Hey guys I have been hearing a lot of people say they have the EGR block...What is this all about? What benifits does it have?
__________________ 2007.5 Duramax 2500HD LS
Black Leather
12" FTS lift w/ dual front shocks, rear springs (no blocks)
37x13.5 Toyo MTs on 22" XDs
EFI Live
Edge Juice w/ Attitude (Used as guages only)
5" Turbo Back Straight Pipe Exhaust
AFE Stage 2 Cold Air Intake
Onboard Air
Sprayed-In Bed Liner
it block the exhaust from recirculating through the engine, it make the inside cleaner and yields a little performance gain
__________________ 07.5 Chevy Summit White Reg cab LMM, Quadzilla steath 2, 5" MBRP straight pipe, 5" turn-down DPF Deleted, Cobalt boost & pyrometer, line of fire and ice. 5% tint. Banks Ram air intake.
Meyer Performance & Fabrication, LLC Home of your diesel performance needs. www.meyerperformance.com (812)-344-4421 Tyler Fass Sale for November pm for details.
Why is it even there? Does ot throw any codes or anything when blocked?
Black Leather
EFI Live
Onboard Air
Oh yeah she will throw codes for sure.
Most tuners will be able to get rid of them, or you can go the finger stick route.
Pretty sure that even some monitors (edge insight) can also clear codes now.
just my 2 cents
__________________ 06 Chevy Duramax LBZ 3500 Dually
4"MBRP turbo back, Amsoil (Injen) cold air intake
PPE Standard (Level 2)
Edge Insight monitor, Edge dash pod mount
Edge Insight Pyro, PPE EGR blocker plate,
BD Manifold, Bed rug box liner
what is finger stick? Yeah my Juice reads and clears the codes, but if you dont fix the "problem" that set off the code in the first place, it will just come back on.
Black Leather
EFI Live
Onboard Air
A finger stick is a little computer chip that fools the computer into thinking that the egr is getting proper flow. I am not sure, but i don't think they make one for the LMM though.
__________________ KYLE
I must be lame...'cause I just can't get back there to block it w/out removing allot of things in the way. I give allot of credit to the people who blocked their LMM.
Maybe it would be easier and better to just get rid of the whole egr system...I just gotta do more research on figuring out how to go on doing it. LOL...
__________________ 08 Sierra WT CC SB
Steel Gray 4x4
PPE RACE
Modded OEM AirBox/PCV Reroute/4" MBRP into 5" MagnaFlow/ EGR BLOCKED
Isspro EGT/Boost gauges Cognito Leveling Kit/HD Tie Rods Pitman/Idler Support Brackets/Bilsteins
Pirelli Scorpion ATR 265/75/16 Coated OEM Wheels
Factory Oval Steps/Rhino Lining
Klein Air Horns (4)/ViaAir 150 psi 2g compressor
ya everyone says the block plate on lmm is awful thats why i in no hurry to do mine
Yea ... it's a bitch to get in there. I have not done mine yet also. Started to but didn't have the time to really get into it so I put it back together before I was past the point. Also I myself would not use the finger stick. Great product in it's time but I would use a programmer that has the EGR turned off to do the job of the light. Cleaner and not something the dealer can say something about if they seen the wires spliced on. Just my 2cents.
I have heard that with the EGR turned off you can get away with the same as blocking it but if you push big PSI #'s then it will force it open so a plate is best.
First thing to do is find a programmer you like that has this future to turn off the EGR in it and go from there.
Nor-Cal Nick
__________________ 2008 Chevy 3500HD Dually LTZ <<< Clink on link to see truck.
Cognito 2-3 leveling kit, HD tie rods, Steering braces, Idler pivot, Front & Rear Sway Bar, Bistein's frt & rear, Sulastic shackles, Bags, Toyo MT 295/70r17 w/2" spacers, AFE stg2, MBRP 5" turbo back w/RBP back 6" tip, EFI Live by Duramaxtuner.com, Nexus gauges, Nicktane fuel filter, TTS Dual pumps & pick up, Transgo JR, MagHytec Trans & Diff pans, Titan 62gal fuel tank, Amp boards, 8000k HID Headlights and fogs, Drawtite Sig.24k 5er.
6-7-08 “400hp Fun Tune” >> 414hp./786tq.
6-7-08 “LMM08_08_HOT_6.07.08_Highboost” >> 440hp./805tq.
Black Leather
EFI Live
Onboard Air
