Go Back   Chevy and GMC Duramax Diesel Forum > Chevy / GMC Duramax 07.5+ LMM Forums > 07.5+ LMM Performance Parts Discussion
07.5+ LMM Performance Parts Discussion Discussion of Performance Parts For the 07 and up LMM Duramax Trucks No Advertising
Old 05-23-2008, 04:31 PM   eBay Motors   #1 (permalink)
Duramax Power
Points: 155, Level: 3
Points: 155, Level: 3 Points: 155, Level: 3 Points: 155, Level: 3
Activity: 0%
Duramax Power's Avatar
Eliminating the top speed limiter on an 08 duramax?
I have an 08 duramax with banks six gunner with pda. A bank intake, and mbrp filter back dual exhaust. my problem is that my truck wont let me go over 96 mph. how can i get rid of that b/c the banks system doesnt have the option to raise the top speed.
Duramax Power is offline   Reply With Quote
Old 05-26-2008, 07:24 PM   eBay Motors   #2 (permalink)
DMAX Z71
Points: 84, Level: 1
Points: 84, Level: 1 Points: 84, Level: 1 Points: 84, Level: 1
Activity: 0%
Hey man i have the full big hoss bundle and yea you cant change your top speed unless you stack another programmer, which i did. and banks can calibrate the speed but only with the pda and even then it doesnt correct the trucks spedo just tells you the correct speed on the pda. you can find anouther cheap programmer from pro=comp or something and use it to remove the spedo, rev., and correct tire size.
07.5 Duramax : Banks Six-gun with PDA, Techni-cooler, Ram-air, DPF filter back Banks exhaust. And a stacked programmer to take the gov. off the rev. and the spedo.
DMAX Z71 is offline   Reply With Quote
Old 05-27-2008, 06:13 PM   eBay Motors   #3 (permalink)
Duramax Power
Activity: 0%
thanks for the info. i wasnt sure what to do. i will have to look into it.
Old 05-28-2008, 08:43 PM   eBay Motors   #4 (permalink)
DMAX Z71
Activity: 0%
Sure thing man, no problem. Hey Im trying to figure out how to lower my EGT's, do you happen to have any suggestions??
Old 05-28-2008, 08:55 PM   eBay Motors   #5 (permalink)
Meyerperformance
DPF Delete man
Points: 7,617, Level: 37
Points: 7,617, Level: 37 Points: 7,617, Level: 37 Points: 7,617, Level: 37
Activity: 100%
Meyerperformance's Avatar
water meth injection, or dpf delete
07.5 Chevy Summit White Reg cab LMM, Quadzilla steath 2, 5" MBRP straight pipe, 5" turn-down DPF Deleted, Cobalt boost & pyrometer, line of fire and ice. 5% tint. Banks Ram air intake.
www.meyerperformance.com
(812)-344-4421 Tyler
Meyerperformance is online now   Reply With Quote
Old 05-28-2008, 08:55 PM   eBay Motors   #6 (permalink)
BigRedChevy
Catch Me If You Can!
Points: 8,123, Level: 38
Points: 8,123, Level: 38 Points: 8,123, Level: 38 Points: 8,123, Level: 38
Activity: 100%
BigRedChevy's Avatar
TWINS
KYLE
Old 05-28-2008, 11:32 PM   eBay Motors   #7 (permalink)
DMAX Z71
Activity: 0%
Well in order to do the delete do i have to cut the DPF filters out or what? can i just take it out with a programmer??
Old 05-28-2008, 11:47 PM   eBay Motors   #8 (permalink)
psyco66
Points: 3,582, Level: 25
Points: 3,582, Level: 25 Points: 3,582, Level: 25 Points: 3,582, Level: 25
Activity: 0%
psyco66's Avatar
Get a PPE or EFI live and buy an turbo back exhaust for an LBZ and you are good to go. If you get a PPE or EFI live you can change the top end speedo and you will be realy happy with ether programmer.
John
EFI LIVE with McRat tune, DPS5, PPE Lift Pump, 4inch Turbo Back Strait Piped MBRP Duals, EGR block off, AFE stage 2 intake, Turbo resonator blocked off, 6000k HID kit, 305/75/16Super Swampers on stock rims, Auto Meter boost and pyro gauges, Killer sound system, Limo tint all the way around, Suncoast Stage IV built by me.
NO TALKING JUST LINE IT UP
psyco66 is offline   Reply With Quote
Old 05-28-2008, 11:58 PM   eBay Motors   #9 (permalink)
DMAX Z71
Activity: 0%
yea but i already have spent over a $1100 on the six-gun with PDA!
Old 05-29-2008, 12:02 AM   eBay Motors   #10 (permalink)
psyco66
Activity: 0%
psyco66's Avatar
Try to sell it. Just put it up and see what you can get for it. EFI live goes for 750 with 2 tunes and a set of guages and a piller pod go for around 300. Hope this helps. You will be very happy with the EFI live or PPE.
John
