Go Back   Chevy and GMC Duramax Diesel Forum > Chevy / GMC Duramax 07.5+ LMM Forums > 07.5+ LMM Performance Parts Discussion
07.5+ LMM Performance Parts Discussion Discussion of Performance Parts For the 07 and up LMM Duramax Trucks No Advertising
Old 02-19-2008, 04:53 PM   eBay Motors  #1 (permalink)
2008 lmm's Avatar
heavy duty tie rods
whats a good brand that r strong...cause i snaped both of them this weekend in the sand and had to pay 250 thru the dealer for new ones to fix the truck cause i couldnt moved it
2008 2500 6.6 lmm LTZ 4x4 c/c l/b..6 inch lift on 17 inch moto metal 951 rims, tires 37/12.5, trian horn, PPE hot race 2with dpf delete, 5inch turbo back with 6 inch black rpb tip, S&B CAI, autometer boost/egt gauges, bd exhaust manifold, 7 inch in dash tv, 2 7 inch headrest tv, 3 jl audio 10 subs custom box 2 jl audio amps, 8,000k hid lights,
2008 lmm is offline   Reply With Quote
Old 02-19-2008, 04:56 PM   eBay Motors  #2 (permalink)
Raul B's Avatar
Fabtech ones are pretty good...
2002 7.3L Excursion
10.5" DR lift, dual Bilstiens, 40" Toyo's on 20" Welds, custom grill, custom bumpers, custom Trac bar with Integrated blocks, AMP steps, train horns, DC power Alternator and More.....
Raul B is offline   Reply With Quote
Old 02-19-2008, 05:01 PM   eBay Motors  #3 (permalink)
2008 lmm's Avatar
alright thanks ill look into them..im already running there lift
Old 02-19-2008, 05:08 PM   eBay Motors  #4 (permalink)
Extreme lb7 Dmax's Avatar
Crank it up diesel has tie rod renforcement stuff. Crankitupdiesel.com
2003 Duramax lb7
stock/5spd Allison
Edge/attitude
Silverline Exhaust
4 inch turboback
AFE air filter modded air box
Turbo Mouth piece mod
Extreme lb7 Dmax is offline   Reply With Quote
Old 02-19-2008, 05:20 PM   eBay Motors  #5 (permalink)
Hi, I'm Earth. Have we met?
05_LLY's Avatar
Tie rod sleeves and some cognito braces should make it pleanty strong enough, but if you want stronger go with a straight center link and the tierod sleeves!!!
Crankitupdiesel.com
Cognito Steering Support Kit
Mine~05 D/ZF Reg. Cab D-Max/ZF-6 Twin Turbos, Twin pumps, tripple clutch, 60% Extrudehones ~ 11 sec truck
Hers~04.5 D/A CC/SB- s300, Single Pump, 40% Extrudehones~12 sec truck
runNADM.com
Thanx IdahoRob for all the help with the injectors!!
