Go Back   Chevy and GMC Duramax Diesel Forum > Chevy / GMC Duramax 07.5+ LMM Forums > 07.5+ LMM Performance Parts Discussion
07.5+ LMM Performance Parts Discussion Discussion of Performance Parts For the 07 and up LMM Duramax Trucks No Advertising
Old 10-30-2009, 12:28 PM   eBay Motors   #1 (permalink)
09darkdmaxx
09darkdmaxx's Avatar
boost gauge question...
ok so before i got my edge cs race "that has a bost gauge" i installed a 30psi gauge so that i could monitor where it was at...was just curious... anyway i put that into the intake manifold just like the DIY write-up... and it worked fine no leaks....
now heres my question, the mech gauge i first installed was spiking out past 30psi no leaks, and i have now removed it and just run the edge but it only goes up to 28 psi???????
is that all that gauge should read i would have thought it would be more than that??
any help would be appreciated
-09 2500hd cc/sb
ppe intake mod with afe pro gaurd 7, turbo resonator block, pvc re-route...edge cs race, dpf delete, no muffler mbrp 4" turbo back,shim kit, egr blocker,diamondeye downpipe,transgo jr., deep pan,ready lift leveling kit, 285/75/16 pro comp xtreme a/t...and a new boss 8'2 power-v xt
in spring: airdog2, tie rod sleeves, cognito tie rod ends, suncoast stage3, afe bladerunner turbo inlet, snow performance stage1 water/meth, bd manifold!!!!
-08 2500hd reg/lb 6.0 (gasser)
flowmaster single cat-back exhast, airaid cold air intake, predator diablo tuner, 285/75/16 coopers, leveling lift
AlligatorPerformance.com/Amsoil syn/Powermaxperformance
09darkdmaxx is offline   Reply With Quote
Old 10-30-2009, 12:31 PM   eBay Motors   #2 (permalink)
AO2005
AO2005's Avatar
sorry i dont have the answer to your questiion but i know on my lly my 0-60 boost gauge only reads like 28 psi max also. So im not sure of why the old 0-30 gauge was maxed out.
ALAN
05 lly CC/SB 4" mbrp turbo back no kitty no muffler LBZ mp
res. plugged quadzilla stealth 2 135 tune
AO2005 is online now   Reply With Quote
Old 10-30-2009, 12:38 PM   eBay Motors   #3 (permalink)
09darkdmaxx
that makes more sense then maybe it was a faulty gauge? owell thanks for the input
-09 2500hd cc/sb
Old 10-30-2009, 12:43 PM   eBay Motors   #4 (permalink)
AO2005
AO2005's Avatar
i beleive that the computer stops it before 30 psi. im not real sure with the lmm nor am i for sure about any duramax.
ALAN
Old 10-30-2009, 02:00 PM   eBay Motors   #5 (permalink)
jc1843
These gages are not a calibrated instrument like you would use in a plane, which costs $$$$. These are just cheap monitor indicators.
Chevy 04.5 LLY, 265s, shell, XDR, MikeL 6spd, TransGo, deep pan, blocked, fingered, de-badged, PVC, 65 Gallon Aero tank, PPE, LBZ- mod, Pre-fuel filter, tow mirrors, BU cam, gauges, GPS, Sirius, bags
Old 10-30-2009, 02:18 PM   eBay Motors   #6 (permalink)
cainer70
cainer70's Avatar
i have maxed my 30psi gauge out and know someone else that has as well. almost looked like it was hittin 33 - 34.
07.5 Dmax Pioneer F90BT Nav Unit, Compustar Alarm/Remote Start, 6 inch Tuff Country lift on 35X12.5 Toyo MT's, 5 inch stright pipe/6 inch tip, turbo resonator plugged, transgo jr, Autometer cobalt pyro, boost, fuel pressure gauges, EFILive, S&B intake, AFE intercooler tube, airdog 150, PPE shim kit. Soon to come, EGR blocker and Diamond Eye Downpipe.
Thanks to Jess @ HUSKER DIESEL PERFORMANCE
WWW.HUSKERDIESEL.COM
86 3/4 ton bowtie 350/350 sitting on 44x19.5 swampers, gutted and custom interior with full interior rollcage,checkerplate dash, 10" lift and a wack load of speakers.
cainer70 is offline   Reply With Quote
Old 10-30-2009, 04:09 PM   eBay Motors   #7 (permalink)
09darkdmaxx
hmmm... well i will call edge and ask them about the tuner's gauge and how high it will read to...
thats where mine would look like it was reading.... so i am ordering a 60...
-09 2500hd cc/sb
Old 10-30-2009, 04:13 PM   eBay Motors   #8 (permalink)
AlligatorPerformance's Avatar
I have seen up to 35 psi on level 7, and that's both the mechanical DiPricol Gauge and the Edge.
Alligator Diesel Performance - Chad Hall Owner 1-866-255-7212
AlligatorPerformance is offline   Reply With Quote
Old 10-30-2009, 04:17 PM   eBay Motors   #9 (permalink)
09darkdmaxx
i am only running on level3 till i get my transgo jr. in there...
chad, i figured the edge gauge was right, does that sound like the correct boost for that level"28psi"?? just curious....
-09 2500hd cc/sb
Old 10-30-2009, 04:27 PM   eBay Motors   #10 (permalink)
I don't think I saw much more than that when I ran level 3.
