AFE intake, two JL 10's, all new interior speakers, PPE HOT, titan tank, bed liner, 10inch adjustable drop hitch, and more to come!
smokin'LMM is offline   Reply With Quote
