Go Back   Chevy and GMC Duramax Diesel Forum > Chevy / GMC Duramax 07.5+ LMM Forums > 07.5+ LMM Performance Parts Discussion
07.5+ LMM Performance Parts Discussion Discussion of Performance Parts For the 07 and up LMM Duramax Trucks No Advertising
Old 05-23-2008, 04:43 PM   eBay Motors   #31 (permalink)
D-Max HD4
Points: 214, Level: 4
Points: 214, Level: 4 Points: 214, Level: 4 Points: 214, Level: 4
Activity: 0%
D-Max HD4's Avatar
K does anyone have any tips on how to remove the FPRV from the engine without rounding the head. I cannot get enough torque on it to break free, any suggestions would be appreciated, thanks
'08 2500HD LTZ HD4 conversion
18" AR rims, 3" Rancho HD Level/Suspension, Custom Interior
Banks Six-Gun with Power PDA
Banks Ram Air Intake
BD Performance Exhaust Manifold
4" MBRP Stainless Dual Exhaust
PPE Lift Pump
PPE FPRV Shim Kit
"If My Wife Only Knew"
D-Max HD4 is offline   Reply With Quote
Old 05-23-2008, 09:54 PM   eBay Motors   #32 (permalink)
BigRedChevy
Duramax Forum Moderator
Points: 5,923, Level: 32
Points: 5,923, Level: 32 Points: 5,923, Level: 32 Points: 5,923, Level: 32
Activity: 100%
BigRedChevy's Avatar
I had to use a swivel 6pt. Socket with a cheater bar.
KYLE
05 Chevy LLY Crew Cab LT Dually 4x4, Crank it up Diesel Tie rod sleeves and centerlink, BD Diesel Remote Fuel Filter, EGR Blocked, TTS Dual Lift Pumps, FPRV Shim, Bullydog Outlook Monitor, AFE Stage 2 CAI, BD Diesel Manifold, Diamond Eye Turbo Direct Pipe, Diamond Eye 5" exhaust straight piped, Level Kit, Suncoast Stage IV w/ 1056 Torque Converter and Allison Deep pan
Old 06-10-2008, 08:22 AM   eBay Motors   #33 (permalink)
D-Max HD4
Activity: 0%
D-Max HD4's Avatar
Alright so I finally have time to work on my truck and put in the FPRV shim kit. I was finally able to break it loose, and now I have a question. I've been driving the truck for a couple weeks and pulling a skid loader around and I know that I've been popping the valve numerous times. So I was just going to put on a new FPRV with the PPE shim kit but found out a '08 FPRV cost about $600. So to ensure that I don't have any future issues should I put in the 3rd shim that comes in the kit that is suppose to be put on only with the duramaxamizer kit. Thanks for the help.
PPE Lift Pump
PPE FPRV Shim Kit
Old 06-11-2008, 08:27 AM   eBay Motors   #34 (permalink)
D-Max HD4
Activity: 0%
D-Max HD4's Avatar
I went ahead with the two shims in the FPRV mainly due to the recommendation from a local shop. They told me even though it may be slightly weaker due to multiple compression, it would actually make it weaker in the long run if I put all three shims in. So I put in two and put it back in and took it out this morning, and I'm very pleased to find that that was all my truck needed. The tranny still has to relearn the shift points because now it has all the fuel it needs at higher rpms. But I still took a new '08 mustang GT without even tryin. So I'm very happy with my results so far and with post up latter with my new improved MPG's or any issues that I have. Thanks for all the help.
PPE Lift Pump
PPE FPRV Shim Kit
Old 06-17-2008, 06:03 PM   eBay Motors   #35 (permalink)
WILDMANNS DIESEL
Points: 144, Level: 2
Points: 144, Level: 2 Points: 144, Level: 2 Points: 144, Level: 2
Activity: 0%
WILDMANNS DIESEL's Avatar
im confused! banks says to use a 7/16 drill bit for the manifold hole and tap it with a 1/4 inch tap. how will this work considering 7/16 hole is bigger than a 1/4 in tap?
im installing the egt sensor
07 DURAMAX LMM
8" PRO COMP
4 12" JL W6
DYNAUDIO
WILDMANNS DIESEL is offline   Reply With Quote
Old 06-17-2008, 07:10 PM   eBay Motors   #36 (permalink)
TheHoov
Points: 2,508, Level: 20
Points: 2,508, Level: 20 Points: 2,508, Level: 20 Points: 2,508, Level: 20
Activity: 22%
Activity: 22% Activity: 22% Activity: 22%
TheHoov's Avatar
Im looking at installing the 6 gun bundle and the BD exhaust manifold this summer im really excited.
2002 Chevy LB7 Crew Cab
Thank you Duramax Forums
TheHoov is offline   Reply With Quote
Old 06-17-2008, 07:43 PM   eBay Motors   #37 (permalink)
D-Max HD4
Activity: 0%
D-Max HD4's Avatar
wildman, yea i noticed that little piece of miss information as well during my install. I went ahead with the BD performance exhaust manifold, not only because they already have a hole pre-tapped for the egt sensor, but they are also alot less restristed then the stock manifold. When they designed the factory manifold they thought there would be a clearance issue between the manifold and the steering shaft, but there is not, so all they really did is put the engine out of balance due to the restricted flow. Also I have heard horror stories about getting shavings from tapping that hole into the manifold and making their way to your turbo and doing some real damage.
PPE Lift Pump
PPE FPRV Shim Kit
Old 06-17-2008, 07:48 PM   eBay Motors   #38 (permalink)
D-Max HD4
Activity: 0%
D-Max HD4's Avatar
Hoov, Good luck with the install, I know that you'll enjoy the power gains, good idea goin with the BD manifold, little more work but worth it. Only piece of advise that I have is take your time working your way up to a higher power level, give your tranny plenty of time to re-learn shifting points with the additional power. Oh and plan on putting in an FPRV shim kit if you get above power level 4. Are you gettin the Six-Gun with the PDA? if not I would hold off and spend the extra money, well worth it. Let me know If you have any questions with your install, I will try to help, good luck.
PPE Lift Pump
PPE FPRV Shim Kit
Old 06-17-2008, 08:07 PM   eBay Motors   #39 (permalink)
WILDMANNS DIESEL
Activity: 0%
oh no instant code. i only drove it about a mile and it threw a p009e fuel rail pressure relief code. what does this mean? it did go into limp
07 DURAMAX LMM
8" PRO COMP
4 12" JL W6
DYNAUDIO
Old 07-07-2008, 07:01 PM   eBay Motors   #40 (permalink)
youcandoit
Points: 258, Level: 5
Points: 258, Level: 5 Points: 258, Level: 5 Points: 258, Level: 5
Activity: 0%
has anyone install a lift pump on a 08 duramax? and whats your opinon on it? is it worth it or should i not even think about it and just do the valve relief
youcandoit is offline   Reply With Quote
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96
